Old 07-14-2017, 08:26 PM   #29
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
23fd Battery disconnect switch install
Ordered them pre-made from Amazon. 1/0 sized cables with 3/8th inch ring terminal ends. One black and two red.
https://www.amazon.com/dp/B07113NT8K..._tHFkeT96m8UqD
I did have to add ring terminal ends to the main 12v leads from the trailer (I cut off the automotive clamps, which is necessary for the hot/+ lead at a minimum as it fastens to the switch) - I had some of those in my toolbox and I also own a crimp tool....
wulfraat is online now   Reply With Quote
Old 07-16-2017, 06:09 AM   #30
Cispook's Avatar
2017 27' Flying Cloud
Chillicothe , Ohio
As I read it, you added 3/8" terminal rings on the cut off wires for placement in the cut off switch? Thanks
Cispook is offline   Reply With Quote
Old 07-16-2017, 06:54 AM   #31
wulfraat's Avatar
Correct, this is required for the main pos 12v feed as it connects to the rotary switch in the picture. This is a 6ga wire.
I did the same for the beg feed for consistency although strictly speaking adding a ring terminal to the negative feed is not required. (Also a 6ga wire)
Pop/neg feeds from the inverter are already equipped with ring terminals. These are 4ga wires.
I used 1/0 gauge wires to replace the 2 parallel connections across the batteries for good measure. Stock from the factory the parallel connections are 6ga wires. Too small!
Old 07-16-2017, 12:43 PM   #32
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Positive side is the way to go.
I used a single switch that allows me to select:
1 - main 12v trailer feed
2 - inverter feed
1+2 - trailer+inverter
all off
Wulf this is the switch you used, yes?
https://www.bluesea.com/products/600...y_Switch_-_Red
Can't tell from pic, how did you mount the switch, or is it just held in place by the wires?
After seeing your switch in person, do you think the 2-terminal switch would work, i.e. is there enough room to attach the lugs from both the inverter and main 12v feed to one lug, resulting in "all on" or "all off" condition, or would it be too tight with the heavy gauge wire?
Thanks for the intel, this is next on my list.
pcskier is online now   Reply With Quote
Old 07-16-2017, 03:20 PM   #33
wulfraat's Avatar
That is the switch I have. It's floating in place and secured by a zip tie and 1/0 gauge wire which won't budge much.
Yes there is enough room for 2 lug connections (one from the inverter and one from the 12v main trailer hit feed). The 1/0 gauge wire goes to the battery and has its own terminal connection.
Old 07-16-2017, 08:07 PM   #34
2007 22' International CCD
There are 4 nice holes in the corners of the switch that will accommodate a faster of your choice, be it wood screws or machine screws...
Old 07-17-2017, 02:53 PM   #35
pcskier's Avatar
Park City , Utah
Yes, but I was asking what those screws were mounted to. One person used a sheet of plexiglass on the center threaded rod which was slick. Wulf just let his be held in place by the cables which is the route I'm taking. It won't be going anywhere attached to those heavy cables.
Old 07-17-2017, 02:56 PM   #36
pcskier's Avatar
Park City , Utah
Thanks again. Based on that, is there a reason you chose the 3-position switch with 3 terminals, vs the 2 position switch with 2 terminals, and put the invertor and 12v feed cables on one lug? Just want to make sure I'm thinking this through all the way before ordering!
Old 07-17-2017, 05:54 PM   #37
wulfraat's Avatar
Yes on a previous install I used those holes and put two screws into the side of the battery box and mounted the switch on the outside.
With the newer battery boxes however they are deep enough to accommodate the switch on the inside sitting on top of the batteries.
For this latest install I just used zip ties through the holes to keep the casing of the switch buttoned up and then a single zip tie that attach the switch body to a cable to keep the switch from bouncing about inside the battery box
Old 07-17-2017, 05:55 PM   #38
wulfraat's Avatar
No worries. I'll draw you a picture and upload when I get home this evening
Old 07-17-2017, 06:14 PM   #39
pcskier's Avatar
Park City , Utah
Thanks. Based on your earlier description and photo, I think I'm clear on how you wired yours, using this switch, you had one cable on each of these lugs, from the 12V Main Feed to trailer; the Inverter Cable; and lastly the jumper from the second battery + side. Giving you the option to choose 12V Trailer feed only on, Inverter only on, both on, or 'all off'.
I was thinking of using this switch, and putting the 12V feed to trailer and the Inverter feed on one lug, and the feed to battery on the other lug. What I was wondering is if there is enough space on the lugs to be able to put the Inverter and Trailer feeds on one of them. This would allow me the choice of 'all on' or 'all off.'
Assuming there is enough room for me to put both cables on one lug, was there an advantage you saw in having the ability to choose between 'all on', '12V Feed only,' 'Inverter only', and 'all off'?
Thanks again for bearing with me. Not a big deal either way, I just like to see how others arrived at their solutions to be sure I'm not missing something that might be helpful later!
Old 07-17-2017, 08:37 PM   #40
wulfraat's Avatar
4-position battery disconnect switch wiring
Let me know if this makes sense.
Name:	airstream battery disconnect switch wiring.jpeg
Old 07-17-2017, 08:41 PM   #41
wulfraat's Avatar
2-position battery disconnect switch wiring
... and here is the wiring for a single 2-position switch...
Name:	airstream battery disconnect switch wiring 2.jpeg
Old 07-17-2017, 08:44 PM   #42
wulfraat's Avatar
Yes you can fit both POS cables to the trailer & inverter on a single lug on the switch. I like to separate because I like to have options you are good either way.
Battery Disconnect Switch Issue ATE123 Sprinter and B-van Forum 17 08-28-2017 07:31 AM
Battery Disconnect Switch Not Working Toronto_Guy Batteries, Univolts, Converters & Inverters 9 04-13-2015 05:39 PM
Battery Disconnect Switch Question MaryD Batteries, Univolts, Converters & Inverters 4 07-13-2013 08:19 AM
Battery Disconnect Switch nsbcpa Batteries, Univolts, Converters & Inverters 5 08-10-2012 05:11 PM
Battery Disconnect Switch, Solar & AGMs SilverGate Batteries, Univolts, Converters & Inverters 29 11-03-2010 10:52 AM
