Old 12-11-2018, 10:51 AM   #1
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Re-running an audio wire in the walls
In another thread, I discussed a problem I had with my Classic 30. The subwoofer audio cable (two RCA jacks) runs through the walls of the trailer to under the center of the sofa where the sub is located. I have power there (12v) but one of the audio lines is broke somewhere in the walls.
How to fix.
AS said the only way they can do it is to remove furniture, the wall window boxes and to peel back the inner aluminum to run a new wire. That sounds drastic. It also sounds like it may create other problems down the line. I talked with Vinnie's AS repair in Sacramento (AS told me to call him) and he said the same thing. Too much to remove for a simple cable. He also is booked into March and cannot help me. AS offered to reimburse me for his work. AS wants me to take it to Scottsdale AZ for them to work on. We had planned on storing our trailer in AZ and drive back to Ohio end of January. We are coming back west in the spring. I was trying to avoid pulling the trailer back to JC in Ohio during the winter.
Is there another solution? Is this really my problem?
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
***Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 12-11-2018, 11:01 AM   #2
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
One thought I had was an audio transmitter. The plug up in the cabinet is an inverter connected plug. I'm not sure what is under the sofa. Most of these devices come with a black box power cord. I cannot find a 12v version.
This could work and avoid the incredible two days of work on the trailer. The transmitter/receiver can be on the high-end side to ensure no lag or cutouts at low volume. I'm guessing Airstream would be quick to reimburse me for that solution and to avoid the whole mess.
The sofa has electric recliners that will work with the inverter. There probably is a line down there I could use to power the receiver.
Old 12-11-2018, 06:51 PM   #3
Hamilton , Ohio
I had the same problem. It turned out that I had power to the sub woofer however the sub was not outputting any sound. Sounds like your problem. The solution was to adjust the settings on the subwoofer. They are in a small panel on the side of the sub that has to be removed. Whenever I adjusted the settings up the sub will for works like a charm. Be aware that you can also adjust them so high that it will blow a fuse.
ErnieDurbin is offline   Reply With Quote
Old 12-11-2018, 06:53 PM   #4
Hamilton , Ohio
My cell is 513-608-2833 if you want to discusd
Old 12-11-2018, 07:18 PM   #5
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
the service guys did a continuity test on the audio cables and said one was not good.
But can i trust them?
Old 12-11-2018, 07:22 PM   #6
waninae39's Avatar
2017 22' Sport
NCR , Ontario
i ran small diameter conduit or cable tray type molding
that was far easier than snaking cable through the wall and snagging on insulation
i suggest just run new wire using those wire concealing products
get them at any big box store
waninae39 is offline   Reply With Quote
Old 12-11-2018, 07:41 PM   #7
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Bluetooth...
Richard
azflycaster is online now   Reply With Quote
Old 12-11-2018, 08:34 PM   #8
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
got a great idea from ernie. move the sub to under the dinette next to the tv.
Old 12-12-2018, 08:45 AM   #9
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Good news,
If your airstream has only one subwoofer then it is mono, not stereo.
What does this mean? You only need one of those RCA connectors to work!
Normally in such a set up only the left output (white) from the back of the stereo is used.
Even if your subwoofer has a left and right input just use the left!
No need to pull anything apart!
I have been messing with audio systems for 25 years in cars/boats/ATVs/trailers/houses.
Hopefully this helps you out, any questions let me know.
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 12-12-2018, 09:29 AM   #10
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Originally Posted by Gsmblue View Post
Good news,
Very interesting! Let me give it a try.
Old 12-12-2018, 09:42 AM   #11
Mollysdad's Avatar
He's right.
Low frequencies are not directional. They seem to come from everywhere.
If you feel you need two inputs on the sub, put an RCA "Y" cable in the path and split the one signal into two. The only reason some subs have two inputs is so the other speakers can be looped through them.
Also, don't be shy about moving the sub if it's more convenient elsewhere.
In addition, unless Airstream punctured the wire, it's unusual for a cable to fail in the middle. Before I tore things up, I'd cut the ends off and replace or test.
Bluetooth? I don't think this will work for your application because of digital delay.
Mollysdad is online now   Reply With Quote
Old 12-12-2018, 10:07 AM   #12
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Here are images of both ends of the sub. The Axxess device seems to be attached to several speakers. Maybe two fronts. Two rca outputs go to the sofa.
At the sofa, the two rca jacks plug into a harness that plugs into the sub.
Name:	sub wire 1 sm.jpg
ID:	329545   Click image for larger version
Name:	sub wire 2 sm.jpg
Old 12-12-2018, 10:30 AM   #13
Gsmblue's Avatar
Bend , Oregon
That wiring is giving me a heart attack!
Ok, so as I read this: the stereo plugs into the Axxess device (I can't see what kind of connection that is). The RCAs connect into the Axxes device on the other side and those run to the sofa and plug into the sub.
Is that correct?
If so:
1. It would be good to see the input to that Axxes device are they speaker type wires or RCA?. I am not sure if it is a noise suppresser or a speaker level to RCA level adapter
2. what does the connection at the sub look like.
Old 12-12-2018, 10:38 AM   #14
Gsmblue's Avatar
Bend , Oregon
Ok, what make/model is the stereo. Can you send a clearer picture of the back of the unit and the jumble of wires?
The axxes device is a line level converter
https://axxessinterfaces.com/product...gory=AX-ADDAMP
It changes "speaker level" output of the stereo into "line level" RCA output for sending to an amplifier. This is used if the stereo does not have a dedicated "Sub out" RCA conector.
Your sub will have an amplifier built into it and will need the RCA connector for the signal.
Note: most modern stereos have "sub out" on them and the axxes device should not be needed.
But any which way. The original point stands. If the sub is working with just the white RCA plugs connected, plug the red ones back in and leave it all alone, it is working as well as that set up can.
If not - report back!
To Rip Off Walls Or Not To Rip Off Walls... belikethefox Upholstery, Blinds, Walls & Interior Finishes 3 03-20-2015 02:31 PM
Best wire connector for 12 gauge stranded wire jcarnevale Lights - Interior & Exterior 6 04-14-2014 09:18 PM
Green wire/White wire magnets robbier49 Brakes & Brake Controllers 3 07-08-2009 07:26 PM
Two wire and three wire converters??? max7 Batteries, Univolts, Converters & Inverters 1 02-28-2008 06:27 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 12:09 PM
