Old 01-08-2019, 02:50 AM   #1
2019 23' Flying Cloud
West Sacramento , California
23 Vent fan front and back
Dumb question.
How do you operate them?
I had the propane heater on for 65° and wanted to air out the trailer a bit. It's been raining last couple days but has been clear all day.
So I go to press "on" it opens then closes. Then doesn't open again. I have the fan speed to zero and have the fan switch to on. All of which is a moot point because it doesn't want to open at all.
I try the one buy the bathroom. Doesn't even open. I press then wait. Nothing.
I have the dial on the neutral setting as I don't need heat. Sometimes they open but don't want to close and I have to do it manually.
I'm very frustrated with these fans. The videos aren't any help. The guy make it look so damn easy. Just goes over and presses the on switch and it works. Not for me. I can't even get them to open tonight after five minutes of pressing every (TWO) button and a temperature dial.
Thanks.
Brandon T. is offline   Reply With Quote
Old 01-11-2019, 09:59 PM   #2
Well it was a clear blue sky day today and the fans operated fine doing the following.
Switch the fan speed from zero to one.
Turn on the fan switch.
Turn temp to cold
Pressed the black power open button.
Worked!
But then it wouldn't close once I hit the black power button? I had to manually close it
obviously turning the motor in the process.
Grrrr!
I hit all the switches and turned the temp to and it wouldn't close.
Can't figure this thing out.
Old 01-12-2019, 04:56 AM   #3
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Brandon,
Here’s my best guess at your problem.....
The fans have Rain sensors. Just under the edge of the lid. If these sensors get wet in any way the fan lid will close. This is to prevent you from accidentally leaving them open and getting rain inside your unit.
The fans have 6 (yes I said SIX) switches to operate them
#1 Fan on-off switch. This switch activates 12 volt DC power to the fan motor
#2 Lid open-close switch. This switch actuates the fan lid up and down.
#3 Rain sensor. This switch overrides the lid open-closed switch if it becomes wet.
#4 Lid position switch. This switch disconnects power to the fan motor when the lid is closed, preventing the fan from running without air flow.
#5 Fan speed switch. This dial controls motor speed 0=off 1=low 2=med 3=High
#6 Temperature switch. This switch allows you to roughly control at what temperature the fan turns on an off at.
So with that said... for the fan to operate these things need to happen
#1 fan lid has to be open. This means that the rain sensor must also be dry.
#2 fan power switch must be in the “On” position
#3 fan speed control has to be on 1,2,or3 setting. (If on “0” fan will not work)
#4 Temperature control must be set low enough for it to allow the fan motor to operate.
NOW. About manually operating the Fan Lid with the Spin Dial.
You should not turn the dial with it engaged with the lid lift motor.
You should disengage the Spin dial.
To do this “pull” down on the Spin dial and then you can rotate it with out the resistance of the lid lift motor. To re-engage the lid lift Spin dial to the motor push up on the Spin dial ( you may have the slightly turn the dial while pushing up on it to get it to re-engage with the splines of the lid lift motor.
Whew!
Dept of “OverKill”
Old 01-12-2019, 07:29 AM   #4
2017 23' Flying Cloud
Bartlett , Tennessee
The "fan speed" switch turned to 0 turns it completely off. It won't open. Set the fan speed switch to 1.
The small black switch opens and closes the vent. It does nothing else.
The big black switch is the fan power switch. All it does is turn the fan on and off. It has nothing to do with the vent opening and closing. If this switch is turned on, and the vent is open, then the thermostat knob determines if the fan will run.
The thermostat knob is what you use to determine if the fan auto turns on/off. It is temperature dependent. It has nothing to do with opening or closing the vent. It only turns the fan on/off.
They do not auto-open. They only auto-close if the rain sensor detects moisture.
They do not heat. Turning the thermostat knob to the hot setting only means that it must be hotter for the fan to turn on.
