Old 01-05-2020, 05:27 PM   #1
Huntsville , Alabama
2019 25 RBT lift kit to get in driveway
I am about to buy a new house and thinking ahead drove the AS over to see if I can get it up the drive. With the WD bars removed I backed up making a sharp turn in no problemo. Leaving I scraped the right rear ever so slightly. I think the lift kit would fix the problem. The house is the one mama wants and the AS will not be the reason she does not get it. I read lots of posts on adding the dexter kit and it looks straight forward. Anyone have experience adding one to a new 25’? I don’t think I can weld tabs to bolts or alter to fit but don’t want to pay to have it done either.....
McDonald256 is offline   Reply With Quote
Old 01-05-2020, 06:59 PM   #2
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Congratulations on finding the new home and great thinking ahead about the Airstream / clearance.
Thinking outside the box, would it be possible to use a temporary wood ramp (2x8’s) to span the low spot? I’m sure the lift kit would do the job but perhaps there’s an alternative solution? I know it’s not as convenient but would be less expensive.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 01-05-2020, 07:17 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Have the lift kit installed. It’s a PITA to install. I paid $600 bucks worth every penny. They should ship them from the factory with the lift kit - big improvement in ground clearance and zero effect on towability.
Chalk it up to an expense associated with buying a new home. It will be the first of many haha.
wulfraat is offline   Reply With Quote
Old 01-05-2020, 07:22 PM   #4
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
I have installed several (5) and would be happy to help. Also I’m just south of you.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
GMFL is offline   Reply With Quote
Old 01-05-2020, 07:52 PM   #5
StuartsDad's Avatar
2018 28' Flying Cloud
Chapin , South Carolina
I had same issue with my 28' going in or out of driveway. Initially I used boards in the low spots (PITA) until I installed the Dexter lift blocks. Problem solved. Having the tabs welded on would certainly make installation easier, especially if installing it by yourself. I did not have the tabs, but had two pair of hands, one to hold wrench, other to operate impact wrench. A cheap 15/16 combination wrench, cut in half and a makeshift long extension handle did the trick for me. I like the kit for reasons beyond just my driveway clearance.
Since you just barely scrape the rear and if you don't really want the lift for any other reason, you might get by using a non WD drop receiver just for getting in and out of the driveway. Get one that lowers the front of your AS, thus raising the rear a little. I have to do that because my Blue Ox hitch head will drag.
StuartsDad is offline   Reply With Quote
Old 01-05-2020, 08:10 PM   #6
Where about? I might take you up on that.
Old 01-05-2020, 09:00 PM   #7
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Dadeville,
Haven’t done a 25’, but I’ve done a few for sure.
Old 01-05-2020, 09:09 PM   #8
That’s not too far. If your willing to help I might take you up on it if the stars align and I get the house.
Old 01-05-2020, 10:18 PM   #9
Steamy1's Avatar
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
Hi Wulfraat,
Could you share who installed yours?
Many thanks!
Steamy1 is offline   Reply With Quote
Old 01-06-2020, 09:27 AM   #10
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
There are several videos on YouTube "less we explore" has a very detailed install video
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 01-06-2020, 05:00 PM   #11
2017 25' Flying Cloud
Woodway , Texas
Good to hear so many are upgrading their ground clearance! We did the wood ramp--a couple of 2" x 12"s to lift the rear end on a high-crowned street. Problem was stowing the ramp after each exit and retrieving it on return. And we STILL scraped if the approach angle was off a bit.
Got the Dexter lift kit for our 25FB's axles and the 2x's got delegated to other projects. Only complaint was that the nuts and bolts supplied didn't thread well so we replaced them with a load of grade 8's from Ace Hardware; those supplied were grade 5.
Dropping the axles wasn't difficult but a roll-around floor jack to maneuver them throughout the process is strongly suggested; and you may need a couple of flare wrenches if your PVC-jacketed gas line goes through the street-side axle bracket. Watch the routing of the leads on your electric brakes so as not to put any unnecessary strain on them. Took my wife and i about 5 hours to do the job, including getting the new hardware. One of of the most rewarding projects we've done so far!
emelaich01 is offline   Reply With Quote
What should I pay for a left over 2019 25 FC RBT? huck55 2016 - Current Flying Cloud 1 11-17-2019 01:40 PM
2019 26 RBT Transfer Switch Location Too tall Electrical - Systems, Generators, Batteries & Solar 1 10-21-2019 04:12 PM
2019 classic 33 lift kit Djmkcity 2016 - Current Classic (all lengths) 7 11-08-2018 06:36 PM
