12-31-2018, 11:14 AM
2018 30' Classic
Traverse City
, Michigan
Water Filter, Softener, Regulator
We have a 2018 Classic. Getting ready to hook-up a new water softener. What is the recommended sequence for using filter, softener, and regulator?
Motorhomes were our choice for 40 years and decided to get rid of the stress and experience more flexibility in travel.
2018 30’ Classic
12-31-2018, 12:22 PM
2018 25' International
Mound
I use pressure regulator, sediment filter, water softener in that order.
12-31-2018, 01:26 PM
2016 27' International
Sherwood Park
, Alberta
+1. Pressure regulator, filter, softener, in that order.
12-31-2018, 02:34 PM
2019 30' Classic
Canfield
, Ohio
That the order I go also.
The softener will change your life! Just love the quality of the water we have now. Just remember if you are also filling your freshwater tank to use the softener.
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
01-01-2019, 09:11 AM
National City
Which water softener are you guys using?
01-01-2019, 06:26 PM
2019 30' Classic
Canfield
, Ohio
Tom & Doty
01-01-2019, 07:54 PM
Overland Adventurer
2009 34' Panamerica
Telluride
On the go brand softener.
01-01-2019, 08:32 PM
2022 25' Flying Cloud
NCR
, Ontario
Pressure regulator,
primary high flow filter for the whole trailer
plus
triple filter just for drinking water at the sink
01-02-2019, 05:00 AM
2018 30' Classic
Eden Prairie
The 2018 Classic has a built in water regulator
01-02-2019, 06:53 AM
2015 30' Classic
Decatur
Originally Posted by waninae39
Pressure regulator,
plus
I'm interested in a "high flow" filter, appreciate learning your choice and performance.
01-02-2019, 08:13 AM
NCR
, Ontario
look for any HIGH flow filter at a plumbing or big box store
We added a new brass pressure regulator vs the stock AS unit
The three red valves in the picture or for bypass mode. ie when we replace the filter, we turn all three valves and that bypasses the filter
01-02-2019, 12:30 PM
2007 22' International CCD
Corona
Pretty much all Airstreams have one, but It only protects the internal plumbing from overpressure.
A good regulator at the campground connector protects the drinking water hose from overpressure. Important when campground pressure is very high. Helps prevent a burst hose.
01-02-2019, 04:05 PM
2017 22' Sport
Johns Creek
, Georgia
Originally Posted by turk123
Which length classic do you have and where do you put the softener tank?
01-02-2019, 05:09 PM
2019 30' Classic
Canfield
, Ohio
i have a classic 30! tank goes in the outside rear side storage area. i have the twin classic.
Tom & Doty
01-02-2019, 06:27 PM
2017 22' Sport
Johns Creek
, Georgia
Thank you. We’re thinking we’ll go for the 33 queen and are trying to figure out where a softener could go.
01-09-2019, 12:56 PM
2007 34' Classic S/O
Hillsboro
I was in the water filter & softener (for RV) business for 5 years, Premier Aqua Solutions, based in Illinois. I attended many AS rallies as well as most of the other clubs and RV shows in FL & PA. I use a pressure regulator at the faucet to keep the pressure on the hoses to 50 psi maximum. Next is a 10 micron sediment filter, either string wound or melt blown foam, then the water softener, then a 10 micron carbon block filter, then into the AS. The carbon block is recommended to remove taste, odor, and chlorine which will pass the sediment filter and softener. The sediment filter is checked periodically and replaced when discolored, usually due to rust or other sediment. The carbon block filter will last 2 times as long with a sediment filter ahead of it. The softener was purchased from G & L RV Specialties, rvfools@yahoo.com.
John Green, Hillsboro, TX
2007 34' Classic LTD S/O
2011 Dodge RAM 3500/Cummins power
WBCCI #4432 & ARC member W9CJX
01-09-2019, 01:04 PM
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
+2 Pressure regulator, filter, softener, in that order. While the AS does have a pressure regulator as standard I use one at the campground source to protect the hose!!
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
01-10-2019, 02:57 AM
Reads a lot
Titusville
Ditto on the sequence on the add-on’s and buried somewhere in all the Alde paperwork you might find that Alde suggests a lower pressure than what AS installed. It’s been a couple of years since I read the owners manual so I don’t remember the exact numbers. AS may have adjusted the regulator since 2017 but I am more concerned about protecting the Alde system than a ruptured external water hose, although that would be unpleasant too.
Lauri
She Believed She Could so She Did.
01-10-2019, 07:18 AM
NCR
, Ontario
@jwgreen
tnx i will add a 2nd filter as per your suggestions
10 micron sediment filter, then a 10 micron carbon block filter
i have no need for a water softener