Personally, I keep my fan speed dial set to 1 so it will work, but at low fan speed. I keep my thermostat knob set to completely blue so if I turn on the fan it will work. When I want it off, I use the fan switch to turn it off. I use the small toggle switch to open/close the vent. I use the big toggle switch to turn the fan on/off. I ALWAYS use these settings and don't let the fan auto-anything except for the rain sensor.
Bobbo, Lin and the furry kid (45 pound rescue)
2017 F-150 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 01-12-2019, 08:05 AM   #5
2019 25' Flying Cloud
Hendersonville , North Carolina
Vent fans
We have a 2017 23D with the 2 roof fans. At first my fans would close at the first hint of any rain. So I installed the Fantastic Fan covers with the bug screen. This should have made these fans a bit less sensitive to a bit of rain. Not so. If fan was on and you even sweated inside the dang things would close. One call to Manufacturer and a 5 minute conversation with nice lady that answered call told me how to eliminate rain sensor. Problem solved. I can leave my fans on or just the cover open and it has to be raining pretty hard before any drops of water come in. Read your instruction booklet on how to operate. Takes 5 minutes per fan to disconnect rain sensor. Love the fans. The rain sensor not so much.
uraljohn is offline   Reply With Quote
Old 01-23-2019, 03:00 AM   #6
Appreciate the detail reply. The front vent by the bathroom does open, does go whirrrrr, then closes.
Back one by the bedroom acts exactly like you wrote upon operating it. It's pretty straight forward and does what it's supposed to. Hit the open switch, setting on "cold", turn the dial to one for fan speed and away we go until I want it closed.
Not the front one. It's smart you see and wants to piss you off. It seems to somehow be tied to the bedroom one and I haven't figured out the relationship between the two. Once, I had both open and the back bedroom one decided to blow air INTO the trailer while the other sucked out air. That was a head scratcher.
Old 01-23-2019, 03:04 AM   #7
Originally Posted by GMFL View Post
Brandon,
Whew!
Thank you. Might be a rain senor issue with the front one by the bathroom. I'll check it out.
Old 01-23-2019, 07:53 AM   #8
You must have a different model fan than I do. While Fantastic Fans does make a model with reversible fans, mine do not have that feature. Now, if I have both vents open and turn one fan on to exhaust the air, the other fan blade will spin as air is drawn in.
Old 01-23-2019, 05:39 PM   #9
Well I'm ready to Theo this damn thing out.
It's in the open position currently and I want it to close. It's NOT CLOSING. I press the open and close button and nothing. I see the little picture it provides so I know I'm pushing it in the right direction. I also have the model one can't pull out the handle to manually close it. I pulled on it and damn near bring the roof down. It's not popping out. So I have to close it with the motor engaged. Is it asking to much to make a toggle switch that opens and closes when pressed! Arrrrgh!!!
Frustrating.
Whoa. What just happened. While waiting for a picture to upload I turned the fan speed on, then to setting number 3,.which started to turn. I quickly hit the close button while the fan was in operation. It started to close. So I quickly turned the fan off.
What a damn strange way to close the vent.
Old 01-23-2019, 08:10 PM   #10
If the fan speed knob is set to 0, everything except the rain sensor is turned off. The switch to open and close the vent included. Never turn the fan speed knob to 0.
Actually, I am assuming that the rain sensor is still operational with the fan speed knob set to 0. Does anyone actually know?
Fan Tastic vent roof vent with 12 v fan Sanne Airstream Classifieds 0 08-04-2018 11:28 AM
Roof pipe vent covers and fan vent covers stormbornSG Exterior Restoration Forum 3 11-09-2016 05:27 AM
Fan-tastic Vent 3000BT Fan 110 Volt, 3 Speed, Smoke Dome top, Built in Thermostat? pejokerst Airstream Classifieds 0 02-19-2014 08:45 AM
Fan-Tastic Vent Fan roadliner54 Our Community 2 07-11-2011 11:14 AM
Back and forth, back and forth.....what 2 do??? WILDRTEXAS Upholstery, Blinds, Walls & Interior Finishes 19 11-30-2009 05:24 PM
