Old 06-01-2016, 12:28 PM   #1
2016 30' Classic
Gilbert , Arizona
Water Heater Light
I took delivery of a new 2016 Classic 10 days ago and everything seems to be working fine with the exception of a red water heater light that has come on three times. I have found that if I shut off the water heater and let it sit for a few hours I can restart and the light will not come on for 2-3 days. The light comes on whether I am using propane or electrical power. Any ideas??
holmesaz is offline   Reply With Quote
Old 06-01-2016, 01:30 PM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I assume you are speaking of the red light on the propane on/off switch.
This light is more of a fault indicator than anything.
It should light momentarily when one switches on the propane system and then go dark. If the water heater lights and is burning, the lamp will stay off.
If the water heater fails to ignite or quits burning(perhaps runs out of propane) at some point before the water gets hot, it will light to indicate a fault.
It has nothing to do with the electric operation of the water heater.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Water heater - pilot light wont light africaroots LP Gas, Piping, Tanks & Regulators 18 08-06-2012 04:14 PM
Black Water Light Indicator & Water Heater problems SGM ADAMS General Repair Forum 9 04-17-2012 06:18 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 08:01 PM
Pilot light works, but heater does not seem to light FLYNCLD Water Heaters, Filters & Pumps 6 06-13-2009 09:57 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 08:17 AM
