Old 07-10-2019, 11:28 AM   #1
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Soft Close Drawer Sliders
I am starting my search for honey do list items and one of the requests was to change all the drawer sliders to heavy duty residential sliders that soft close.
I tried searching google and the forum but a lot of options come up. Hope that someone on here as experience with an upgrade like this?
Thanks in advance for sharing.
BigSxyWhtGuy is offline   Reply With Quote
Old 07-10-2019, 03:12 PM   #2
2007 22' International CCD
Try Rockler woodworking
rmkrum is online now   Reply With Quote
Old 07-18-2019, 07:51 AM   #3
2019 30' Classic
2012 25' FB Eddie Bauer
Crested Butte , Colorado
Originally Posted by BigSxyWhtGuy View Post
I am starting my search for honey-do list items and one of the requests was to change all the drawer sliders to heavy-duty residential sliders that soft close.
BSWG,
I am a furniture builder. Amazon is your friend
Soft close drawer slides are, generally, slightly thicker than their less exotic cousins. There are many brands and dimensions vary. In your case, the length of the slide is the easy part unless you want to rebuild all your drawers. Slide dimensions look like "Side-mounted Steel ball-bearing action.100 LB capacity.20'' in length.1.77'' in width.0.5'' in thickness." You probably don't need to match the width, also labeled as height sometimes.
I suggest you use Amazon, only order returnable items, try a few different brands styles until you find a brand that is the same thickness as your current slides. Search for soft-close drawer slides.
If the slide is even a 32nd of an inch thicker (a sixteenth for two slides), the drawer will bind and the soft-close won't function.
Heavier duty slides are not automatically better. Don't buy 100# capacity if you only need 75#. Make sure to buy full extension if that is what you are replacing else the drawer won't fully open.
2019 30' Classic RB pulled by 2013 F-150 Eco-Boost Platinum with Max Tow Package
Froglips is offline   Reply With Quote
Old 07-18-2019, 05:20 PM   #4
2018 30' Classic
Wow. Thanks for the tips. I’ll check it out, seems like I may be able to decipher the labeling with your tips. Thanks again
Old 07-18-2019, 05:37 PM   #5
1994 30' Excella
Mississauga , Ontario
soft close slides are nice, but they will open when you drive unless you find a way to lock them shut for travel.
Al and Jean
TAC ON-3
Old 07-19-2019, 05:59 PM   #6
2018 30' Classic
Oh snap. Really? Didn’t think about that. I need to research more....
Soft Close Cabinet Slides DDickey Cabinets, Counter Tops & Furnishings 1 11-04-2017 05:13 PM
Can't get drawer to close/latch Stews General Repair Forum 3 09-24-2017 03:32 PM
Curtain Sliders For '63 Overlander squrlgurl Upholstery, Blinds, Walls & Interior Finishes 4 08-29-2014 08:29 AM
Help -spring loaded hinges -can you adjust to soft close?? LAWBC 2009-2015 Flying Cloud 1 07-09-2012 09:12 AM
1964 curtain sliders Safari64 Upholstery, Blinds, Walls & Interior Finishes 6 11-26-2008 06:49 AM
