07-27-2019, 01:44 PM
#2641
Washington
, Missouri
Originally Posted by TCwheels
I added the push button lock to the pantry door thereby eliminating the need to bungee. For us, the only door or drawer that fell open during travel was the pantry.
Darrell,i assume you removed the oem latch? This was my solution but my wife hates it. It was on my garden bench looking for a home. I use it in the hooked position. Fingers are hard to work the spring latch for the lock position. Thinking of other options. Can you post a pic. Push button lock makes me think of a entry lock??
FWIW, i just noticed that the racks just hand on a little hook of the slider. Opened the door to see the far end of the top rack hanging loose. Couple of small zip ties now keeps it place. Need to do the bottom too.
I used the rev-a-lock on the pot/pan drawer and all is groovey. I have gone the bungee route on the refer tho. What ever works.
Post 20. http://www.airforums.com/forums/f240...-161467-2.html
B
07-27-2019, 02:05 PM
#2642
Sag Harbor
, New York
A note for the record from the chief bungee advocate. KISS -- they still work great!
Have a good weekend.
Peter
[click on orange arrow to see the full Post #1101 and all photos]
Originally Posted by OTRA15
Here you go. I changed the plan a bit and eliminated the long bungee.
A disclaimer first -- I don't mind exposed hardware if the finish and design are good. Form follows function . . .
So the exposed stainless strap eyes may not appeal to some folks, but on their own they are preferable to exposed bases for white Velcro, and coachman's loops (if I understood that post correctly). The top eye near the sinks is also actually good for the corner of a thin hand/dish towel. Different strokes for different folks . . .
08-30-2019, 11:25 AM
#2643
2018 20' Flying Cloud
Park City
, Utah
Can anyone check if their rear dinette bench has an angle bracket attaching the back to the streetside inner skin?
Mine does not (the front bench does)
Front:
Rear:
Thanks to anyone who can help - a picture would be amazing as well!
08-30-2019, 12:51 PM
#2644
Sag Harbor
, New York
Yes we have a mirror image of the angle bracket on the front bench seat.
Peter
08-30-2019, 03:45 PM
#2645
Washington
, Missouri
Peter
X2
b
08-30-2019, 04:41 PM
#2646
Sag Harbor
, New York
Bob are you still going to Maine?
We are going to try to squeeze into Hither Hills on Tuesday off the wait list. Iffy forecast for next week . . . hopefully some folks will bail out, plus schools start next week. HHSP is super crowded this time of year but a 2-3 day stay is often do-able midweek. TBD.
Peter
08-30-2019, 06:33 PM
#2647
Washington
, Missouri
Peter
yup
09-01-2019, 09:07 AM
#2648
Sag Harbor
, New York
Thanks for the PM, Bob.
Happy Trails!
Peter
09-05-2019, 09:31 AM
#2649
Park City
, Utah
Peter
Originally Posted by CruizinDux
X2
b
Thank you! Looks like I'll be adding that to the "next time I'm by a dealer" list.
10-27-2019, 11:41 AM
#2650
Cary
, NC
No outlet power when plugged into 30AMP
Love the chain!
I bought a 19' my first year on the road, because I couldn't find a 20' that I really wanted. YES, it is the kitchen, double sink, lots of counter space, great shower and just love this floor plan. I found a used 2014 the following year and this is my 3rd year in Ms. Scout.
I am having a very strange problem. When plugged into 30 AMP, my outlets don't work. I have lights but no outlets or microwave. Any ideas?
10-27-2019, 11:46 AM
#2651
Sag Harbor
, New York
Did you check the 120-volt circuit breakers, some of which may also require a GFI reset [on the breaker, or on one of the outlets]?
Do your fridge and water heater work on shore power? [propane off]
Your interior lights do not work off the 120-volt shore power. They are supplied with 12-volt direct current from the batteries. You might want to review your owner's manual about all the electric IMO.
Peter
10-27-2019, 11:49 AM
#2652
Cary
, NC
I love my 2014, 20' Flying Cloud. Does anyone else have the problem of excessive shake rattle and roll? WOW! When I open the door after 2 hours on the road, everything has shifted and shaked. I keep my tire pressure at 80 PSI. But stuff just flyes everywhere!
Especially, the drawers opening even when I have used a bungee cord to lock them in place.
10-27-2019, 12:12 PM
#2653
2013 20' Flying Cloud
Westerly
, Rhode Island
Assuming you have Goodyear Endurance E rated tires, stock size, even at the trailers GVWR of 5000 lbs. you can run 75 psi and still have the 10% safety margin that the forum tire experts recommend. Our trailer's axle weighs in at 4600 lbs. with a full tank of water. At 4600 lbs. I could go down to 65 psi. if I wanted to, but I run 70-72 psi and it doesn't seem to abuse the trailer.
10-27-2019, 12:18 PM
#2654
1986 31' Sovereign
Miami
Umm, I think perhaps your tire pressure is the culprit. At 80 psi, your tires are essentially the same as those on Fred Flinstone’s car — rock solid.
You may want to weigh your trailer and then consult the inflation guide published by the tire manufacturer for your tires.
I have Goodyear Endurance. Max pressure (for max load) is 80 psi. For my trailer’s weight, the appropriate pressure is 65 psi, which is what I run. I don’t have any symptoms of harsh ride...
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
10-27-2019, 02:31 PM
#2655
Washington
, Missouri
Same here almost. I'm a few lbs more give or take...with the 2 bikes usually, but half tank water. Full tank prop plus a partial since it lasts forever. I target 75 but don't top off if it reads 72. Somethings me across a hot desert i keep it closer to but less than 80.
Hardly ever have to add air..holds psi firm. Just passed 35k miles since new 2/2018
10-28-2019, 06:07 AM
#2656
2016 23' International
Centennial
Do any of you put your 20FC up on jacks for winter storage, to take the weight off the tires? I put new GYE's on this summer and the only got to camp one time because of a sick parent. The Airstream has been sitting in the same spot for several months.
Steve "Centennial Man"
10-28-2019, 06:53 AM
#2657
2018 25' International
naperville
X2
b
Yup...I have same= brackets on both.
Taking a page from TCWheels I am reupholstering the dinet. I'll post before and after....doing it myself so a little slow at it.
Going from orange cloth to ultraleather tan for the base and dungaree blue for the seats...very hyped on the update
10-28-2019, 07:58 AM
#2658
Cary
, NC
Thx, i’ll Reduce to 75 psi and see if things stay put.
10-28-2019, 10:14 PM
#2659
Sag Harbor
, New York
Sorry to hear about your parent. Been there . . . no fun.
We just move the trailer 2-3' every month or two. Not sure about tires "going flat" but moving once in a while can't hurt. IMO modern radial tires are made of a better compound than in the old days of bias-belted tires. Even a short trip to nowhere of 5-10 miles exercises the tires, and is better than sitting still.
Just a lay opinion -- FWIW.
Good luck, Steve.
Peter
PS -- Our van tow vehicle is supposed to be back from the body shop any day now, after a reckless driver ran a stop sign, and clipped the back of the van ~6 weeks ago. Planning on going to dump the tanks at a local CG, for a R/T of about 15 miles.
10-29-2019, 05:56 AM
#2660
Centennial
Good idea Peter! We are already getting substantial snow here, so, hooking it up and taking a short trip around the neighborhood probably won't work but I can move it up and down the driveway with my trailer mover when some of the snow melts off. Thanks for the idea!
