Old 06-10-2015, 06:53 AM   #1
beetlebob's Avatar
2015 30' Classic
Green Cove Springs , Florida
Polk radio
So for us with the new Classic with the Polk PA450UM radio in it. I contacted Polk who said they do not build it and only put their name on it. SO with that you have to contact ASA electronics (877-305-0445). Very helpful people. Since the speaker placement is BAD I asked about using Bluetooth speakers on it. Also the ASA people could not believe what Airstream did with the speaker placement. If you want to do Bluetooth you will have to go to the amp and install aan additional and to run a Bluetooth sender. It can be done if you want to spend the $$$ and take up more cabinet space. Just to let you all know. I did download and copy a great operation manual and installation guide from ASA. So for now will have to enjoy music to loud to sit under or not loud enough to hear when cooking
beetlebob is offline   Reply With Quote
Old 06-10-2015, 08:59 AM   #2
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
The speaker placement is the same in the 25 Flying cloud. I have he same problem as you with the volume. I have rubbish hearing so when I cook my wife gets deafened!
Not sure there is really a good solution.
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 06-16-2015, 05:33 PM   #3
Trying to run away.....
Hampton , Virginia
Is this the Polk unit in the new Classics?
https://www.polkmarine.com/stereo-source-unit.html
HeavyAssault is offline   Reply With Quote
Old 06-16-2015, 05:59 PM   #4
Firedog1
Firedog1's Avatar
2015 30' Classic
Woodbridge Connecticut & , Venice Florida
also interested in bluetooth I'm jumping on to follow updates
Russ and Lisa
2015 Classic 30
2015 F250 King Ranch 4x4 turbo diesel
Sold but not forgotten: 2005 Classic 25 Limited
Firedog1 is offline   Reply With Quote
Old 06-16-2015, 06:25 PM   #5
ericpeltier's Avatar
Superior , Colorado
I don't own one of these, but it's something I stumbled across a month ago:
Bluetooth Stereo Receiver Adaptor / Converter
ericpeltier is offline   Reply With Quote
Old 11-24-2015, 10:21 PM   #6
Firedog1
Firedog1's Avatar
2015 30' Classic
Polk system died last week. Tried everything. Spoke to tech at airstream. Need to bring it in. Appointment at factory. Hope it's covered under warranty.... Will advise
Russ and Lisa
2015 Classic 30
Old 11-24-2015, 11:46 PM   #7
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I have a Classic, 2016 and have this system. Not thrilled but mine seems to work ok. I did use a bluetooth adaptor in the bedroom to get the sound to come out of the bedroom speakers when watching TV in the bedroom only.
TinCan
graysailor is offline   Reply With Quote
Old 11-25-2015, 05:17 AM   #8
beetlebob's Avatar
2015 30' Classic
Talked to a person who made sound rooms and he told me about a fix. He said since the speakers are 4ohm you can replace them with 8ohm speakers and double the amount you have without hurting the amp. Have looked and there is a lot of room to put a speaker into the front of the cabinet. Now all I need to do is find the money to replace the front 2 and buy 2 more.
Old 11-28-2015, 08:26 AM   #9
TinCan
graysailor's Avatar
2016 30' Classic
What would be the gain of putting in 8ohm speakers? I was playing around last night and am having the same issues as others. I need to turn on the TV speakers just so I don't have to have the Polk speakers blasting.
TinCan
Old 11-28-2015, 10:02 AM   #10
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Two 8 ohm speakers can replace each 4 ohm speaker doubling the total number of speakers and allowing the additional speakers to be added in new locations pointing in new directions without changing the radio. Each speaker would produce less sound, but overall sound could be distrusted better.
Joe
WBCCI/VAC #6768
(Looking for a vintage 1960's fiberglass front window guard)
66Overlander is offline   Reply With Quote
Old 06-01-2016, 11:43 AM   #11
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
Has anyone used the preamp outputs to feed a simple BT transmitter? This could feed a portable wireless speaker (I've been happy with Libratone) that you could carry into kitchen/dinette or outside around the campfire. What I don't know until I get my trailer, is if the preamp outputs can be controlled separately.
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
cory_can is offline   Reply With Quote
Old 06-06-2016, 02:00 PM   #12
2016 30' Classic
Hilliard , Ohio
Yes, to try it out I deliberately bought a cheap $23 BT transmitter from Amazon (HomeSpot Dual Stream) and connected it to the spare (rear) preamp outputs. We have one of those Bose BT speakers and I'm able to bring it outside up to about 20 to 25 feet from trailer. Isn't great for inside trailer because there's an inherent delay causing an echo effect. Outside is fine. I saw more capable transmitters on Amazon with a greater range. I may upgrade in time, but this works.
On my trailer, the front pre-amp output is already used to feed the subwoofer, I believe. As I say, the ones I used are the rear pre-amp so the control I have is limited to the fader.
2016 Classic
2010 Ford F-150 Lariat
jeff4506 is offline   Reply With Quote
Old 06-06-2016, 03:10 PM   #13
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
Polk radio
^ they do make BT transmitters that are marketed as no delay/low latency ....that may be worth considering for sync issues for inside usage. Also, since the rears are powered already, perhaps a separate speaker level volume control might make sense so that you don't have to have the inside speakers playing while you use the portable outside speaker. For instance, my wife and I might be sitting around the fire while my son is inside sleeping.....we wouldn't want the speakers going inside.
'15 Classic
Instagram: cory_can
Radio Speakers but no Radio 1969 ???? tdoescher 1965-1969 Sovereign 13 04-21-2015 02:17 PM
'15 Classic Polk Audio BAB 2011 - 2015 Classic (all lengths) 1 03-12-2015 08:32 PM
cb radio, cassette radio jagcb750 Classic Motorhomes 14 04-19-2012 03:32 PM
Radio/Light Interface??? 74Tradewind Electrical - Systems, Generators, Batteries & Solar 3 06-18-2002 10:43 AM
Old motorola radio... niftypkg General Interior Topics 1 05-13-2002 10:27 AM
