Old 05-31-2019, 08:48 PM   #1
2019 30' Classic
Pleasant Garden , North Carolina
Water pump question
While camping last weekend we tried to use our water pump to increase water pressure when showering. Went to the Czone panel and turned on the water pump but saw no difference. Disconnected city water and discovered that our water pump wasn't working. Any suggestions what to check first?
jlandreth is offline   Reply With Quote
Old 05-31-2019, 09:14 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Make sure the switches for the pump are in the on position.
Check that all of the wires are connected to the pump or to each other (complete circuit).
Use a meter to check for 12v DC power at the pump.
If there is power at the pump, start looking at the pump components (pressure switch, etc)
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 05-31-2019, 11:47 PM   #3
2018 25' Flying Cloud
Portland , Oregon
If by not working you mean you hear it come on but little water flows that could just be it needs to prime itself. That can take quite a while, it takes ours ten minutes sometimes.
daleyocum is online now   Reply With Quote
Old 05-31-2019, 11:53 PM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
This may sound stupid, but
Hi, this may sound stupid, but it has been admitted on this forum several times. Is there any water in the fresh water tank? [and don't trust the tank monitor, they lie]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-01-2019, 05:04 AM   #5
Long Island , New York
Good suggestions so far. Is there water in your tank, and have you ever used the pump? If you can solve the apparent lack of 12-volt electric to the pump, be sure to open all the hot and cold faucets when you start the pump, until all air is out of the system. [incl. outdoor shower].
Good luck,
Peter
PS -- Check your 12-volt distribution panel and the circuit breakers for a tripped CB to the pump. Also . . . consult your owner's manual's troubleshooting section in the back of the book.
OTRA15 is online now   Reply With Quote
Old 06-01-2019, 05:51 AM   #6
2019 30' Classic
Appreciate the suggestions. Water tank is full, opened all the faucets but don't hear the pump come on. It is the first time I have tried to use it. I will check connections this morning.
Old 06-01-2019, 06:27 AM   #7
Gainesville , Florida
Is the switch on if it has one!?
Old 06-01-2019, 06:35 AM   #8
2019 30' Classic
Update. This morning cut everything off in the trailer then turned the pump on at the Czone panel. I opened up all the faucets. I can hear the pump running but nothing comes out of any location. Is there a valve on the Classic that needs to be opened?
Old 06-01-2019, 06:43 AM   #9
Thanks for the updates.
Progress!
You might have an air leak at the plumbing connections at the pump, so you will have to find it to check them. I seem to recall that your Classic pump is buried somewhere, and will look for relevant posts when I get back home later. Look at the list of topics in this sub-forum, and you will probably find a recent thread on point.
BTW, you have to open ALL faucets hot and cold incl. exterior shower to get all air out of system to help the pump get its prime.
Oh . . . any chance your AS was winterized and the hose from the water tank to the pump was never connected again? Also there may be a winterizing feed for antifreeze at the pump which needs to be adjusted?
In any event, find the pump is the next step IMO.
Good luck,
Peter
PS — Did you reverse your Winterization?
http://www.airforums.com/forums/f540...ze-192665.html
Old 06-01-2019, 07:05 AM   #10
2019 30' Classic
Thanks Peter, I will try to find the pump. I did reverse the winterization. I also had to winterize again after we used it the first time because we had about a week of sub freezing weather after our first trip. Btw, all faucets were open with the pump running but no water appeared.
Old 06-01-2019, 07:37 AM   #11
2019 30' Classic
Problem solved. When I dewinterized I neglected to turn the winterization valve at the pump back to normal use position. Works as it should, sorry for wasting everyone's time.
Old 06-01-2019, 08:49 AM   #12
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Not a waste of time at all. Others can learn on the tuition each of us pays to the school of hard knocks. All good - glad you got it sorted out!
Old 06-01-2019, 10:18 AM   #13
Thats how we learn!
Old 06-01-2019, 11:30 AM   #14
All good . . . no worries.
OTRA! [On The Road Again!]
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Pump in RV Antifreeze Downstream from the Water Pump? KJRitchie Winterizing, Storage, Carports & Covers 6 01-09-2015 01:18 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
