Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Classic > 2016 - Current Classic (all lengths)
Old 01-02-2020, 07:37 AM   #1
Carey Box
2019 30' Classic
2015 27' Flying Cloud
2013 25' FB Flying Cloud
Franklin , Tennessee
Inverter and CZone
Happy New Year, everyone! On our 2019 Classic, the inverter turns on automatically whenever we choose the “Cinema Mode” from the CZone. This is when we are fully connected @30 or 50 AMP.
I cannot find and reason for it to turn on, nor can I find anything in the literature to suggest it should.
Any thoughts!
Thanks all,
CB
basicbox is offline   Reply With Quote
Old 01-02-2020, 07:53 AM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Apparently that’s a program error. I’m in a 30, so not sure if there is a fix for this. You’ll just need to turn off the inverter if you press cinema mode or do it the old fashioned way and lower each window individually like us non power black out folks [emoji12]
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 01-02-2020, 07:56 AM   #3
2020 30' Classic
Star , Idaho
Same with my trailer. I just assumed it was normal. I think life would be just fine without any modes. "Away" is the only mode I find useful.
StarCamper is offline   Reply With Quote
Old 02-02-2020, 12:34 AM   #4
2020 30' Classic
DALLAS , Texas
My 2020 Classic does the same thing.
Phantom98 is offline   Reply With Quote
Old 05-15-2020, 09:25 AM   #5
2020 30' Classic
Crown Point , Indiana
2020 classic 30rb does the same. Thanks to all for confirming its an issue with all and not just mine.
Jczatorski is offline   Reply With Quote
Old 05-16-2020, 02:06 AM   #6
2018 30' Classic
Classic 30 doesn’t have cinema mode???
BigSxyWhtGuy
Old 05-16-2020, 06:05 AM   #7
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Ok so I’ve been deep in the guts of the 30’ classics and here is what I know.
With the C-Zone in Cinema mode the inverter will always come on. It’s one of the commands programmed into that setting. Why you might ask..... well when you are in “Cinema’ mode the Trailer has to assume you are not connected to shore power in order for that mode to work all the time, so the inverter Relay is programmed to close switching on the inverter to run the TV and BlueRay player.
If you are on shore power the program still runs the same, switching on the inverter.
This creates a problem when on shore power not because the inverter is sending power, but because of the heat the inverter naturally creates and the cooling fan noise associated with that heat.
On a recent install I did. I removed the factory inverter for a much larger Victron MultiPlus 3000.
This process of the new install eliminates the problem but is an expensive solution.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
CZone app skiphoyt Sprinter and B-van Forum 23 10-09-2022 06:19 PM
CZONE Display Reset? PaulR-GA 2016 - Current Classic (all lengths) 18 08-06-2020 08:10 AM
CZONE replacing fan with MaxxFan The Naker 2016 - Current Classic (all lengths) 21 03-15-2020 07:49 AM
CZone and Multiplex Interfaces In General Re-Pete 2016 - Current Classic (all lengths) 10 05-26-2019 09:11 AM
Regarding Multiplex Interface Systems such as CZone, etc. Re-Pete Electronics & Connectivity 0 04-16-2019 10:53 PM
