Old 04-23-2019, 12:48 PM   #1
mikeinca's Avatar
2018 30' Classic
Santa Rosa , California
Which AC is which?
I have a 40 AMP circuit in my garage that I'd like to use to run the AC on our 2018 30' RB Twin Classic when it's in "port". I realize that I shouldn't run both AC units at the same time on 40 AMPS but I'd like to run the larger 15,000 BTU unit. On my trailer, which AC is 15K BTU and which is 13.5K? It seems like it would be useful to know in any event.
Maybe the answer is out there already but I've done a search and haven't been able to find a definitive one. I'd rather not climb on the roof to find out if I don't have to.
“The good thing about science is that it's true whether or not you believe in it.”
― Neil deGrasse Tyson
2018 30' Classic Twin
2017 F250 4x4 6.7 max tow Platinum
200W portable solar
240Ah LifePo4 upgrade
mikeinca is offline   Reply With Quote
Old 04-23-2019, 12:53 PM   #2
2007 22' International CCD
Which AC is which?
Most air conditioners have a nameplate accessible behind the vent grill that would give the data you need.
Old 04-23-2019, 02:05 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
You can safely run either AC unit on a 30A hookup at a campsite. Their current draw and performance are so close as to pretty much not matter. In fact, if you *happen* to ... errrr...run a controlled experiment , it turns out you can run *both* AC's on a 30A hookup. Don't ask how I found this out .....
I believe the "typical" configuration is to put the larger unit over the living area and the smaller over the sleeping section. It's AS, so trust very little, and verify everything .
Old 04-23-2019, 02:54 PM   #4
mikeinca's Avatar
2018 30' Classic
Bingo! You were both correct. I found the tags with a flashlight and removed the grills so I could read them. The larger 15K BTU unit is indeed over the living area at the front with a 13.5K unit at the rear....on my AS Classic at least!
Thanks!
200W portable solar
Old 04-23-2019, 03:48 PM   #5
2018 28' International
Fayetteville , Georgia
On my Serenity 28, the front (living) area is the larger 15K unit, and is # 2 on the thermostat. The rear (bedroom) is the 13.5K unit, and is # 1 on the thermostat.
You will not run two A/C’s on a 30 amp plug for long...
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 04-24-2019, 06:26 AM   #6
Half a Rivet Short
Hi
You can do it for longer than you might think ..... (hours).
Old 04-24-2019, 06:55 AM   #7
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
You can run both with a 30a, but be advised that there **is** the **possibility** that long term damage (read years) could prematurely reduce the life of the compressors if they cycle at the same time. I mean if you are running both A/C units in your garage, you are prob either in the trailer with other things turned on, or you have more on than just the A/C unit(s) on in general (fridge may come to mind, TV or stereo too). There is a reason they put 50a on the rig and if it were my rig, I would run one or the other if I was connected to a 30a. 40a, I've never seen, only 30 and 50, so could your 40 be a 30? If so, that's my advice. If your 40 is a 50, then you can run it all day long so long as the power supplier and circuit are providing ample power (no brownouts or surges).
If your garage already has a 30, 50 is not a major jump in cable gauge size and breaker. There are calculators on-line that can easily tell you if the cable in your garage setup is aqueduct for the length of the cable run (30 or 50a). This is a major variable that can't easily be given a thumbs up or down on on a forum without knowing the cabling infrastructure. I went through this excercise about 7 years ago when putting in an EV charger for my car. Power decreases with distance, requiring larger cable.
This is a fair one I've used in the past:
https://www.electricaltechnology.org...alculator.html
Old 04-24-2019, 08:34 AM   #8
Mollysdad's Avatar
Living area is 15 and bedroom is 13.5
Old 04-24-2019, 08:20 PM   #9
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
If you want to run both A/Cs at the same time on a regular basis you need MicroAir's SoftStarts on them. You would be amazed at how this computerized start/run system really improves the situation. Low amperage starts, no more jolting to a stop and smooth quiet running. Plus much longer motor life. I'm on my 15th season with no trouble yet.
guskmg
Old 04-25-2019, 08:03 AM   #10
Half a Rivet Short
Hi
I'm by no means suggesting that running them both on 30A is a good idea. It's not a good idea. The point is that you *can* do it if the one who plugs in the trailer does not keep track of what the one who turns on the A/C's is doing ....
Univolt internals - which fuse is which? barts Batteries, Univolts, Converters & Inverters 9 08-13-2017 09:18 AM
Heating and Air Cond. - Which wires are which? trekerboy Electrical - Systems, Generators, Batteries & Solar 12 08-09-2015 08:37 AM
Dump Valves Which is back and which is grey? clicker187 Waste Systems, Tanks & Totes 7 01-16-2013 08:15 PM
Which tank is which? dejahardy13 Fresh Water Systems 8 09-24-2010 09:23 PM
Which switch is which or what 74Sovereign Electrical - Systems, Generators, Batteries & Solar 6 09-10-2002 08:55 AM
