Old 12-22-2018, 06:58 PM   #869
2018 30' Classic
2004 30' Classic
1972 Argosy 22
Meridian , Idaho
Originally Posted by turk123 View Post
I was wondering why my dinette seat on that side was a foot higher!
On my 2018 30' with a 3010 boiler they put the Alde Flow between the boiler and the outside wall. Snug but it works. No difference in dinette seat heights.
cbburke is offline   Reply With Quote
Old 12-23-2018, 08:38 AM   #870
Half a Rivet Short
Carlisle , Pennsylvania
Originally Posted by james.mileur View Post
When I asked JC, a couple months ago, was told about 5 gallons. I didn't get to it before winter storage, but plan to in the late spring.
He said it seemed like a lot for the loop, but the registers are multi-pass, not just straight through. But, there are two model years past the '17s we have, so who really knows.
Any of you over-acheivers out there could really help the rest of us '17 DIY-ers get 'er done with some shade tree stories.
What I've used for make up and plan to use for replacement. It matched the MSDS from Alde for the blue stuff. Pricing is going to drive the concentrate or one gallon premixed.
Camco 35116 Boiler Antifreeze... https://www.amazon.com/dp/B004804N7E?ref=yo_pop_ma_swf
Hi
In this case, if you are going with a concentrate, mix it with distilled water. Trusting the local tap water to be devoid of something nutty is not a good idea. The local grocery store should be well stocked with gallon jugs ....
Old 12-23-2018, 08:41 AM   #871
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Absolutely, and everything including hands needs be clean, clean, clean when refilling.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 12-24-2018, 07:14 AM   #872
Half a Rivet Short
Hi
One unanswered question - do you do a flush before you do a refill? If you flush, what do you do it with and how much of it?
Yes, I know people who get obsessive about oil changes and can't understand why the rest of the world does not do a rinse step.
Old 12-24-2018, 10:12 PM   #873
2018 33' Classic
Silverdale , Washington
Had my system flushed by my local AS dealer and Alde, DI water was used. Not sure if a flush is recommended or required prior to replacing glycol, Spencer at Alde could answer this question.
CWO7241 is offline   Reply With Quote
Old 01-11-2019, 06:55 AM   #874
2018 30' Classic
Traverse City , Michigan
I’m so confused by so much information. We’ve had our 2018 30’ Classic for about a year and a half. We’re currently in FL during a real cold streak. When the heat is on we’ve always heard some “gurgling”. Now when the heat comes on it sounds like it’s raining in various areas. Wakes me up at night. Is this normal?
Motorhomes were our choice for 40 years and decided to get rid of the stress and experience more flexibility in travel.
2018 30í Classic
SMKovalchik is offline   Reply With Quote
Old 01-11-2019, 12:41 PM   #875
Obviously-NOT
Kalispell , Montana
(Ms. Lauri, coffee alert)
Well, it could be normal if you are a light sleeper
The gurgling you might hear when the circ pump runs for heat is the expansion tank in the cabinet above the toilet (circa 17). If you top it off, less gurgling, but still normal. Sort of a cold weather ambiance to let you know all is well with heat.
The raining sound is new; could be an air bubble in the register near your bunk. AS told me they were multiple pass registers, hence the 5 gallon volume for a 70' loop. So, this will mean 3 passes thru each register, 2 internal elbows, and perhaps you hear the ambiance of the Alde waterfall.
Or it was just raining outside.
The real question was were you comfortable (temp wise)?
Old 01-11-2019, 12:58 PM   #876
Obviously-NOT
Kalispell , Montana
Originally Posted by cbburke View Post
Century Transfer Fluid is available on Amazon for $25 a gallon or $16 a quart for concentrate.
https://smile.amazon.com/gp/product/...ED39JHPWFZ4AH9
James, Your camco link did not work when I tried it??
Yup, looks like they dropped it. I've bought it at RV shops at about $15 a quart concentrate. It was CAMCO 35116 Boiler Antifreeze Concentrate.
