Old 03-29-2016, 08:27 PM   #29
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I can't imagine not having both a microwave AND a thermal oven. I did dump the "Franklin Chef" microwave/convection that came in my trailer. I substituted the microwave with a Panasonic. This is one of the few microwaves that uses an internal inverter -- so instead of just pulsing on and off (which is what virtually all microwaves do), it actually decreases and increases the power to the magnetron for better cooking performance.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 03-29-2016, 08:33 PM   #30
2016 30' Classic
Erie , Colorado
Barry you are killing me. Almost fell off the dinette seat laughing. Makes me glad that I have the twin beds. Keep it up and you will need a RAM 3500 dually or maybe even an MDT/HDT like one of the ones from RVHaulers.ca. Giving it more thought skip the RAM and get the HDT Volvo. Safe travels.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 03-30-2016, 11:14 AM   #31
2016 30' Classic
Orlando , Florida
We have twins, but with the addition of 3" tempurpedic toppers, the beds are very heavy to lift. I could use two of BAB's motors.
FreshAirStmr is offline   Reply With Quote
Old 04-03-2016, 06:13 PM   #32
2016 30' Classic
Indianapolis , Indiana
ghaynes755 we just came back from our first outing and had a few problems. One was the furnace. It ran for about an hour on auto and then shut off when it reached the set temperature. When it kicked on again all we got was cold air. You mentioned trouble with the sail switch and that it was an easy fix. Can you tell me more about that? Also, we thought both the furnace and heat pump sounded very loud. At least louder than we expected after being in both pop up trailers and motorhomes.
2016 Classic 30'
2016 GMC Sierra 2500HD
ProPride Hitch
Indianapolis, IN
SusanFleck is offline   Reply With Quote
Old 06-03-2016, 09:07 AM   #33
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Originally Posted by FreshAirStmr View Post
Our 2016 Classic floor, when brand new, looked fine. In reality, it was filthy and made the soles of my feet black. What??
The solution? We cleaned and scrubbed it many times -- over and over again. Now it's clean -- it still looks the same as it did when the trailer was new, but the soles of my feet stay clean. I can't explain it.
Joanne
Hi Joanne,
The floor in our 2016 Classic turns the bottoms of our socks brown. It has done this from the first day we got it 11 months ago up through the last time we used the trailer a couple of weeks ago. I have scrubbed the floor end to end on my hands and knees three times and we even had the floor professionally steam cleaned and in every case it made no difference. Within hours the bottoms of our socks were again turning brown.
I would like to know what you did to get the flooring clean. What cleaner did you use? How many times did you clean it? etc.
As a side note, Lorrie thinks our flooring may be fading (I am not as sure due to shadows when looking at the corners vs. main walking areas). Have you noticed that in yours?
Joe
WBCCI/VAC #6768
(Looking for a vintage 1960's fiberglass front window guard)
66Overlander is offline   Reply With Quote
Old 06-03-2016, 11:26 AM   #34
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I like the fake wood plank roll vinyl flooring in my 2013 Classic-
Durable and easy to clean-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-04-2016, 10:05 AM   #35
2016 30' Classic
Orlando , Florida
Originally Posted by 66Overlander View Post
Hi Joanne,
Joe,
We initially used a wet swiffer because that's all we had (we were still at the dealer) and made about 6-8 passes, each with a fresh pad, pressing hard. Each pad was filthy afterwards but they gradually ended up a bit cleaner.
That mostly did the trick, but I didn't like using the swiffer pads and we abandoned them. Then we did a couple of passes on hands/knees using a microfiber rag and the only cleaner I use in the AS -- Mrs Meyers Clean Day Multi-Surface Everyday Cleaner, Basil scent, rinsing several times.
Since then, we've had no problems with the floor. I vacuum every day (takes two minutes) and on laundry day about once a week or less, we wash the floor with a swiffer-like stick product that uses a washable microfiber pad instead of a swiffer pad. We wet the pad and spray a little Mrs Meyers on the floor and scrub. Then we rinse the pad and go over the floor one more time to remove the cleaner. Then the microfiber pad gets washed/dried when we do the laundry.
We slip our shoes off at the entry and always go barefoot inside or on cold mornings, we wear socks.
I haven't noticed any fading.
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 14 09-26-2016 10:40 AM
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 2 10-26-2015 05:57 PM
Opinions Needed on Interior Design Issue in 34 Classic craftsman Full-Timing 23 02-14-2008 08:50 PM
Fabric Garages - opinions needed sigv Winterizing, Storage, Carports & Covers 25 04-19-2007 10:38 AM
Service policy opinions needed :) Kistler Our Community 8 07-20-2003 10:16 PM
