08-13-2018, 06:05 PM
#61
Ocala
We have a 2017 Classic 30 Twin delivered in September 2016. I had a flat on the passenger rear wheel. And, indeed mine had the fake cover over the lug nut and one out of six split during the wheel removal and reinstallation after repair. I am not sure that I understand why Airstream would use these cheapy lug nuts on a unit with a MSRP of $139,000! I recently visited JC and purchased the solid lug nuts. I would strongly suggest that anyone with this unit change to the solid lug nuts before you have a problem on the road. Best wishes. Ray
09-11-2018, 09:00 AM
#62
2016 19' International
Orange County
Originally Posted by mojoe7009
...replace them with quality, REAL CHROME lug nuts from McGard before you need to remove a wheel. Here a couple of pictures to illustrate the difference in the two and the replacement McGard packaging showing the item number:...
I can't thank you enough for taking the time to post this information!
I took heed to your advice and ordered the McGard chrome lug nuts. 9 of the factory nuts with chrome caps came off with ease. 2 gave me some trouble and I had to hammer the socket onto the cap for it to get enough bite to finally unscrew.
The last simply would not come off. After 2 days I gave up and called AAA who sent out a tow operator who couldn't get it off and ended up scratching my Sendel wheels in the process. He clearly didn't know what he was doing as he was trying to use a crescent wrench.
I ordered a 3/4" lug nut remover socket from Performance Tool which was worthless. It had a reverse spiral design rather than the rounded edge type.
I stopped by my local tire shop and luckily they knew exactly what to do. They had a Snap On brand lug nut remover set with the rounded edge design and was able to remove my last stripped lug nut. I'm glad I was able to get this done before hitting the road!
09-11-2018, 03:03 PM
#63
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
I changed ours shortly after MoJo posted. Glad we did with the brake issues I'm sure I'd have had problems as i've had wheels off at least four times now and on Thursday they all come off again and manual adjusting brakes go on.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
10-29-2018, 09:49 AM
#64
2013 28' International
Bozeman
, Montana
So, I'm getting ready to order the McGards before we head south and am confused on which ones to order, the #64010 or the #64000. I take both will work, Airstream is putting the 64000's on the new units, but the 64010 take the same size socket as the old chrome capped disasters. I'm running the 16" Sendal wheels if that makes a difference. Any additional clarifications appreciated since I don't want to order the wrong ones. Thanks!
10-30-2018, 08:48 PM
#65
2014 28' International
Blacksburg
, Virginia
64010
You want the 64010. They are just a touch taller and the stud will not bottom out in that nut. You don't want a shorty. I think I saw you could get by with the 64000, but 64010 have delivered excellent service.
I'm trying to keep all mine uniform with the 64010. I saw that the price increased a bit, last time I bought a pack of four. The people that make them have to live to. Made in USA,
Safe travels and have a good one!
Ra & Chelle
For my next trick, I will use my new AS & Dodge Ram CTD to make this pile of money disappear.
10-31-2018, 08:31 AM
#66
2023 27' Globetrotter
Pleasant Garden
, North Carolina
So, from this I take it that AS is putting solid nuts on the trailers being produced now. My 30' Classic is coming 12/4 and I want to have new nuts available if I need to when I install my Centramatics .
05-26-2021, 02:24 PM
#67
2016 19' Flying Cloud
San Francisco
Albeit a late arrival to this post, much thanks. I just had to pull a flat tire and discovered my 2016 Airstream has the lugs with the chrome covers. It was a royal B to get the lugs off. I'm having my tires replaced (at 5 years now) and plan to switch out the lugs.
05-27-2021, 06:48 AM
#68
Ocala
Hi Terry, the 2017 Classic does not have solid lug nuts. I have a 2017 Classic and it had the covered lug nuts. Ray
Ray
2017 Classic 30' Twin
Tow Vehicle 2020 Ram 2500 Laramie
