Old 08-14-2016, 09:34 PM   #15
2016 30' Classic
Erie , Colorado
Berry I only have one window that is just a bit troublesome. I also changed to the all chrome metal wit set screw handles from Vintage Airstream supply. Better clearance and look much better than the grey plastic ones.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 08-15-2016, 01:14 PM   #16
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
Are the replacement metal ones really any different in their dimensions to the plastic ones?
- Cory -
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
cory_can is online now   Reply With Quote
Old 08-22-2016, 06:04 PM   #17
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
Shade Interference with Window Lifts
You will probably hear more in the coming days but a report from a friend that just picked up a '17 is that their (AS) fix was simply to make the frames of the window shades slightly deeper so the handles don't interfere.
It would be a PITA but it seems a similar fix for 15/16's would be to put spacers between the frames and inside skin so they sit a bit further out then they do now.
- Cory -
'15 Classic
Instagram: cory_can
Old 08-22-2016, 06:34 PM   #18
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
That's not what I want to hear!,
Neither shaving the knobs.
I already have gaps that let light in when they are suppose to keep it out. So shimming is not pleasing, and labor heavy. But, a complete change out of or "shimming" every window is not appealing either.
I just want to open the windows without trouble of further damaging the blinds.
A few options;
1. Shaving knobs
2. Cutting shafts
3. New metal knobs, as done by previous poster.
4. Shimming shroud.
5. Replace shrouds with proper 2017+ proper "engineered" fix.
6. Live with it and have them replace as needed.
Any other options?
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 08-22-2016, 06:40 PM   #19
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Glad to hear AS finally fixed this. It only took until the third year for this version of the Classic for somebody to do something. This was mentioned publicly to the Airstream folks at Alumapalooza in 2015. As far as a retrofit to the 15's and 16's (and I guess a few 17's as well), they will never spring for modifications to our trailers. I had an issue with the front right curved accordion shade. That shade comes as a unit from Airstream at a cost of around $1500., as the shade and valence are "inseparable." My dealer fixed it in about 20 minutes (thanks, Terry!). I still wonder how the original design of the interfering window lifts left the prototype phase without resolution before the trailers went into production back in 2014.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 08-22-2016, 07:31 PM   #20
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
Good point on the gaps.
Do the metal knobs actually help....beyond aesthetics?
- Cory -
'15 Classic
Instagram: cory_can
Old 08-23-2016, 07:23 PM   #21
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
I'd spring for the metal knobs if it works for me. Only need a dozen at $5 a pop.:~
Just noticed also that in the rear with twin beds, the shroud runs behind the shirt closet above the foot of the beds. It would be hard to shim that.
Sphere Guy
AIR 50601
Old 08-24-2016, 02:21 PM   #22
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
I count 18...I'll give them a try....and they look nice
- Cory -
'15 Classic
Instagram: cory_can
Old 08-24-2016, 03:38 PM   #23
TheDuke's Avatar
2016 30' Classic
The Beautiful Mountains Of Southwest , Virginia
Images: 68
Knob?
Would someone please be kind enough to list the part# for the vintage knobs? I looked at their website to no avail. Thanks in advance for your help.
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Wayne - "JB Books" 1976.
TheDuke is offline   Reply With Quote
Old 08-24-2016, 03:40 PM   #24
daveswenson's Avatar
Issaquah , Washington
http://www.vintagetrailersupply.com/...-p/vts-294.htm
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 08-24-2016, 11:35 PM   #25
2016 30' Classic
Lorton , Virginia
I just ordered 18 metal knobs. I really like the set-screw method. Plastic knobs that pull off are a no-go.
Zybane is offline   Reply With Quote
Old 08-25-2016, 10:22 AM   #26
2016 30' Classic
Erie , Colorado
Add a drop of LocTite 242 MEDIUM (not the red stuff, think this is blue). While I haven't had a lot of issues with the set screws loosening when I find one loose now a do a 'little dab will do ya' with LocTite.
Gary
2015 Classic
ProPride
NVPN
Old 08-25-2016, 07:14 PM   #27
beetlebob's Avatar
2015 30' Classic
Green Cove Springs , Florida
Since we full time I have been cutting the plastic ones down. Almost have them to where they don't hit the blind. Could use a few of the original ones to do some heavy cuts on. If you want to give them up for the experiment let me know
beetlebob is offline   Reply With Quote
Old 08-29-2016, 09:35 AM   #28
TheDuke's Avatar
2016 30' Classic
Images: 68
Chrome Handles Installed!
I ordered 18 of the chrome knobs from Vintage AS and installed them all this past weekend. Added blue locktite to the setscrews as recommended. They look much nicer and match the latches. I still have a little bit of interference with a couple of the shades. Nothing serious that we can't live with. All in all, I would say a worthwhile project! Thanks for the info!
Bed lifts-Won't compress adwriter73 General Interior Topics 10 09-03-2011 11:40 AM
2007 Classic front center window glass/frame interference dznf0g 2006 - 2010 Classic (all lengths) 0 03-23-2011 10:44 AM
Spring lifts missing on streetside galley roof lockers - 2010 Classic Jammer 2006 - 2010 Classic (all lengths) 7 11-11-2010 11:16 PM
Axle Lifts ???? Bulldogger Axles 15 11-01-2008 11:39 AM
Hitch Interference Camp-Dog Hitches, Couplers & Balls 14 12-13-2004 04:56 PM
