06-06-2019, 09:57 PM
#2561
Washington
, Missouri
BW vac Br + ck valve
http://www.airforums.com/forums/f163...ml#post2249662
Parzts have arived...getting ready in a couple of weeks to do the dinette pull and swap out the the vac breaker and check valve...both in brass. No plastic here!
will do pics and notes.
b
06-06-2019, 10:34 PM
#2562
Washington
, Missouri
Soooooo, can't remember if I posted it on this thread or not but a refresher and update.
11/2017 discovered a very slight leak on the rear Fantastic Vent when washing the rig. Thought it was the oven fan outflow since a few drops on the stove cover. Dealer discovered a crack in the FV base flange. I call it a curb flange. Calked and tested all good. to go. Whoaaaa. Cracked? What up? Called FV and they said often at install they are cracked if mfr, over torques with a driver. While the 2 years parts/labor had passed, the 7 year parts was still in play. Seems models have changed from my 6000 series (H6000BTAWH) so no base flange is available....we'll send you a new compete (reversible model) 3350. Well OK!
Called JC re FV's install comment...gave me an hour of good will for the install. Thanks JC!!!
Jumping fwd to the Hee Haw Florida 2019mtour, noticed some condensation on the domes, but attributed it to cold weather and closure and exhale. Cranked the domes up a bit for some flow...all groovey.
Came home...rained for 3 days...went to the rig at storage to clean things out and noticed a 3" puddle in front of the closet drawers. Wiped it up, left a buck where the puddle was...dry for a week even after some precip.
Pulled the garnish (trim) as they call it...two rusted screws and evidence of moisture. Decided to take a few pics of the fwd dome and could see a crack in the flange at the same location of the rear vent's failure.
Called FV/now Dometic (they were great!!). Slight hurdle they wanted me to go to a service center...NONE is OR...pointed out the last was shipped to me directly......found the earlier order and agreed to ship another to me. Labor is mine.
After a closer review at the dealer for a patch (leaving town for a quick trip) I also suspect the caulk failure at the cracked corner. For whatever reason I left the nose down that time and it is usually level to slight up....hence the leak now but not the previous 3 months of very obnoxious weather.
So for the heads up....get up on top and take a good look at your caulking. I don't do ladders anymore so this is now a dealer function.
Fwd FV install set for this Monday. BW vacBr/Ck Valve project after this is in the bag!
For the record, my pic of this fwd vent after the 11/2017 event did not show a crack in the flange. So much for the OEM driver over torque assertion. Clearly this was a crack in the course of OTR. Check the vent flanges OFTEN....maybe a peek under interior trim once in a while. Especially since I saw no evidence of a failure in the waterproofing.
And while you're at it, a very hands on s/annual or annual roof inspection
B
06-07-2019, 05:05 AM
#2563
2013 20' Flying Cloud
Westerly
, Rhode Island
The caulking on every rivet, did your trailer come that way? Ours does not have that, but we do have an insane amount of caulk on the Fantastic Fans. It covers almost the whole flange and an inch or two on to the roof.
06-07-2019, 05:44 AM
#2564
Sag Harbor
, New York
Originally Posted by CruizinDux
Thanks Bob for the two detailed posts. We have the same brass vacuum breaker, as shown earlier in that 2015 thread . . . thanks for your check valve heads up. Simple enough to put inline when the plumbing is re-done.
FEI -- Here is an earlier post about this project, which will lead to other earlier posts. If you keep clicking on the orange arrow in all quotes that pop up, it is easy to follow the trail . . . backwards . . . over the last couple of year. years? Ugh!
Originally Posted by OTRA15
Thank you for that reminder!
PS -- See also Posts #1910 and #1922. Thanks again vandemusser.
Good luck, Bob. Looking forward to your report and guidance.
Peter
PS -- Thanks Darrell for leading the way!
[click on orange arrow to go directly to Post #1604]
Originally Posted by TCwheels
Dinette removed!
06-07-2019, 08:59 AM
#2565
Washington
, Missouri
SC, here is a different angle. The OEM is the darker/ dirtier, tooled at the flange edge, but also on some of the screws. When the rear fan was installed the dealer touched up the fwd fan, they lets say top coated with fresh in a less tooled process.
