Old 05-26-2019, 05:49 AM   #1
jmitchell's Avatar
2019 30' Classic
Granite Bay , California
Refrigerator Temperature - Shore Power
Hi All we are on our first trip in our new 2019 30. Our refrigerator does not cool below 44 degrees no matter what setting it is on. Is this normal? The outside temp is in the 50s, so it canít be related to the temp difference capacity. We are connected to 30 amp shore power now, and noticed the same thing while plugged into 15amp at home. We have not been anywhere with 50 amp service yet.
We have tried setting 3, 2, and 1. Setting 3 cooled to 52 degrees. Both setting 2, and 1 are the same temp of 44. The freezer works great at all settings.
I tried sliding the thermocouple further up the cooling fin, and that didnít change anything. The thermocouple appears to be placed normally.
Thank you in advance!
2019 30' Classic
2013 2500HD Duramax
P.E., CA
jmitchell is offline   Reply With Quote
Old 05-26-2019, 07:12 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard....👍
One of these helps us a LOT.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 05-26-2019, 07:45 AM   #3
2019 25' International
Providence , Rhode Island
Brand and link would probably help OP.
Our '19 serenity has 5 settings...on #3, we were down to 39F....44 seems a bit high....if you add a couple of cans of coke.....does it drop it down after a few hours?
kittmaster is offline   Reply With Quote
Old 05-26-2019, 08:00 AM   #4
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Has it ever cooled the fridge or is this first run?
Check fridge door seal with dollar bill test.
Do you have a light that is staying on and heating it?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 05-26-2019, 08:35 AM   #5
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
[QUOTE=jmitchell;2245120]Hi All we are on our first trip in our new 2019 30. Our refrigerator does not cool below 44...
We have tried setting 3, 2, and 1. Setting 3 cooled to 52 degrees. Both setting 2, and 1 are the same temp of 44. The freezer works great at all settings. ď
QUOTE]
Try setting it to Ď5í. Apparently the higher numbers correspond to lower temps.
az-streamer is offline   Reply With Quote
Old 05-26-2019, 09:50 AM   #6
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
When I set the fridge to 5, it cools down to around 33 in the fridge and below 20 in the freezer.
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 05-26-2019, 10:23 AM   #7
jmitchell's Avatar
2019 30' Classic
Hi Bob, I canít figure out what the pictured device is? Thank you!
2019 30' Classic
2013 2500HD Duramax
P.E., CA
Old 05-26-2019, 10:25 AM   #8
Anna Maria , Florida
On our 30' Classic we have the setting on 4, thermocoupler all the way up on the fin and we get a steady 37 degrees and freezer really really freezes. It is the same on LP, 50 amp or 30 amp.
franklyfrank is offline   Reply With Quote
Old 05-26-2019, 10:27 AM   #9
jmitchell's Avatar
2019 30' Classic
We have the frig full. We even had to add a couple ice packs around the fish and meet to keep them at recommended temps.
2019 30' Classic
2013 2500HD Duramax
P.E., CA
Old 05-26-2019, 10:32 AM   #10
jmitchell's Avatar
2019 30' Classic
This is the first time out, not used before.
The lights turning off, and it is sealing good, checked with dollar bill when freezer is open from top of frig when closed
Per below post we are trying setting 5, but I think thatís going the wrong direction.
Thank you for the troubleshooting support!
2019 30' Classic
2013 2500HD Duramax
P.E., CA
Old 05-26-2019, 11:05 AM   #11
Mike1997's Avatar
1998 36' Land Yacht Widebody
Shepardstown , West Virginia
Images: 14
Mine is an older Dometic Royale 3way, but 5 is coldest setting for it. Anything past 3 makes items on top frig shelve freeze.
Mike1997 is offline   Reply With Quote
Old 05-26-2019, 11:15 AM   #12
2018 33' Classic
Irvine , CA
The higher the setting number the colder your fridge/freezer is correct. Mine is set at 4 and the temp ranges between 35-37. When it's at a 5, temp is 32.
Octarine is offline   Reply With Quote
Old 05-26-2019, 11:38 AM   #13
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Our 2014 International Serenity 25's refrigerator struggled to stay below 48 degrees on electric or propane. I added a vent exhaust fan and interior circulation fan to no avail. Our 2015 Classic 30's refrigerator stays in the mid 30s with the freezer staying around 1 degree or below. This tells me there was a mechanical or electrical malfunction with the Serenity's refrigerator.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 05-26-2019, 12:01 PM   #14
GCinSC2's Avatar
Do you have a small fan you can point so it blows air UP from the bottom of the outside of the coils ? Make sure it pointing on the coils and not on the chimney for the heating unit.
Weíre in camp right now and pretty sure weíre on 4 plus small exterior fan and freezer temp is -6 in the morning and I think itís about -2 right now.
No repairs to 12 yr old unit other than new seals on doors.
Try switching to gas and see if that helps.
S/OS #001
Refrigerator Will Not Cool on Shore Power wrbaron Refrigerators 23 05-25-2018 12:46 PM
Dometic refrigerator wonít run on shore power& water heater light on when on shore po fotoman1527 General Repair Forum 22 04-10-2018 02:57 PM
LP light on refrigerator when connected to shore power jnm30327 LP Gas, Piping, Tanks & Regulators 8 11-18-2017 10:01 AM
2017 26U Refrigerator Temperature Increase Jamesbford 2016 - Current Flying Cloud 10 07-03-2017 07:44 AM
Refrigerator clicking sound when on shore power & fridge set to auto? kayt General Repair Forum 5 02-02-2016 08:59 PM
