Turn on all the lights using the Interior and Exterior Master On switch and turn on the tank heaters. Watch the battery voltage on the Fire Fly and listen for the Converter fan under the Wardrobe left side. I never heard our Converter fan before I replaced a dead Converter after two months, under warranty, with Parallax, none available from Airstream. The converters have been failing a bit lately. The owners manual says you "may never hear it run", but you should.
You can download an Owners Manual to read before you get there.
Especially read over thethread, Much Ado About Alde, so you can understand this new system and comprehend the orientation tour. Run the hot water, for a while.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
