Old 03-10-2019, 12:49 PM   #1
TimT's Avatar
2019 30' Classic
Clovis , California
House to trailer electrical Connection
I am purschasing a new 2019 Classic 30 which won't be delivered until the middle of May...built date is April 23 at the factory. I am new at this, and need some advice on what would be the best way to power up the trailer prior to taking it out on the road.
My question is should I have a 50 amp outdoor outlet installed to run the trailer and charge it etc.....I will be parking it on the side of my house next to the garage, and electrical outlet box. I have a nice 35 foot concreate pad for it, or can I use something less to run all the components. I want to ensure everything is working and maybe use it on occasion while it parked. It get pretty hot here in California during the summer so I thinking I may need both A/C units working....
What do you think?
TimT is offline   Reply With Quote
Old 03-10-2019, 01:11 PM   #2
2017 23' International
hendersonville , North Carolina
Power for new Classic
Congratulations on your soon to be built Classic! Welcome to the Airstream world. Have an electrician install a 50 AMP RV outlet box to power it up. Make sure it is wired for 110v not 220v. It would not be the first time that mistake has been made.
You may want to check with local codes to insure your allowed to park it next to your garage. Some places have restrictions. Happy travels.
uraljohn is offline   Reply With Quote
Old 03-10-2019, 01:16 PM   #3
Jugadorone's Avatar
2019 30' Flying Cloud
Lucedale , Mississippi
If you want to run everything,,you need the 50 amp box,, If you just want to run some lights and keep your battery charged there is a 50 amp to 15 amp connector that you can use. You just bought a brand new bad ass 30' Classic,,,.spring for the 50 amp box and never worry again about it.
The 50 to 15 amp is handy to have ,,its only 20 bucks.
LeisureCords Trailer dogbone power cord plug adapter 15 amp male to 50 amp female locking connector with LED Indicator (15 Male - 50 Female Twist)
by Leisure Cords
Jugadorone is offline   Reply With Quote
Old 03-10-2019, 01:26 PM   #4
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
If you donít already have one, a 50 amp to 30 amp conversion plug is also a good idea since campgrounds donít Always have 50 amps.
az-streamer is offline   Reply With Quote
Old 03-10-2019, 01:27 PM   #5
Jugadorone's Avatar
Also since you say you are new to this I cant stress the importance of a departure check list of some type. There are many threads on here about it. Don't let something happen that was preventable.
Old 03-10-2019, 01:31 PM   #6
Jugadorone's Avatar
As AZ-Streamer said the 50amp to 30 amp is good to have but if you have to use it I believe you can only run one air conditioner at a time,,some body correct me if i'm wrong.
Old 03-10-2019, 01:43 PM   #7
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
If you donít plan on running AC etc and you just want to tender your battery, a standard plug is fine if you have all the step down cords. Before we went full time, all we had was a standard plug at our RV slip next to our house. That worked fine, but we didnít need to heat or cool it while it was sitting there. Just wanted to prevent batteries from draining while it sat idle.
BigSxyWhtGuy is offline   Reply With Quote
Old 03-10-2019, 01:48 PM   #8
2012 Avenue Coach
Corpus Christi , Texas
What do you think?
Welcome to the forum TimT!
rowiebowie is offline   Reply With Quote
Old 03-10-2019, 01:53 PM   #9
Long Island , New York
My question is should I have a 50 amp outdoor outlet installed to run the trailer and charge it etc.... . . . thinking I may need both A/C units working....
Yes, you need a 50 amp outlet of the proper kind for 120 volts AC, as already mentioned. Welcome to the forum!
Happy Trails!
Peter
Old 03-10-2019, 07:52 PM   #10
2019 30' Classic
Pleasant Garden , North Carolina
We took delivery of our 2019 Classic 30 on Jan. 4, prior to taking delivery we had 50amp service installed. The first 5 nights we spent in the Classic was in our drive way. We were able to practice using all the different systems and get comfortable with the trailer before we ever went to a campground.
jlandreth is offline   Reply With Quote
Old 03-10-2019, 09:52 PM   #11
TimT's Avatar
2019 30' Classic
Clovis , California
Thanks everyone for the advice.....I will plan on getting it installed prior to delivery date. I appreciate your comments and advice....
TimT
Old 03-10-2019, 10:57 PM   #12
Napa , California
Add solar and you make might not need add any electrical or power cords! We added solar for less cost than a power cord and our trailer is always charged and ready go. Not bad for occasional boondocking, either.
Atwebs is offline   Reply With Quote
Old 03-10-2019, 11:27 PM   #13
SailorSam205's Avatar
Northville , Michigan
You could consider getting one of these. Same power pedestal box you see in a campground. Has the correct outlets for powering an RV. There are other models and suppliers.
http://www.rvparksupplies.com/p/503020AMPSMPOWER/
Al
2017 26' SOB, 2018 F-150 SCrew, ProPride
SailorSam205 is offline   Reply With Quote
Old 03-11-2019, 09:43 AM   #14
caz
2018 30' Flying Cloud
Elgin , Texas
FYI, We installed a 50 Amp Box in our RV shelter in the driveway. City ordinances did not allow us to install a sewer dump. We like the piece of mind that our Flying Cloud stays fully charged & both AC units operational. We use the Airstream for overflow guest sleeping when we are not traveling.
caz is offline   Reply With Quote
Marinco Electrical Connection Roadrunner Batteries, Univolts, Converters & Inverters 15 09-11-2017 09:19 AM
Electrical connection from trailer to TV McDave Tow Vehicles 37 11-23-2016 10:03 AM
Stainless steel upgrade for TV/Sat connection and exterior electrical outlet on curb GLovedahl Exterior Storage Compartments & Access Doors 2 03-13-2015 07:38 AM
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 07:24 PM
failed electrical connection on brakes on one side only Tin Diesel Brakes & Brake Controllers 3 04-20-2006 02:02 PM
