Old 07-06-2016, 09:18 AM   #99
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
This is the stainless steel 120V outlet cover that I put on my '15 Classic. You do need to change the outlet itself -- which is probably a good thing anyway since Airstream uses the cheap "press to connect" outlets.
Marinco Marine SS 120V Outdoor Cover (AFI Marinco) Boaters Cove 52.99
Barry
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 07-06-2016, 07:54 PM   #100
2016 30' Classic
Lorton , Virginia
The only thing I don't like about the Marinco is it's a vertical outlet cover. Stainless horizontal covers don't seem to exist. I did find an aluminum one though I may go with, although it's not very pretty. I feel a vertical outlet cover mounted horizontal has a much greater potential for water intrusion. BAB, does the spring that keeps the cover secure really seal the outlet tight against the membrane?
Zybane is offline   Reply With Quote
Old 07-06-2016, 08:01 PM   #101
BAB
BAB's Avatar
2015 30' Classic
No sign of any moisture at all. I, too would have preferred a horizontal opener, but this is the best I've found. There's been plenty of water on this Marinco, and no issues. Since the product is designed for boats, it has a strong spring, and a more than adequate high quality silicone-type seal. The outlet is on the GFCI circuit and if there'd been any water intrusion it would have tripped the GFCI. Hasn't happened.
_________________
ProPride 3P
AIR# 58452
Old 07-07-2016, 07:26 AM   #102
Dan & Sue Busse
2016 30' Classic
Wildwood , Missouri
This is the same plate that is manufactured by Pass & Seymour. The horizontal version is the WPH8. What Marinco sells is the vertical version WP8. If you Google these numbers, they are easily found online.
I think I'll buy a WPH8. They also manufacture versions for standard duplex receptacle as well as the Decors version (like a GFCI).
Dan Busse
2016 Classic "Birdie"
WBCCI 14004
dbusse is offline   Reply With Quote
Old 07-09-2016, 09:12 AM   #103
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Dan Busse
WBCCI 14004
The WP8 and WPH8 are "dustproof", not watetproof. Per their own specifixations, they do not meet the NEC requirements for sealing again water intrusion.
Joe
WBCCI/VAC #6768
(Looking for a vintage 1960's fiberglass front window guard)
66Overlander is offline   Reply With Quote
Old 07-10-2016, 03:14 PM   #104
Dan & Sue Busse
2016 30' Classic
Wildwood , Missouri
Agreed. I'm basing my try in BAB's comments above. There is no seal on the plastic door that Airstream currently uses. I also intend to use a spec grade Hubbell illuminated face outlet. It's instant verification that it is live. The GFCI protection is in the breaker.
I'll report back when the cover arrives.
Old 08-03-2016, 06:05 PM   #105
Boogieshoes's Avatar
2016 30' Classic
Little Rock , Arkansas
Originally Posted by BAB View Post
These are the exact sizes manufactured for my '15 Classic:
18.0 x 26.5" (rear) = $208
23.0x 23.0 = $252
Exterior finish was powder coated white
Skylight colors: gray-clear-clear
Pricing was as of December 2014.
BAB, Zybane or others: we are going to replace our skylights with Maxims. Do you recommend installing them ourselves, or is this best left to our dealer (Foley)?
_________________________________
Boogieshoes, DH of JudyJudy
WBAC 5932; Arkansas Razorbacks Unit of Reg 6
2016 F250 King Ranch 6.7 4x4 Crew Cab "Tex"
Members, North Texas Airstream Community
Boogieshoes is offline   Reply With Quote
Old 08-03-2016, 06:29 PM   #106
BAB
BAB's Avatar
2015 30' Classic
I did them myself. I have the detail for the two skylights if you'd like to save yourself the work of getting up on the roof and measuring the openings. I've sent this to a flock of '15-'16 Classic owners. You will have to do the color selection (window tints) and of the aluminum frame -- white or aluminum (most of us have had the white powder coat...but your choice.)
_________________
ProPride 3P
AIR# 58452
Old 08-03-2016, 11:52 PM   #107
2016 30' Classic
Lorton , Virginia
I'll take the info BAB, thanks.
Old 08-04-2016, 08:47 AM   #108
beetlebob's Avatar
2015 30' Classic
Green Cove Springs , Florida
Babs keep the information on the skylights I want to replace mine but with all the other problems I am having I am going to wait. Do you still have the old cover for the electrical power cord from your trailer? Would love to buy it to match both covers on mine. Zipdee has sent me another control unit for the awning in hopes that this will fix my ongoing problem. They have redesigned it again and the new update looks good. Will keep you all updated. Living in the middle of the Yellowstone park makes it hard to fix things. 100 miles to a hardware store and have to say for full time they are not the best for 4 season living. O well we will see what Yuma weather does to the home in 2 months
beetlebob is offline   Reply With Quote
Old 08-04-2016, 11:21 AM   #109
BAB
BAB's Avatar
2015 30' Classic
Zybane: pls PM me with your email address and I'll send you the document.
Bob: I have the old cover somewhere. I'll save it for you.
Barry
_________________
ProPride 3P
AIR# 58452
Old 08-04-2016, 05:31 PM   #110
beetlebob's Avatar
2015 30' Classic
Babs I will be at vinnies in California in October. If you find it pm me and I will pay for the cover and shipping to vinnies for me to get
Old 08-04-2016, 07:00 PM   #111
BAB
BAB's Avatar
2015 30' Classic
I'll see if I can track it down. On the road most of the month of Aug!
_________________
ProPride 3P
AIR# 58452
Old 08-07-2016, 10:17 PM   #112
2016 30' Classic
Lorton , Virginia
Got the Tarheel motorized antenna mast installed with the Wifi Ranger and Weboost LTE antenna all setup. Routed everything to the Blu-ray player area via the fridge vent. Took about eight hours, fun project. I can even see this baby rise and lower through the center skylight.
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 14 09-26-2016 10:40 AM
Rumble Strip Ramblings: Alice Reno! RumbleStrip General Repair Forum 49 02-11-2016 08:58 PM
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 2 10-26-2015 05:57 PM
road ramblings norbert Off Topic Forum 4 06-29-2004 12:44 AM
Misc. ramblings till Our Community 14 03-06-2004 08:11 PM