Old 01-12-2019, 04:43 AM   #877
Reads a lot
Titusville , Florida
smkovalchik, ditto what James said. Try topping off the tank first then maybe bleed the valves nearest to your pillow. (Although I haven’t ever heard the gurgling in the bedroom I can hear the tank when I’m sitting at the dinette.) If you’re still hearing the sound after toppling of the tank you may need to bleed all the valves but I’m guessing that just filling the tank will do the trick.
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 01-13-2019, 10:29 AM   #878
Half a Rivet Short
If it's really quiet out and you are in the bunk on the side by the bathroom, you can indeed hear the gurgle in the bathroom tank from bed. Indeed, we keep the bathroom door open at night due to multi dog traffic issues in the hall. That may have some bearing on the noise level.
Old 01-14-2019, 05:26 AM   #879
2018 30' Classic
I think I need to clarify our issue. The gurgling isnít just in the bedroom and certainly not under my pillow, itís coming from most of the heating areas, living area and bathroom. The solution is to have it serviced when we return from a Florida.
Thanks for everyoneís help.
2018 30í Classic
Old 01-14-2019, 06:50 AM   #880
Obviously-NOT
Kalispell , Montana
Gr8, please post the "rest of the story" about the rainfall noise. Thx.
Old 01-14-2019, 10:09 AM   #881
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I also have heard that sound. Mine happened once under the sink area. To me, it was like a hose was pinched and the fluid was bubbling and rushing past. Your description that it sounded like "rain" seems very appropriate.
I am not an Alde expert, but I believe when the air gets trapped in a large bubble in the hose, the fluid is somehow forced by while the air bubble remains in place causing the rushing sound. I've bled my system four times since then and I have not heard that sound again.
You may have excessive air in the system.
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
***Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 01-14-2019, 12:18 PM   #882
Obviously-NOT
Kalispell , Montana
So here are some basic heat transfer and fluid flow ideas. Your circulation pump (all circa 17) will run even if fluid cannot flow due to a restriction, air or otherwise. Just runs and beats up the water; think vacuum cleaner with your hand over the nozzle. On my trailer, the flow goes clockwise from the boiler around the trailer, expansion tank is on the suction side of the loop, at the bathroom, in line with the biggest bubble catcher, the towel rack. I suppose if the rack was, not warm, and nearly full of air, the pump with speed set at 1, like mine was, might not be able to push against that bubble uphill from the bedroom and displace the bubble, backwards against flow forward. Little to No heat from registers.
Have you tried the easy vent at the top of the towel rack? Could be a game changer.
If you look at the side of the circ pump, small surface switch, set to 3 or 4? Under the forward dinette seat.
For air in the registers, if they are 3 pass, and the first pass is on top in line with flow direction, I could imagine a hot fluid flow stream-bubble interface, with fluid trickling through the passes, and a sound like rain. Some heat, but far from design output. I haven't verified multi pass yet, or that might be an upgrade after 17. Individual registers have vents on one end or you can follow the manual instructions and tilt the trailer full up and down (Rig ship for angles and dangles.) and hope the air travels around and works its way to the auto vent valve of the boiler, hope it opens as designed, and hope it doesn't stick open and drain your system. Have I mentioned how hope isn't a plan or solution I recommend.
You may need to just burp your system a bit. Depending on the dealer, you may already know more than the actual technician assigned to your service. Or not, and it will be an easy service and just charge for the Alde fluid.
alde heating system old vet General Repair Forum 1 01-23-2017 11:05 AM
Alde system classic twin cegardner 2006 - 2010 Classic (all lengths) 1 01-06-2017 05:35 AM
What Alde system does Airstream Use. Lets travel Classic Motorhomes 14 10-12-2016 07:54 AM
ALDE LP Radiant heat? Zybane 2016 - Current Classic (all lengths) 1 05-06-2016 04:39 PM
