Old 08-10-2016, 08:52 AM   #1
Tom Wright
2016 30' Classic
2007 25' International CCD FB
huntsville , Alabama
Trailer sway
Hey all! Classic 2016 hitch weight 773# Trailer weight 7365# dry and 8420# loaded. Scary trailer sway with Equi-l-izer restribution/sway bar hitch. Previously pulled 25 CCD International 833# hitch 5612# dry same truck/hitch with absolutely no sway. How can I increase my hitch to trailer weight percentage?
gototwright is offline   Reply With Quote
Old 08-10-2016, 09:01 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The first think I would check is the wheel alignment. If you are using the original hitch and TV and the problem came with the new trailer look at it first.
If you have a 8 ft florescent light bulb set it across the center line of the wheel and see how the bulb rests on the edges of the tires. if there is a gap at any of the points of contact that may be pulling the trailer off the tracking line. If no bulb 2 people and a tight string folded into the wheels slowly should contact All point at the same time.
2004 Excursion 4x4
Old 08-10-2016, 09:09 AM   #3
Long Island , New York
Welcome to the forum! I can't help you but you might consider posting this in the Equalizer thread for better visibility and expertise from other similar hitch owners:
http://www.airforums.com/forums/f464...ead-98886.html
There is a recent post with the same model and year trailer.
What is your tow vehicle incl. its gross vehicle combined weight rating, max. trailer weight, max. hitch weight and so forth. How about your TV tires and tire pressures? People will want to know all the factors which might be causing your new problems IMO.
Have you weighed the TV and trailer carefully, including the tongue weight?
Good luck!
Peter
PS -- Personally -- I would have the dealer, or a good hitch shop, set up your hitch for the new trailer.
Old 08-10-2016, 09:10 AM   #4
2015 28' Flying Cloud
Newtown , Pennsylvania
Tongue weight is a little on the light side. I would try to move heavier cargo from the rear to the front. Get the tongue weight closer to 15%. Also might try adjusting the weight dist. bars.
Bruce
50 amp, Awning package
2015 Ram 2500 6.7 TD, Blue Ox 1000 lb.
4 Lifeline AGM, Trimetric 2020
PD9160 converter, Prosine 1800 inverter
2x eu2000i Propane
AstroBruce is offline   Reply With Quote
Old 08-10-2016, 09:13 AM   #5
aftermath's Avatar
Spokane , Washington
Who set the hitch up? I would take it back to them.
If you set it up you might want to contact the Equalizer folks, they should be able to help. You can download the directions too.
You might have issues with the trailer but I would reset the hitch first. I have a 25 FB and it does tow nicely. The TW on this trailer is pretty heavy so changing to your new trailer should not be an issue.
aftermath is offline   Reply With Quote
Old 08-10-2016, 09:14 AM   #6
CLOUDSPLITTER Phone home
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Question
Set up using CAT scale weights....or measurements. Proper drop stinger with level trailer.
773# TW 30' Classic?
Our 25' Classic TV & trailer loaded for camping TW 1200#
Most likely....Excess sway=improper TW/set-up.
ID:	268704   Click image for larger version
Name:	CAT Weights.jpg
OOP's
I'm a confirmed beginner in just about everything that other folks are expert in....
RLC
Old 08-10-2016, 09:22 AM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
You would need to know the actual hitch weight. You might have too much stuff in the very back of the Airstream but who knows. Best to load light in back and front, heavy in middle for best stability.
Are you feeling the sway in the truck's steering, and does in increase with speed? You may not have enough weight transfer to the front of the truck at the present setting of the w.d. bars. What is the truck/tow vehicle?
Doug and Cheryl
Old 08-11-2016, 09:21 AM   #8
beetlebob's Avatar
2015 30' Classic
Green Cove Springs , Florida
Would love to see a picture of everything hooked up from the side. I have seen way to many trailers hooked up wrong. If you are level all the way from front of truck to bumper of trailer you have to much weight on the rear of the trailer or the wrong tow vehicle
beetlebob is offline   Reply With Quote
Old 08-11-2016, 02:39 PM   #9
2016 30' Classic
Santa Rosa , California
I was surprised at the low tongue weight our loaded Classic initially showed. 780lbs TW with a GVW of 8280lbs, way less than the recommended 10% minimum ratio. I moved and swapped some heavy items from the rear of the AS toward the front of the AS, and some to our truck bed. I also carried 6-8 gallons of drinking water containers in a box just in front of the front lounge. I moved/swapped anything heavy from points behind the AS axles to areas in front of the AS wheels (best) or over the wheels. We have the twin model with the two exterior side storage compartments. I swapped heavy items out of there for lighter, bulkier items that we were originally carrying in the truck. The redistributed weights brought my TW to 12% of the TT weight, and noticeably improved handling. I also will avoid letting the propane tanks get too empty as this will also decrease my TW. In addition to increasing tounge weight, you can also raise the TW/TT weight ratio into the 10-15% recommended range by lowering the TT overall loaded weight - e.g., carry less in your fresh water, grey and black tanks.
Happy Trails,
Phil
phann is offline   Reply With Quote
Old 08-11-2016, 03:52 PM   #10
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
If your using 1000 lb bars it should not sway unless not set up correctly.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 08-12-2016, 05:51 AM   #11
Naper's Avatar
Loretto , Ontario
The front of the trailer should be down slightly. If the front is too high you will have sway for sure.
Naper is offline   Reply With Quote
Old 08-15-2016, 07:23 PM   #12
Tom Wright
2016 30' Classic
hey all. grateful for tips.
1. put 180# cargo boxes next to sofa rather than bed of trcuk
2. dealer raised spacers 5 to 7.
3. weighed
15,350 gross, 7630 truck hitched ( 3530 front, 4100 rear )
7720 trailer hitched. truck unhitched 6680.
4. and no more sway!
5. however sway bars not parallel with trailer bars, and shows enough wear for dealer to recommend dealer new hitch. this is my second Equal-I-zer (first one actually fractured).
6. what is experience with Reese vs Hensley?
7. and weights right at ratings for my F150 ecoboost without heavy payload package. safe?
Old 08-16-2016, 07:28 PM   #13
1974 27' Overlander
Baltimore , Maryland
Is money an object?
1974 Overlander In Progress
TheGreatleys is offline   Reply With Quote
Old 08-16-2016, 08:42 PM   #14
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I'd guess with a 2016 30 Classic, money can't too much of an object.
For that trailer I would recommend you look at the ProPride 3P. (an updated Hensley type hitch). I towed a 2010 31 Classic with one for 8 years, and sway was never a concern even with strong crosswinds and semis passing.
http://www.propridehitch.com/
Most of our trips involved windy I-80 through Wyoming.
Ken
Sway bars and sway control phibbs Towing, Tow Vehicles & Hitches 1 09-03-2012 05:48 AM
To sway or not to sway? cojer 1966-68 Caravel 11 03-15-2011 03:23 PM
67 Caravel Help: to sway or not to sway vonzellen Hitches, Couplers & Balls 15 01-26-2011 05:07 PM
to sway or not to sway... rayandre Hitches, Couplers & Balls 9 12-01-2010 06:52 AM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
