12-13-2017, 06:00 PM
2016 30' Classic
Hinckley
, Ohio
Is there any differences in 2017/2018 30’ Classic?
I was wondering is there any differences between 2017/2018 Classics?
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
12-13-2017, 07:13 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Yes, there are differences between the 2017 / 2018 versions. If you dig around a bit, you will find some long threads on the changes to the Firefly and Alde system integration. There also is a boost heater on the hot water in the 2018. Pretty much all 2018's got "upgraded" converters. It's not real clear just how much of a change that really is.
Options wise, there are some changes between years. The 2017 had very few options (everything but the backup camera was stock). The 2018 moved some of the stuff back into the "optional" category. If you order both years with "everything" there is no difference in that respect. If you ordered a base model 2017 it would have more on it than a base model 2018.
12-14-2017, 11:39 AM
2016 30' Classic
Hinckley
, Ohio
Uncle Bob your the only one who keeps up on this stuff.
Only one response.
Really it doesn’t sound like a lot of changes in this model then.
12-15-2017, 04:15 AM
2018 30' Classic
New York
, New York
One little minor change I noticed was that some people with older Classics and I don't know for sure if was 2017, talked about the handle of the pantry that protruded and could dent the refrigerator door. The 2018 has a recessed push button handle on the pantry that eliminates that risk.
12-15-2017, 04:55 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
Only one response.
There is a major change in the Alde system as well as the operation of same. The 2017 was a stand alone system, operating within itself to provide both heat and hot water. The 2018 has a supplemental pre-heater for hot water. In addition the Firefly system now operates as the main control feature of the 2018 Alde with a back up 2017 version of the 3010 system under the kitchen sink.
Those are the main changes I'd be considering if I were in the market. Seems there were some "start-up" issues with the Alde communicating with the Firefly, but those seem to have been corrected with some new firmware updates.
Bud
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
12-15-2017, 06:31 AM
2020 30' Classic
Norman
, Oklahoma
We have an 18 and another change is that the dinette is a bit longer to fit taller people. They also did away with the backlights on USB ports in bedroom. As to options in the 18’s. For the 30’ anyway, it was drawers instead of standard oven and solar.
12-15-2017, 08:12 AM
2020 30' Classic
Norman
, Oklahoma
Oh, and the 18’s have a more powerful tongue jack motor. We have automatic/motorized stabilizers too...not sure if that was in previous years.
12-15-2017, 08:27 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The 2017's came factory stock with electric stabilizer jacks and the tongue jack. The solar package was standard. If you wanted drawers instead of a microwave you had to ask for it to be built that way. If you are trying to compare prices or something like that, this all matters. As far as the actual trailer ... no real impact.
Not real sure about the dinette change. The table is motorized. It will go higher than you would ever want to set it on a 2017. The comfortable setting (even if you are 6' 4") is a couple inches down from "max".
12-16-2017, 08:19 AM
2016 30' Classic
Hinckley
, Ohio
This was a list of new features on Airstreams web site for 2017 Classics
Lighter Cognac Maple décor
Alde Hydronic Heating System for silent heating
Heated bath towel bar and shower floor
More comfortable sleeping on dinette with added length
Touch panel electronic control system
Enhanced custom-tuned Polk audio system and 200W subwoofer
Rear view camera and wireless monitor now standard
Repositioned privacy curtains
Latching table stabilizer leg
ZipDee power awning now standard and includes power cutoff feature
Updated Aluminum LP tank cover with better clearance
4 external pre-wired solar ports (3 on the roof, 1 near the hitch)
Added more USB ports
12-16-2017, 08:53 AM
2016 30' Classic
Hinckley
, Ohio
And this is 2018 Classic 30
Continuous hot water feature with the addition of Alde flow
Updated electronics featuring complete control over A/C & heating systems
New larger, color touchscreen multiplex control pad
Redesigned pantry & trunk compartment lids (30RB)
Emergency manual override switches for air conditioning system
Upgraded electrical system including a multi-stage converter and an improved battery disconnect feature
Combined inverter outlets eliminate need for secondary outlet
Dedicated HDMI wall plugs and wiring to articulating TVs
“Handcrafted in Jackson Center, Ohio” badge on screen door
12-16-2017, 09:13 AM
ObviouslyKnot
KAILUA
, HI
Automatic?
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
12-16-2017, 09:15 AM
2018 30' Classic
New York
, New York
That hand crafted in Jackson Center badge was easy to miss. I had to look for it.
12-16-2017, 09:20 AM
2016 30' Classic
Hinckley
, Ohio
Do the 2017/18 still have heat pumps? Or are they AC only?
12-16-2017, 09:21 AM
2018 30' Classic
New York
, New York
They have heat pumps on 2018.
12-16-2017, 11:45 AM
Cave Creek
Another difference I learned was an added bracket on the adjustable bed(s) to secure the mattress when is being raised
Pete B55
2017 Classic
2017 F-250
12-16-2017, 11:58 AM
2020 30' Classic
Norman
, Oklahoma
Originally Posted by james.mileur
Automatic?
Well, automatic in the sense that you open a locked compartment outside and press the button to lower front then the other button for the back...as opposed to the crank or electric drill method.
