01-17-2017, 12:01 PM
#21
Pensacola
We're picking up our new 30' classic today. I have a question though: we want the solar panel option but this one doesn't have it. Is there anyway to add the AS solar option after purchase? The dealer is trying to sell us an after market product for which they would have to rivet into the ceiling. That doesn't sound like a good plan to me. Thoughts ? Thanks!
01-17-2017, 03:42 PM
#22
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
The roof is pre-wired. Lots of people know more than I do about the solar, we had it installed on our Classic just to charge the batteries while in storage as we do not boondock unless we have to. Any solar panels on the roof have to be drilled and mounted. Ours were as was our Satellite antenna. We've done both on prior Airstreams and not had any issue. I go up each year to check and make sure the caulking is holding up and when it's not I peel and replace.
Bud
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
01-17-2017, 05:02 PM
#23
2024 25' Trade Wind
Bothell
Check the solar thread. You might also want to check with member Lewster.
Enjoy the new classic.
01-18-2017, 04:08 AM
#24
Upper St Clair
, Pennsylvania
Great suggestion by charlesk and Lewsiter is down in Naples FL.
Bud
01-18-2017, 06:55 AM
#25
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Lew is also in the Eugene, Oregon area (in the summer) which is a few miles from AM Solar.
We were able to do a simple solar solution on the roof of our 2014 Classic. We have nine 100 watt AM Solar panels going into a Magnum MS-2812 inverter/converter (rated 2800 watts) via a TriStar solar charge controller and keeping a 600 amp-hour lithium battery full. Every outlet in the trailer is powered from either shore power or the battery. Can even run one air conditioner from the battery. One can use 90% of the power in a lithium battery where a Lifeline AGM battery may manage 50% and lead acid under 50%.
The factory 1000 inverter in their solar system can not even power their microwave let alone a toaster or hair dryer. The factory option system only powers three to four outlets (they have a blue sticker on them) to identify them as inverter powered outlets - they are dead when the inverter is off.
Note that the advertised "rating" for solar panels is a marketing tool. The real world power is 75% of that. So on a bright day and proper alignment with the sun, we might see 675 watts to charge the battery. On our 2015 23D International Serenity, we have five 100 watt AM Soar panels on the roof and usually see 360 watts to charge the 300 amp-hour lithium battery that weighs less than the two factory stock Interstate batteries.
One needs to chat with a solar professional, not an Airstream dealer, to get the job done properly. We used A&P Vintage Trailer Works in Paradise, TX for all of the modification work on both trailers and it was done properly the first time.
02-11-2017, 12:02 PM
#26
Glen Allen
, Virginia
02-11-2017, 12:41 PM
#27
2013 25' FB Flying Cloud
Bradfordwoods
, Pennsylvania
Congratulations and happy trails....
02-11-2017, 04:27 PM
#28
Reads a lot
Titusville
I bought the '17 Classic twin back in December and after a bit of a rough start getting to know about the heating system I Love it. I have had the pleasure of meeting one other couple in person that owns the same unit and find myself staring at theirs admiringly then it hits me that I have the same one. Silly. It is nice and I hope you will enjoy it for a long time.
02-11-2017, 07:01 PM
#29
Everyday is a GIFT !!
2015 30' Classic
Collins
, Mississippi
Congratulations [emoji898] and enjoy
J. Nelson
TAC # MS-12
WBCCI # 5314
AirForums # 66116
02-12-2017, 10:32 AM
#30
2016 26' Flying Cloud
Oxford Mills
, Ontario
AS backup camera and 200w solar system
Any reviews on Airstreams rear view camera and 200w solar pkg ?
Wasn't sure if there might be better value options out there....
Camera in cdn$ is 950 installed and 200w solar is 1800.00 installed.
Picking up our new 26u in a few weeks and still undecided about these two options
02-12-2017, 11:29 AM
#31
Glen Allen
, Virginia
I can't make any observations on the solar at this point, however, the wireless camera works well. I am coming from a 40' coach and the camera performs well and doesn't have any connection problems. The setup also has sound which works ok
02-12-2017, 12:42 PM
#32
Upper St Clair
, Pennsylvania
We only use solar feature when in storage as we only boondock if we have to. Camera is OK, I use it more while driving than when backing up, running lights must be on as that is where the camera is wired into.
02-13-2017, 07:47 AM
#33
2014 31' Classic
Apache Junction
Realize that solar panel ratings are based upon theory. The real performance is 75% of the literature number. So our nine AM Solar 100 watt panels on the Classic can in theory, on a great sunny day create 675 watts, - we have seen 625 watts. The 23D with five AM Solar 100 watt panels does make 375 watts.
The 200 watt option might create 150 watts. Airstream charges a very high price for the cheapest components they can buy. They do not place the panels with expansion in mind and the #10 wire they use is nearly maxed out on the long runs of the longer trailer models.
Before buying the way over priced Airstream option, read the solar primer at AM Solar to better understand what solar can and cannot do.
http://amsolar.com/diy-rv-solar-instructions/
Then read Lewsters posts. He is the resident solar guru on this forum.
Both of our trailers use the AM Solar packages with Magnum inverters and lithium batteries.
02-14-2017, 06:17 AM
#34
ObviouslyKnot
KAILUA
, HI
With regard to the camera, ours works much better, consistent connectivity, when I followed the pairing procedure, on screen at startup. The Service tech at delivery said, "Just turn it on, it pairs automatically." It does, it just does better when you follow the procedure. Hasn't blinked off since, with much stronger connect signal. Love it. And according to my Navigator, not allowed to back up without it ;-) On the road, it sits on the dash under the rear view mirror and is now an integral input to safe trailering.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
02-17-2017, 10:43 AM
#35
2016 30' Classic
Santa Barbara
A few issues to check on your new Classic
Originally Posted by Jtermini30
Got the call the other day the Classic is in!
2017 Classic
2014 RAm Eco Diesel
Welcome to the Classic club!
You probably are already familiar with other threads concerning new Classics: bathroom mirror detachment and the possibility of denting the fridge door on hard contact with the pantry handle. If not, be prepared to avoid damage in those two areas.
Otherwise, our first year's experience with our Classic has been very positive. We've put our rig to the test with a cross-country journey last Fall and enjoyed every mile!
02-17-2017, 01:52 PM
#36
Rich and Kat
Alexandria
Alexandria
, Virginia
Congrats! The Classics sure are perty, but then again, we may be biased.
Rich
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 3500 Laramie Crew Cab 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
KB2ZMF Save
02-17-2017, 05:49 PM
#37
Green Cove Springs
Fixed the refrigerator door ding situation using the push/pull flush mount knobs used in the Airstream Interstates. Made by Sugatsune.
Breathe In, Breathe Out, Move On
02-18-2017, 08:38 AM
#38
2016 30' Classic
Santa Barbara
Interstate pantry door pull solution
Originally Posted by mojoe7009
I sure hope the folks at the factory read this!
02-18-2017, 08:52 AM
#39
Green Cove Springs
The fix looks better now than when I took the picture. The second hole can still be seen in these pictures. I had just finished the installation but was in the process of filling and finishing the remaining hole. I don't have a picture right now but the holes are no longer visible. Here is the part number:
Sugatsune PK03CR Series Diameter (1.56") Knob,39.5 mm Diameter (1-9/16") PK-03
Exact ones used on the Interstates. Available on Amazon for $24.
02-18-2017, 08:54 AM
#40
Green Cove Springs
