Old 06-10-2019, 10:17 AM   #1
Oakville , Ontario
Raising or lowering bed with Czone???
Hi All,
I'm picking up a 2019 Classic 33fb next week. I don't recall seeing a way to lower/raise the bed from the Czone system or on the bedroom wall by the door. The only switch I noticed was the one directly above the bed.
From videos, it looks like the previous Firefly system had a control on the bedroom wall to do this.
Can anyone with a 2019 confirm if there is another way to do this (other than the switch above the bed)?
Also, It looked like the previous Firefly system allowed for lowering the table from the panel. Again, it seems like the Czone panel doesn't offer this and the only option is a switch by the entry door? Am I missing something?
Thanks!
Sean
The Naker is online now   Reply With Quote
Old 06-10-2019, 02:54 PM   #2
2019 30' Classic
Norcross , Georgia
Hi Sean. I have a ‘19 30 Classic and it has a few bed switches on the walls by both night stands and by the TV/main bedroom wall controls. The CZone doesn’t have a setting that I’ve seen. Enjoy her!
PaulR-GA is offline   Reply With Quote
Old 06-10-2019, 09:14 PM   #3
Oakville , Ontario
Thanks. I didn't see one by the TV/main bedroom wall controls. Is it the switch that is circled in this picture?
Old 06-11-2019, 04:12 AM   #4
2019 30' Classic
Norcross , Georgia
Yes, that looks like them.
Old 06-11-2019, 05:10 AM   #5
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
On the twin, there is also a switch on each wall next to the USB plugs. Right where you need it. It is under the window boxes and sometimes hard to use as they are not that visible.
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
!!! God I love my Airstream !!!
***Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 06-11-2019, 07:07 AM   #6
Oakville , Ontario
Thanks for the replies. Its very helpful.
Here is a picture I took of the unit that I'm purchasing. Strangely, it is missing the wall switch to raise the bed (I've seen other pics online that show the switch next to the panel). It seems like an important switch to have because with the queen model you need to raise the bed to get around it and don't want to have to climb to the front of the bed to get to the other switch.
I'll check with my dealer to see whats up. The unit also was missing other 2019 items such as the third solar panel and blind over the bedroom vent.
Old 06-11-2019, 04:13 PM   #7
Oakville , Ontario
The dealer is now telling me I can only have one switch to control the bed. It can be on the wall by the door or above the bed. The story is that the unit I'm buying is an early 2019 and the model has been evolving.
I don't get this. The 2017, 2018 and any 2019 I can find all had the ability to control the bed from both locations. That way you can raise the bed when you come in the room to create more space at the end of the bed to get around it. Then when you are in bed you can lower the bed.
Can anyone with a 33FB Queen tell me how often they use both switches or what they typically use?
Thanks!
Old 06-12-2019, 06:18 AM   #8
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
You’ll only need one switch. I would prefer the one on the wall vs under the cabinet personally. The motor doesn’t seem efficient enough to raise and lower the bed with two people in it. We broke the bracket that holds the bed in place early on in the airstreams life by raising and lower the bed every day. Now it’s rare that we raise it at all. We full time and make our bed daily in a 2018 classic 30
BigSxyWhtGuy is offline   Reply With Quote
Old 06-12-2019, 05:30 PM   #9
Oakville , Ontario
Thanks for this. Very Helpful. Its a bigger concern in the 33fb because there is less space at the end of the bed to get by. But, if the motor doesn't want to operate when people are on the bed, I agree it makes more sense to have a switch on the wall.
Old 06-17-2019, 10:10 PM   #10
2019 - 33' Classic
RickyNelson's Avatar
2019 33' Classic
Grand Junction , Colorado
Sean,
I have a 2019 33 FB with a queen. I have two switches to control the bed. There is a switch on the wall and next to the passenger side night stand. Nothing on the CZone. Also, it is a tight fit, but you can get around to the side when the bed lowered. This Airstream is absolutely amazing...enjoy!
Rick & Michelle Nelson
Grand Junction, CO
2019 Classic 33
RickyNelson is offline   Reply With Quote
Old 06-18-2019, 04:22 AM   #11
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I guess you are SOL on the solar panels also! No third panel and possibly no Victron MTTP controller with upgraded wiring would be a significant difference over the current models solar.
Old 06-18-2019, 07:37 AM   #12
Oakville , Ontario
Originally Posted by RickyNelson View Post
Sean,
Thank you!
Old 06-18-2019, 07:38 AM   #13
Oakville , Ontario
The dealer is adding a third panel. There is a Victron display above the kitchen counter. Did the classics only use MTTP controllers with Victron?
Old 06-18-2019, 07:55 AM   #14
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I believe that is true.
CZone and Multiplex Interfaces In General Re-Pete 2016 - Current Classic (all lengths) 10 05-26-2019 09:11 AM
CZONE replacing fan with MaxxFan The Naker 2016 - Current Classic (all lengths) 6 05-26-2019 08:57 AM
Regarding Multiplex Interface Systems such as CZone, etc. Re-Pete Electronics & Connectivity 0 04-16-2019 10:53 PM
CZone app skiphoyt Sprinter and B-van Forum 1 03-07-2019 07:42 PM
CZONE Display Reset? PaulR-GA 2016 - Current Classic (all lengths) 5 10-31-2018 02:41 PM
