Old 03-30-2019, 01:49 PM   #1
2015 25' Flying Cloud
2018 33' Classic
Pullman , Washington
Overheat Red Fail - Alde
Has anyone seen the alert on the Alde Screen which says “Overheat Red Fail - Alde” ?
WA_Airstream is offline   Reply With Quote
Old 03-30-2019, 03:35 PM   #2
Sparr's Avatar
Casa Grande , Arizona
Here is what the Alde manual says:
Overheat red fail: Overheat protection (red cable) tripped. This fault can arise if the boiler is run at high power at the same time as there are air pockets in the heating system, the heating system should then be bled properly.
If the fault remains, contact a dealer. Also check that the fluid level in the expansion tank is at least 1 cm above the min line when cool.
Steven & Lisa
"Olivia" 2017 Airstream Classic 30
2016 Dodge Ram Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
WBAC (WBCCI) - # 5523, AIR # 118556
Sparr is offline   Reply With Quote
Old 03-30-2019, 05:57 PM   #3
2018 33' Classic
Thanks. I had a different version of the Alde Manual which wasn’t helpful. I downloaded the correct one (which had this information in it).
Old 04-01-2019, 09:28 PM   #4
2018 33' Classic
Update - I reached out to our local dealer and am taking it in to have the unit serviced. More details later
Old 04-29-2019, 09:26 PM   #5
2018 33' Classic
Further update. We took our trailer to the local dealer where they have been troubleshooting for 3 weeks. The Alde system works on shore power but continues to give the same fault when trying to use Propane for heating. A factory rep was in Spokane and gave our local tech some additional ideas.
I love the Alde system when it is working - but it has been quirky to say the least.
Old 04-30-2019, 04:10 AM   #6
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Wow. Maybe they could just upgrade you to the 3020 unit at this point
BigSxyWhtGuy is offline   Reply With Quote
Old 05-03-2019, 09:49 PM   #7
2018 33' Classic
Just got a call from Airstream of Spokane and everything is fixed!
Old 06-04-2019, 02:19 PM   #8
2019 33' Classic
Jacksonville Beach , Florida
Did they say what was wrong? Circulation Pump, maybe? We are having the failure code with our 3020 Alde System in our 2019 Classic.
Larry B. is offline   Reply With Quote
Old 06-25-2019, 11:03 PM   #9
2018 33' Classic
First camping trip of the season to the Oregon Coast - Alde system leaked a bunch of fluid and stopped working. I called our dealer and they re looking at it again. We got plenty of hot water - but no heat. We called our dealer in Spokane and turned off fluid circulation throughout the coach.
We used the heat pumps to get the trailer for a week and had a great time - but boy the Alde system has been frustrating.
First Alde 3010 boiler to Alde 3020 boiler and Alde flow upgrade Sparr 2016 - Current Classic (all lengths) 51 06-04-2019 04:54 AM
ALDE HEATING SYSTEM FAILURE- Alde glycol discoloration and vent discharge JimskyD 2016 - Current Classic (all lengths) 50 05-25-2018 07:48 AM
Problem with safety valve popping between Alde flow and Alde paul.kukstis 2016 - Current Classic (all lengths) 7 04-08-2018 06:09 AM
Red! Red! Red! Can Anyone Tell Me What This is About Now? Fly at Night Batteries, Univolts, Converters & Inverters 23 11-06-2011 01:18 PM
GMC Allison Transmission Overheat 2dabeach Tow Vehicles 7 07-20-2007 07:15 PM
