01-22-2019, 11:37 AM
2015 28' Flying Cloud
2018 33' Classic
Cumming
SuperSprings
Pull 2018 Classic 33 with 2015 Chevy HD 2500 Duramax, Equalizer hitch, 1400 lb WD bars. Also have a Leer cap on truck bed. Airstream pulls fine, little sway. I was wondering if installation of SuperSprings would be a safe addition. Anyone have input for me?
01-22-2019, 12:48 PM
ObviouslyKnot
KAILUA
, HI
Pro Pride, no sway.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
01-22-2019, 01:28 PM
"Cloudsplitter"
2003 25' Classic
Houstatlantavegas
, Malebolgia
Ron..
I don't see the connection between helper springs on the 2500Dmax and sway.
Sway starts at the trailer not the TV.👍
Ck for proper tw and weight distribution, make sure the AS is level.🤓
01-22-2019, 01:35 PM
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
I have a similar setup. 2017 F250 gas with cap and 30' trailer. I am able to level fairly well with my Equalizer but have thought about adding Timbren springs, which are similar to summo. Haven't pulled the trigger yet. Also interested in hearing thoughts.
@living.somewhere.yonder | Instagram
01-22-2019, 04:37 PM
"Cloudsplitter"
2003 25' Classic
Houstatlantavegas
, Malebolgia
Scott,
Is your DW correct?
01-22-2019, 04:59 PM
2014 25' FB Flying Cloud
Des Peres
Sounds like too much weight on back of trailer
Does your airstream sit level when hooked to truck or is hitch too high?
01-23-2019, 03:23 AM
2014 30' FB FC Bunk
Anywhere
Originally Posted by robert cross
scott,
is your dw correct?
[emoji631]
dw?
01-23-2019, 05:01 AM
2018 33' Classic
Cumming
SuperSprings
James, had PrpPride on my FC28. Had to switch to Equalizer cuz PP will not work on the Classic 33.
01-23-2019, 05:04 AM
2018 33' Classic
Cumming
SuperSprings
All, not concerned with sway. And rig/tv fairly level. Just concerned about safety. Tongue weight already 1,200 lbs. before cap put on. Seems like the SuperSpring idea is not bad.
01-23-2019, 05:33 AM
2018 30' Classic
Cumberland
, Maryland
[QUOTE=DeltaRon;2202460]All, not concerned with sway.
That's a big mistake!
01-23-2019, 06:40 AM
2018 33' Classic
Cumming
[QUOTE=Airhead2018;2202464]
Why? Equalizer WD mitigates my sway.
01-23-2019, 06:42 AM
2018 33' Classic
Cumming
[QUOTE=DeltaRon;2202474]
Not installing SuperSprings to minimize sway, but to help relieve stress from my tongue.
01-23-2019, 07:31 AM
2015 25' Flying Cloud
Bend
This video was posted a while back about how airbags used for leveling and WD hitches move weight between axles. Just reposting it as it may help with your comment that you want"to help relieve stress from my tongue".
01-23-2019, 08:04 AM
"Cloudsplitter"
2003 25' Classic
Houstatlantavegas
, Malebolgia
[QUOTE=DeltaRon;2202478][QUOTE=DeltaRon;2202474]
Not installing SuperSprings to minimize sway, but to help relieve stress from my tongue.[/QUOTE
Ron,
Helper, (stiffer) springs will not relieve stress, stiffer springs with the same weight, would increase shock 'stress'.
It may seem counterintuitive but a heavier TW with the same springs & proper WD would ride smoother with less percieved stress.
Helper springs, add-on airbags do not increase payload , level trailer with proper WD is the best way to move weight.🤓
01-23-2019, 11:46 AM
ObviouslyKnot
KAILUA
, HI
Pray tell . . .? Not fit?
"pulls fine, little sway." was your summary. Little meant, little to no, or a little but tolerable, or little like none?
01-24-2019, 11:12 AM
2018 30' Classic
Cumberland
, Maryland
My mistake, reading your initial post I thought you meant there is a little bit of sway and you are not concerned about that.
01-28-2019, 07:08 AM
2018 33' Classic
Cumming
The Classic 33 only has one outside storage, a top pull-down door at front. The towers on the ProPride block that door from opening thus we would lose access to storage.
01-28-2019, 07:15 AM
ObviouslyKnot
KAILUA
, HI
Have you seen the new ratchet straps that can replace the towers?
01-31-2019, 03:26 PM
2018 33' Classic
Cumming
Sean at PP isn’t that kean on them; says it all.
01-31-2019, 03:37 PM
2007 22' International CCD
Corona
The ratchet straps work, but the basic issue is that the jacks will lift and tension the WD bars AND also push them down when you need to adjust the angle of the head. The straps cannot do that. You have to push the bars down with your foot instead, after slacking the strap.
Sean still sells them as an alternative to the jacks on the website. Look for his Lippert 335852 Straptek Weight Tension Technology Kit on the Propride website
