10-11-2018, 09:43 PM
#2381
Washington
, Missouri
Originally Posted by OTRA15
Steve, if I understood Lynn's comment correctly, takes his antenna output to the Satellite connection on the rear street side, and then picks up this signal inside with another cable to the Weboost base unit. His second photo shows this elegant solution IMO.
I am pretty sure our 2014 FC20 has the same twin ports back there [CATV and Satellite TV].
Nice!
Peter
Yes and agreed
10-11-2018, 09:44 PM
#2382
Washington
, Missouri
Originally Posted by lynnsr
Peter
The base unit that I purchased which includes the top part of the antenna you see in the pictures was a WeBoost Drive 4G-X RV.
The ground plane and the flagpole attachment to that antenna, I made myself.
A flat to metal ground plane comes with the kit however I felt was inappropriate, stuck 20 foot in the air with the wind.
If you would like I can get you additional information on exactly what I made.
Lynn Senior
Lynn, I'd appreciate and info pics drawings.
b
10-12-2018, 01:19 AM
#2384
Sag Harbor
, New York
Originally Posted by Rovin Raven
Has anyone tried to replace the screen on the windows by the dinette? Seems easy until you realize the cabinets are about an inch lower than the top bead of the screen and it takes some magic to get the bead in. A screen bead roller won’t work. Fingers don’t work. Any ideas?
Plz see my reply in your new thread, which will bring many non-20-footer replies IMO.
Peter
Originally Posted by CruizinDux
http://www.airforums.com/forums/f516...ts-188178.html
Welcome back Bob and thanks for the follow-up. Seeing SpaceX must have been far out!
Peter
10-12-2018, 11:10 AM
#2385
Washington
, Missouri
Gotchya thanks.
Yup...as the small dot started to seemingly explode and continue to build, you could hear whoops and hollers in the neighborhood. I wasn't expecting the show that followed.
10-12-2018, 11:15 AM
#2386
Washington
, Missouri
Jacking plate
followup post 2307
http://www.airforums.com/forums/f542...ml#post2137040
can anyone help with this image?
As for the ele recall (ele system; "...power inlet receptacles not property tightened..."), seems I discussed this with the dealer when the propane tray recall was discovered/discussed but don't have paperwork. I'll request the clearance when I have the above propane line relocated.
b
10-12-2018, 09:28 PM
#2387
2019 23' International
La Habra
Hi we were in Palm Springs for the launch
[ATTACH]
2019 GMC Sierra Denali
2019 23CB International
10-12-2018, 09:35 PM
#2388
2007 22' International CCD
Corona
Saw a similar one while driving down the Cajon pass from Victorville to Anaheim. Great photo!
10-13-2018, 12:26 PM
#2389
Lynnsr
2018 20' Flying Cloud
Colorado Springs
b
I have all of that around, I'll try to get that put together this week end.
LynnSr
10-19-2018, 03:36 PM
#2390
Lynnsr
Colorado Springs
My We Boost Antenna
Well the week end passed......... I finally got some time and here are my Pictures.
LynnSr
10-19-2018, 03:58 PM
#2391
Washington
, Missouri
LynnSr
Lynn, you're awesome and very organized as well. thanks for the details.
10-19-2018, 05:45 PM
#2392
Washington
, Missouri
Originally Posted by centennialman
Thanks Lynnsr.....I thought that the "tunnel" was probably open. I run a space heater in the winter to keep things warm and imagine that some of it gets back into the trunk as well, since that is an opening
For the bathroom alu trim, i swapped t-nuts and a #10 ??? threaded bolt for the screws so (jc wasted the meat for their alu install and screws simply have nothing to screw into) i could remove it easily in the winter to allow some warm air in that critical area. The WH compartment under the setee puts outs out an enormous amount of heat. I'm thinking off setting the old refer fan connected to a 12vdc male plug (that i currently use to vent hot air from the TV for the dogs when parked), to maybe push some of that WH heat thru the floor channel to that toilet/vanity opening. Same thought in the rear compartment as i'm picking up another recycled fan for the dogs for higher exhaust flow in the tv.
