Old 04-11-2016, 05:36 PM   #729
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
Originally Posted by subfan1 View Post
Great subject guys since I've been thinking about how to keep the door partially opened to keep some air circulating. While dry camping I usually leave the upper vent door opened. In order to not mark up the side of the trailer I cut a short piece of clear vinyl tubing sliced it up the middle and attach it to the latch and remove it store it in the lower door wire harness. Now the entrance door. I read that the first 3 25 FB model trailers had the entrance door hinged opposite of how they are hinged now. Brian uploaded a picture of a latch that you could buy from Airstream and it kept the door partially opened. I thought it was a great solution to my problem. I can't seem to find the picture though. I'll try looking for it so I can post it here.
Thanks Subfan1. I like the vinyl tubing idea to protect the skin. I use the foam in the door hinge to keep open a bit more, but this option is subject to winds and it would be nice to be able open fan door all the way up and latch the door opened as designed. The AS door should keep all in place. I'm thinking that even with the door latched open and the resulting limited flow with the fan door up all the way, it all should still contribute to cooling effeciency.
CruizinDux is offline   Reply With Quote
Old 04-11-2016, 05:37 PM   #730
CruizinDux's Avatar
Thanks Subfan1. I like the vinyl tubing idea to protect the skin. I use the foam in the door hinge to keep open a bit more, but this option is subject to winds and it would be nice to be able open fan door all the way up and latch the door opened as designed. The AS door should keep all in place. I'm thinking that even with the door latched open and the resulting limited flow with the fan door up all the way, it all should still contribute to cooling efficiency.
Old 04-11-2016, 05:44 PM   #731
Long Island , New York
Sounds good Bob.
Update on the wheel well gaps showing plywood sub-floor -- yup, same deal in four spots -- interior face of wheel well on top of frame -- front and back corners on both curb and street sides -- some worse than others.
Will use WEST epoxy to seal the plywood as best as I can working upside down against gravity. Apply epoxy liberally and immediately cover with duct tape as tight as possible. Let harden.
Remove duct tape, mask off 4 small areas to be sprayed with can of spray bed liner (just got it at the auto parts store), and consider taking trailer to shop for entire wheel well to get bed liner, including the gaps between the wheel well sheet metal and the trailer's frame, as identified by subfan1 (which I also have here and there, inconsistently you will be surprised to know . . . sorry . . . can't help myself . . . )
Never a dull moment -- tomorrow summerize?
Cheers,
Peter
Old 04-11-2016, 07:35 PM   #732
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
Peter would it be better to use blue painters tape rather than duck tape? I know the painters tape won't stick to almost anything.
subfan1 is offline   Reply With Quote
Old 04-11-2016, 07:45 PM   #733
The blue tape tears too easily. I want to tug on the tape to get it as tight to the recessed opening as possible. Duct tape is good for this plus will stick to sheet metal and frame easily. Once the epoxy hardens, a little tape residue won't defeat the adhesion of the bed liner, I think . . . hope . . .
Old 04-11-2016, 08:17 PM   #734
TahoeStream'n
subfan1's Avatar
Good luck. If you could take pictures of the wheel well post spray, I'd appreciate it. I think I'm doing this too.
Thx
Old 04-11-2016, 08:37 PM   #735
Will do, however the areas of spray will be limited because I don't want to have to take the tires off right now, as would have to be done if a shop sprays bed liner inside the entire wheel well. Just want to eliminate plywood edge grain being exposed to road water.
Old 04-11-2016, 08:44 PM   #736
TahoeStream'n
subfan1's Avatar
Oh OK, I was thinking of removing the tires when I do ours. Maybe I'll take the pictures. If anyone is interested?
Old 04-11-2016, 08:56 PM   #737
Makes sense to do the entire wheel well, especially given that the interior of the trailer should be quieter going down the road!
[ What is the sound a quieter Flying Cloud makes when there is no one inside to hear the difference? ]
Old 04-11-2016, 10:51 PM   #738
CruizinDux's Avatar
Holy Moly, Not looking for more work but this is an open door got more extensive work. I think I'll swing by for an eval and will bring the camera.
Time to be proactive.
Old 04-12-2016, 02:10 AM   #739
Of course, Bob, I guess one could leave the duct tape in place, eh, and end up with
CruizinDuctsTape?
Let us know what you find on your unit . . .
Old 04-12-2016, 08:18 PM   #740
2016 20' Flying Cloud
Somewhere , Texas
Arizona, take off your rainbow shades
Arizona, have another look at the world
My myyy
Arizona, cut off your Indian braids
Arizona, hey won'tcha go my way
VinnyBoomer is offline   Reply With Quote
Old 04-12-2016, 11:41 PM   #741
CruizinDux's Avatar
CruizinDuctsTape?
https://www.duckbrand.com/products/duck-tape/colors
what else would one expect...green, yellow and of course tie dye
and I just noticed...glow in the dark
also available in shelf paper for the RV
will do on the eval
Old 04-13-2016, 03:31 AM   #742
Not sure if you're ready for this one!
https://www.duckbrand.com/products/d...188-in-x-10-yd
Prices on 34 Footers ElCamino Man Trailer Values 21 01-23-2014 04:56 PM
1970s vintage type 30+ footers silversails Airstream History 6 07-22-2010 06:58 AM
31 and 34 footers a thing of the past. yakman Off Topic Forum 23 08-02-2009 11:05 PM
frame layout for 18-footers greenrig Repairing/Replacing Floor &/or Frame 2 08-19-2008 12:06 AM
What about the 74' 28 footers? stinkytwinky All Argosy Trailers 10 08-22-2005 07:30 PM
