Old 08-05-2017, 08:49 AM   #1
2018 30' Classic
New York , New York
Water/Hot Water 2018 Classic
We took delivery of our 2018 30' Classic yesterday. We are experiencing some issues using water and hot water. It certainly could be a newbie user issue.
We are connected to city water and electric. The trailer had a full tank of fresh water on delivery. We connected to city water and it is showing 40 psi of pressure on the regulator. To get enough pressure, we have the water pump also running. Is this normal/acceptable?
We have turned on the water heater. (The first time, it tripped the breaker at the pole because one of the AC units was running.) This morning we tried water heater again and actually added the shower boost and we are only getting seconds of warmish water in the sink faucet. Is there something we are doing wrong?
All advice welcome!
ajwbarnard is offline   Reply With Quote
Old 08-05-2017, 11:25 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You don't need the pump on when you are on city water.
Did you make sure the water heater was full before turning it on? Otherwise you may have fried the heating element.
Was the coach winterized when you took delivery?
Old 08-05-2017, 12:15 PM   #3
mojoe7009's Avatar
Green Cove Springs , Florida
All advice welcome!
The shower boost takes about 15 to 20 minutes to get the water temperature up to 149 to 151 degrees. I thought the 2018's had the new Alde on demand system? Ours is a 2017. There is a great thread on the forum called "Much Ado About Alde". Search for that and you will find many answers. Things are different on the 17's and 18's and most of that thread will be referring to the 17's, but it will still help understanding the system better. We have a separate Alde Control Panel and my understanding is that your Alde controls are integrated in your Firefly panel.
Not sure but if you're water pump is on you might be pulling from your fresh water tank. Also, if you added an inline pressure regulator outside you are reducing your pressure significantly since the trailer has a built in water pressure regulator.
Breathe In, Breathe Out, Move On
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 2500 Limited CC 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
mojoe7009 is offline   Reply With Quote
Old 08-05-2017, 01:46 PM   #4
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Water and power basics:
The pressure into the regulator should be up around 50 pounds or so. Coming out, anything over 30 pounds should be "good enough. My guess is that you are running through a really long hose and that is giving you a pressure issue. A typical hose run is < 25 feet.
Running both the pump and city water is not a real good idea. It should be an either / or kind of thing.
The "old" Alde system had two electric heaters and one LP driven heater. To get it rip roaring hot you turned on all three.
At the sink (on the older system), the normal "hot water" is what I would call very warm water. Without the shower boost it's not what I would call hot. How hot it gets is adjustable. One dealer likely sets it different than the next. Since it's a mix valve, very cold city water will give you "colder" hot water. Hotter hot water used to mean you got less of it before it died.
The 30' Classic is quite capable of tripping a 30A breaker running one AC unit. You *do* have to watch what you have turned on. When hooked up to a "50A" system, you have 100A of 120V available.(yes, it's confusing). That's what the trailer was designed for.
Old 08-06-2017, 04:15 AM   #5
paiceman's Avatar
Some City , Somewhere
When we are connected to 30amp, just to be sure, we only run the rear AC, which is the 13.5 AC. We also do not generally run the microwave when the AC is on. When connected to 50amp we "let her rip".
As others have said we understand that the 2018 has continuous hot water, so to speak, and therefore your flow should not be intermittent. If your trailer has the same Kohler handle and shower head our 2017 does there is an anti scald device on the Kohler handle I disconnected on our unit and now with the 2017 we get more than enough continuous hot water for two fairly long showers ie enough for my wife to wash her hair and our two regular showers. Also, as suggested I'd read every post in the "much ado about Alde" in these forums. It should answer a lot of your questions.
Bud
SAFE TRAVELS
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 08-06-2017, 04:15 AM   #6
mojoe7009's Avatar
Hi
According to the Alde manual if you are hooked to shore power and turn on the gas as well, the system will prioritize the electric and not use the gas. That has been my experience. We had major hot water issues after delivery like many others with 2017's. We tried everything including having the electric and gas on at the same time. It will use the electric and not the gas...at least in our unit.
Kudos go to Jon at Airstream and the service team at JC. They stuck with me and went out of there way to get the system working correctly. We now have plenty of hot water when hooked to shore power.
Old 08-06-2017, 10:29 AM   #7
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Depending on the city water, I used to turn on the pump during showers for a higher flowrate.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 08-06-2017, 12:47 PM   #8
Titusville , Florida
AJ....better or worse today?
Lauri
kendrick.l.j is offline   Reply With Quote
Old 08-06-2017, 01:05 PM   #9
Obviously-NOT
Kalispell , Montana
AJ, a quick look at your owners manual and the Alde phone app gives no clues, actually less than the 17 Alde. If your model number, 3020?, might be able to read manual at Alde website.
Old 08-06-2017, 02:51 PM   #10
Half a Rivet Short
Hi
One obscure thing to check: Is your glycol fluid level up where it should be? There may be interactions between an "air filled" glycol chamber and the water heater. I'd *hope* the days of un-filled heating systems are behind us. Some issues do go on and on ..... Details on how to check the fluid system are all in the previously mentioned thread. Hopefully the 2018 is close enough to a 2017 for them to apply.
Old 08-06-2017, 06:38 PM   #11
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
After reading a number of issues about the OEM pressure regulator, I continue to use my Valtera regulator which is set for 50-55 P.S.I.
It not only ensures that the supplied regulator is working in a safer pressure zone; it also protects the hose from bursting due to campground overpressures.
My main sink was not giving much flow, so I removed the aeriator from the faucet. Much better flow.
Another thing to check, is that the outside shower taps are fully closed. They can bypass hot and cold water, giving warm.
MelGoddard is offline   Reply With Quote
Old 08-06-2017, 06:51 PM   #12
Hi
GLYCOL??? in Water system????
DEADLY COMBO!
REALLY, REALLY FLUSH IT OUT!!
OR PAY THE FUNERAL COSTS!!
Old 08-06-2017, 06:58 PM   #13
Mel, relax. We are talking about the 17 and 18 Classics OnLY. These two models have radiant heat systems that no other units have. At least none that I know of...they use a special glycol based product. That is what Bob was talking about.
Lauri
Old 08-06-2017, 07:22 PM   #14
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Somewhat like the hot water/glycol base board heating of the 70s, except there is a heater with circulating pump for the fluid in the tubing.
Hopefully no leaks ever develop.
But wait, it is an Airstream......
Towing 2018 33' Classic gbstats Towing, Tow Vehicles & Hitches 53 07-30-2017 04:56 AM
2018 Classic 30 and my experience Paratus 2016 - Current Classic (all lengths) 34 07-09-2017 08:58 AM
When to order a new Classic 30 (2017 or 2018) cetanorak 2016 - Current Classic (all lengths) 10 06-19-2017 07:56 PM
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 01:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