I also talked to them about the caulk. Last week they touched up the fwd fan sith sikaflex 221 which Lewster recommends as an adhesive and a sealant at seams. He recommends the 715 for roof flashing etc. as it dries a bit more pliable but also is semi self leveling. I'll post that sealants thread later.
Hmm, having trouble on the upload.
B
06-07-2019, 09:36 AM
#2566
Washington
, Missouri
Looks like they touched up the fwd edge and a few screws too at the time of the rear FV install (1-2018)
06-07-2019, 09:44 AM
#2567
Washington
, Missouri
Peter
Peter thx for the recap. I have been bouncing back to previous thread posts.
BTW Sealants thread.
http://www.airforums.com/forums/f456...ry-116214.html I would suggest posts 21, 100 & 198. Post 91 is the most current "recap".
Thanks you TinTin, Lew and all that contributed. This is a great thread that I have saved for reference.
06-11-2019, 03:40 PM
#2568
2018 20' Flying Cloud
Park City
, Utah
Howdy fellow 20-footers!
I'll be joining some friends (in their own AS) full timing and traveling around the US.
Here's a pic of my TV and AS:
Thanks to all who have contributed to this thread. I hope I can add some information as well.
06-11-2019, 06:48 PM
#2569
Washington
, Missouri
Wow, the honor of your first post! Welcome to to 20's thread. Loking forward to your posts. What year is your 20? I can't tell from the avitar area.
Happy trails.
ps, Nice wheels you have there.
06-11-2019, 11:33 PM
#2570
2019 23' International
La Habra
Welcome and of course everyone has something to contribute. How does your Chevy’s diesel work out through out your travels around the country?
2019 GMC Sierra Denali
2019 23CB International
06-12-2019, 07:05 AM
#2572
2016 23' International
Centennial
Welcome to the 20FC group! Glad you could join us
Steve "Centennial Man"
06-12-2019, 10:51 AM
#2573
Park City
, Utah
Thanks for the welcome everyone!
Happy trails.
It's a 2018, bought "used" - it got titled but never picked up from the dealer.
I've only towed from Boise to Salt Lake City so far, and I was quite pleased with the performance of the truck. Only on one very steep grade did it struggle and lost some speed uphill.
06-13-2019, 01:18 PM
#2574
2019 20' Flying Cloud
Bozeman
, SW Montana
Hello fellow 20 footers. The photo above is our new, and I mean new, 20 FB FC. We did a shake down run to Cherry Creek state park right after we got her but the photo is from our “first” real towing and camping trip to Difficult Campground outside Aspen. Great campground BTW. TV is an F150 3.5 which performed without any strain. Looking forward to many more trips this season. I’ve read all the posts in this thread and have learned alot but have tons more to learn.
06-13-2019, 01:57 PM
#2575
Sag Harbor
, New York
Originally Posted by Putemback
I’ve read all the posts in this thread . . .
Welcome to the 20-footer thread!
Sorry for the long road . . .
Thanks for the great photo.
Peter
06-13-2019, 03:45 PM
#2576
Washington
, Missouri
Attachment 343235
I'm impressed! Welcome to the 20's club. I look forward hearing of your adventures. Cherry Creek...sounds familiar ; ) heads up another 20's in the hood
06-13-2019, 08:53 PM
#2577
1956 22' Flying Cloud
Durango
Hello from Durango - we really enjoy our 20’
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
06-14-2019, 07:16 AM
#2578
Sag Harbor
, New York
Hi Ken, thanks for chiming in. Is your 1956 22’ laid out like our FC20’s with front bed and dinette on the street side? Any photos available?
Peter
06-14-2019, 08:03 AM
#2579
Centennial
Welcome Putemback! Glad you are here with us!!
06-14-2019, 08:33 AM
#2580
Durango
Peter
No - the 56 has pretty much the floor plan as the current 19 - bed is in the back corner and dinette in the front - have all kinds of pics - the 56 is a historic trailer - if you happen to have a 1957 National Geographic it’s in there :-) #50 - I have to say they have made many improvements since 1956 - we love our 2015 20’
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
