Old 01-22-2019, 12:37 PM   #1
DeltaRon's Avatar
2015 28' Flying Cloud
Cumming , Georgia
SuperSprings
Pull 2018 Classic 33 with 2015 Chevy HD 2500 Duramax, Equalizer hitch, 1400 lb WD bars. Also have a Leer cap on truck bed. Airstream pulls fine, little sway. I was wondering if installation of SuperSprings would be a safe addition. Anyone have input for me?
DeltaRon is offline   Reply With Quote
Old 01-22-2019, 01:48 PM   #2
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Pro Pride, no sway.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 01-22-2019, 02:28 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Ron..
I don't see the connection between helper springs on the 2500Dmax and sway.
Sway starts at the trailer not the TV.👍
Ck for proper tw and weight distribution, make sure the AS is level.🤓
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 01-22-2019, 02:35 PM   #4
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
I have a similar setup. 2017 F250 gas with cap and 30' trailer. I am able to level fairly well with my Equalizer but have thought about adding Timbren springs, which are similar to summo. Haven't pulled the trigger yet. Also interested in hearing thoughts.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 01-22-2019, 05:37 PM   #5
Scott,
Is your DW correct?
Amanamus
"Tahawus"
Old 01-22-2019, 05:59 PM   #6
dmbecke's Avatar
2014 25' FB Flying Cloud
Des Peres , Missouri
Sounds like too much weight on back of trailer
Does your airstream sit level when hooked to truck or is hitch too high?
dmbecke is offline   Reply With Quote
Old 01-23-2019, 04:23 AM   #7
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Originally Posted by robert cross View Post
scott,
is your dw correct?
dw?
Old 01-23-2019, 06:01 AM   #8
DeltaRon's Avatar
Cumming , Georgia
SuperSprings
James, had PrpPride on my FC28. Had to switch to Equalizer cuz PP will not work on the Classic 33.
Old 01-23-2019, 06:04 AM   #9
DeltaRon's Avatar
Cumming , Georgia
SuperSprings
All, not concerned with sway. And rig/tv fairly level. Just concerned about safety. Tongue weight already 1,200 lbs. before cap put on. Seems like the SuperSpring idea is not bad.
Old 01-23-2019, 06:33 AM   #10
2018 30' Classic
Callao , Virginia
[QUOTE=DeltaRon;2202460]All, not concerned with sway.
That's a big mistake!
Airhead2018 is offline   Reply With Quote
Old 01-23-2019, 07:40 AM   #11
DeltaRon's Avatar
Cumming , Georgia
[QUOTE=Airhead2018;2202464]
Why? Equalizer WD mitigates my sway.
Old 01-23-2019, 07:42 AM   #12
DeltaRon's Avatar
Cumming , Georgia
[QUOTE=DeltaRon;2202474]
Not installing SuperSprings to minimize sway, but to help relieve stress from my tongue.
Old 01-23-2019, 08:31 AM   #13
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
This video was posted a while back about how airbags used for leveling and WD hitches move weight between axles. Just reposting it as it may help with your comment that you want"to help relieve stress from my tongue".
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 01-23-2019, 09:04 AM   #14
[QUOTE=DeltaRon;2202478][QUOTE=DeltaRon;2202474]
Not installing SuperSprings to minimize sway, but to help relieve stress from my tongue.[/QUOTE
Ron,
Helper, (stiffer) springs will not relieve stress, stiffer springs with the same weight, would increase shock 'stress'.
It may seem counterintuitive but a heavier TW with the same springs & proper WD would ride smoother with less percieved stress.
Helper springs, add-on airbags do not increase payload , level trailer with proper WD is the best way to move weight.🤓
Amanamus
"Tahawus"