Obviously this is for really cold weather, but last year we got surprised at lake wallowa pushing the bottom of the 20's.
As an aside, I noticed some water dripping from the belly just inboard of the dump valves. Holy @#$% batman😂. However since the above mentioned panel had not been reinstalled, i reached under and up to the fw and bw check valve connections and discovered the insulation soaked and i could put at least a half turn to both the connections. So...just a heads up. Those connections, not really able to be tightened by exterior removal, can be with some difficulty tightened from the wall cavity side...small hand really helps as it's a one finger process. Watch for sharp alu.
Now that panel comes off/on so easily, i tend to check them more often.
B
10-19-2018, 06:00 PM
#2393
2013 20' Flying Cloud
Westerly
, Rhode Island
B
I'm having trouble figuring out which panel you are talking about.
10-19-2018, 08:42 PM
#2394
Washington
, Missouri
SC, panel is probably not as accurate as alu cover. I have an alu two sided that is behind/to the right of the toilet. 2 screws attach it to the vanity and the 3rd to the white platform that the toilet is attached to. The toilet supply line comes out from under the alu. Just before the shut off. If you remove this you'll first see the sloped abs vent or maybe the sink waste pipe, then a ton of pex going eery which way. This is where the fw comes in, the bw inlet/check connects and exterior shower backside. Put a camera in or look back for Darrel's/ TC's posts when he removed the settee for new covers. Seems Camano was in the area soon after tc, but to replace his bw backflow check valve. Seems both posted images.
Hope this helps. Let me know.
B
10-20-2018, 07:36 AM
#2395
2016 23' International
Centennial
LynnSr....nice hookup of the WeBoost!! Thanks for sharing. I ended up running my cable through a hole I drilled in the window frame up front and installing the booster next to the magazine rack by the bed. Then, I ran the cable under the bed and over to the dinette by the wall. I really like your set up. Oh...and is that a springer? I have one of those too!
Steve "Centennial Man"
10-20-2018, 11:54 AM
#2396
Washington
, Missouri
correction
.... i reached under and up to the fw and bw check valve connections and discovered the insulation soaked and i could put at least a half turn to both the connections. So...just a heads up. Those connections, not really able to be tightened by exterior removal, can be with some difficulty tightened from the wall cavity side...small hand really helps as it's a one finger process. Watch for sharp alu.
B[/QUOTE]
oooops, check that, not FW.....CW connection on the side
10-21-2018, 08:45 AM
#2397
2017 27' Flying Cloud
Fort Worth
LynnSr
Hi Lynn,
Great posts...thank you very much! So, just to confirm, you made the ground plane adapter and the base that you attached to the Airstream vs. buying them commercially? If so, I certainly don’t have your metal fabrication skills!
Also, dumb question, but what does the ground plane do and is it required? I don’t see that on the installations that I have run into at campsites.
Bill
10-22-2018, 11:59 PM
#2398
2012 20' Flying Cloud
Los Osos
Fresh water sterilization
I searched for the topic, but couldn't find it.
Can anyone point me to the procedure for sterilizing the water system with bleach in our 20 footers?
Thanks, Tom
11-05-2018, 06:17 AM
#2400
2019 25' International
Traverse City
, Michigan
20-footers
As an aside, I noticed some water dripping from the belly just inboard of the dump valves. Holy @#$% batman[emoji23]. However since the above mentioned panel had not been reinstalled, i reached under and up to the fw and bw check valve connections and discovered the insulation soaked and i could put at least a half turn to both the connections. So...just a heads up. Those connections, not really able to be tightened by exterior removal, can be with some difficulty tightened from the wall cavity side...small hand really helps as it's a one finger process. Watch for sharp alu.
B
Great ideas! I’m going to do both. Forehead smack on the alum tunnel attachment mod with bolts and t-nuts. I’ve tightened those dumb screws 100 times if I’ve done it once...
"Don't let perfect be the enemy of better."
