Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Classic > 2016 - Current Classic (all lengths)
Old 11-10-2021, 04:32 AM   #981
2018 30' Classic
Traverse City , Michigan
We have an ‘18 Classic and the Alde system has been a major problem from day 1. Virtually all major components have been replaced (it’s a 3010). The last time Airstream said they were done paying for it. Great, a company that wouldn’t back its product when the entire process was well documented. Well, the system failed again. Finally a member posted on one of my posts the phone number of Truma (relatively new owner of Alde). They have been wonderful and we have an appointment for repair or replacement. In the conversation it was mentioned that Airstream had issued a recall which we never received. Anyway, it appears we will finally have the issue solved after over 3 years of frustration. (We were to trade & leave Airstream.)
Our experiences led us to believe the 3010 is faulty.
Motorhomes were our choice for 40 years and decided to get rid of the stress and experience more flexibility in travel.
2018 30’ Classic
SMKovalchik is offline   Reply With Quote
Old 11-10-2021, 10:54 PM   #982
2018 30' Classic
2004 30' Classic
1972 Argosy 22
Meridian , Idaho
We have a Sept 2017 built 2018 Classic 30'. It has a 3010 boiler with an Alde Flow. After a brief period of getting it adjusted correctly it has worked as described. We did move the control panel out from under the sink. It works with the FireFly although there is a differential with the temperature setting. It has kept us warm with outside temps in the 20's so far. Hot water takes a moment to get to the curbside faucets it has always been adequate to the job. The boss likes it so I like it.
cbburke is offline   Reply With Quote
Old 11-11-2021, 04:37 AM   #983
2018 30' Classic
Interesting. Our dealer said Airstream told them the control panel couldn’t be moved to the outer wall. Sounds like our dealer is at least part of the problem.
2018 30’ Classic
Old 11-11-2021, 04:52 AM   #984
JDG
Riveted
JDG's Avatar
2018 33' Classic
Charleston , West Virginia
I have the same experience as cbburk above. Dec 2017 build on a 2018 33 Classic. Alde 3010 Flow connected to the Firefly system. Works great. Had the recall done at JC (fluid change & ground installed). Works as advertised with no complaints.
JDG is offline   Reply With Quote
Old 11-11-2021, 06:54 AM   #985
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Never had a problem with our Alde and we've used it a *lot*.
What Alde system does Airstream Use. Lets travel Classic Motorhomes 15 06-06-2021 06:14 PM
Alde system classic twin cegardner 2006 - 2010 Classic (all lengths) 2 02-18-2019 06:38 AM
alde heating system old vet General Repair Forum 1 01-23-2017 10:05 AM
ALDE LP Radiant heat? Zybane 2016 - Current Classic (all lengths) 1 05-06-2016 03:39 PM
