Old 12-09-2018, 03:41 PM   #1
Hamilton , Ohio
Temperature differential front to rear
So we are the proud new owners of a 2019 classic 30. We took delivery and immediately headed to Washington DC via Pennsylvania. Had some cold nights in Pennsylvania down to 19°. DC is been around 30-32°. The Alde system is working flawlessly as far as I can tell. It maintains a constant temperature of 72° utilizing electricity and gas with electricity being prioritized.
My question is there is a 4° differential between the bedroom area (twin) and the front living area. The front living area is consistently 4° warmer. Is this typical? It is easily adjusted for if it is common for the size trailer.
I have read through the "much to do about Alde" thread and I have not found any specific discussion of a differential.
Thanks in advance, Ernie
ErnieDurbin is offline   Reply With Quote
Old 12-09-2018, 03:47 PM   #2
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Yes, normal. See #832 in Much Ado.
Cheers.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 12-09-2018, 08:12 PM   #3
Hamilton , Ohio
Cheers.
I read this thread… It appears to be the inverse of the issue that I am indicating. My bedroom area is cooler by 4° than the main cabin. This thread seems to indicate the opposite.
Old 12-09-2018, 09:53 PM   #4
Obviously-NOT
Kalispell , Montana
Nope, same. Bedroom area cooler, just like at home, better for sleeping.
Old 12-10-2018, 12:27 AM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Raise temp until comfy in bedroom... will be warmer up front when you rise.
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-10-2018, 07:14 AM   #6
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Yes, there is a way to calibrate and adjust temp but it’s standard to see the temp difference. Mine is 2 degrees.
Better than what it looked like pre alde. From what I understand it is not uncommon to see a 10+ degree difference between front and back.
BigSxyWhtGuy is offline   Reply With Quote
Old 12-10-2018, 08:55 AM   #7
Hamilton , Ohio
It is is easy to deal with... just wondering if it is typical!
Thanks for the responses!
Old 12-10-2018, 09:11 AM   #8
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
My 2019 is 2 degrees cooler in the bedroom also. It was 4 degrees and I called John at AS customer support and he recommended bleeding the system again.
The twin Classics have a "rail" against the wall that needs partially removed to get to the bleed valves. If you pull back your mattress you can get to the rail. Remove the rear two screws so you can pivot the rear of the rail toward you so you can get to the valve.
John explained that the fluid takes a while to get to the rear and it cools as it flows to the rear of the trailer. Air bubbles can impede that flow. There are two bleeder valves behind the beds where the round vents are. Remove the three screws completely from the round vent and take it out rather than trying to reach into it with the cover off. It is much easier.
Bleeding my system a couple times has brought up the temps in the back to a two-degree difference. Also, remember to make your bed! if you cover the sides of the bed with your blankets, no heat gets to the side walls!
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
***Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 12-10-2018, 09:22 AM   #9
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I had another thought. Set your priority to gas when you need to warm up the trailer quickly. If you are plugged into shore power the Aldi system will use the electricity almost exclusively with the electric prioritized set.
Make sure your "Load Monitor" accessory is turned on at the factory. You can add that accessory if it is not. Mine was not set up at the factory. Set your load to the amperage you have in the campground such as 50 amps.
Aldi told me the optimum glycol temperature for heating the trailer is 145 degrees or more (look in your service menu to see this reading). When temps outside are in the 50-60 range, the glycol may not get that hot and the bedroom can stay a lot cooler.
Old 12-10-2018, 12:04 PM   #10
PCJ
2018 30' Classic
Eden Prairie , Minnesota
I've not measured as close as you have but. . . I'd say that is about it.
PCJ is offline   Reply With Quote
Old 12-10-2018, 12:25 PM   #11
2018 26' Flying Cloud
Hendersonville , Tennessee
My Mark 1 - Mod 1 fix: I used a small 12V floor fan. It moved the air around nicely and helped equalized the fore/aft temps. Might help in the short-term.
jmsm1 is offline   Reply With Quote
Old 12-10-2018, 12:29 PM   #12
2017 27' International
Box Elder , South Dakota
So, my question is, where did you park in DC?
alphamale49 is offline   Reply With Quote
Old 12-10-2018, 12:48 PM   #13
1973 31' Sovereign
1978 Argosy 30
1985 31' Excella
Sacramento , California
And you heater is located where.... just one is never enough... you should put another heater in up front and one at the rear bed... that way you can have good climate control in both... of course AS doesn't kare... its a 3 season trailer now...
GM Airstream is offline   Reply With Quote
Old 12-10-2018, 02:17 PM   #14
2018 30' Classic
Beverly Hills , Florida
I would not recommend doing anything with your alde system. I also have a 30 classic. My experience is this the reason you have a 4 degree difference in the bedroom is that there is no insulation under the bed and it is open to the back storage area. With that much cold air having access under the bed there is no way it will be the same temperature as the front you will see this consistently. My experience is everything is working as designed. As someone else said just set your temperature a little higher and it will be warm in the bedroom and just a little bit warmer than you want it in the living room.
Kentbrookin is offline   Reply With Quote
Rear Differential Oil Change mayco Mechanics Corner - Engines, Transmission & More... 32 03-13-2017 11:06 AM
How to set the on/off temperature differential on Dometic Furnace warmrain Furnaces, Heaters, Fireplaces & Air Conditioning 16 01-13-2014 09:59 AM
Rear Differential Problem?? Help! FLYNCLD Tow Vehicles 31 04-19-2010 12:04 PM
Temperature Differential Expected JimGolden Furnaces, Heaters, Fireplaces & Air Conditioning 6 11-28-2005 11:48 AM
split differential or locking differential cindy foxx Tow Vehicles 6 01-22-2003 08:48 PM
