Old 07-17-2019, 09:28 AM   #1
2019 33' Classic
Oakville , Ontario
Holes in the floor of my 2019 Classic 33
I removed the aluminum kickplate below the desk area while I was routing some Ethernet cable. I discovered two 2" round holes and could see through them right to the ground. Any mouse or critter could simply climb in and have full access to my trailer.
I sealed these holes but now wonder if there are more that I should fix. Anyone come across others?
Also, isn't there supposed to be some insulation in the floor? These holes show that part of the floor is just plywood and nothing else.
The Naker is offline   Reply With Quote
Old 07-17-2019, 10:37 AM   #2
2016 30' Classic
Lorton , Virginia
Airstream has no quality control. As soon as you remove any cover or access panel, you find that out VERY quickly.
Aitstream's also do not have insulated flooring. Welcome to the jungle.
Zybane is offline   Reply With Quote
Old 07-17-2019, 10:55 AM   #3
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
That picture disturbs me a lot. How is anything like this permitted in a $150,000 trailer? I would contact customer support and send them the pictures. Ask THEM how they are going to fix this issue.
I see you are from Canada. Have Airstream send the dealer you bought it from to your house with the "authorized" repair.
This is by far the most shocking, appalling, horrific, horrifying, horrible, terrible, awful, dreadful, grievous, gross, ghastly, hideous, horrendous, frightful, atrocious, abominable, abhorrent, outrageous; monstrous, nightmarish, heinous, harrowing, dire, unspeakable, shameful; flagrant, glaring, blatant, scandalous, unforgivable, unpardonable, intolerable issue I have ever seen.
Hallelujah! Holy shxx! Where's the Tylenol?
Open-air access to the inside of the trailer. Can you imagine if it is parked on the side of your house for a winter? Mice, bugs snakes . . . .
This really is not funny.
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 07-17-2019, 11:00 AM   #4
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
You sealed the holes? How is this not going to freeze? You have pipes that are normally protected by the heated tanks. No protection when the snow and wind are blowing into the space below the floor.
I would take a second look at this with your dealer or Jackson Center.
Old 07-17-2019, 11:07 AM   #5
2019 33' Classic
Oakville , Ontario
Good point on the freezing. I covered the holes for now so mice won't get in. I'll follow up with Airstream on this. BUT I am still also concerned about what I haven't found.
Old 07-17-2019, 11:15 AM   #6
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Wow. Can you post a pic from the outside where the opening is?
pcskier is offline   Reply With Quote
Old 07-17-2019, 11:15 AM   #7
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I was being funny with my first post, but I am dead serious about this build quality. This truly disturbs me. Why expose your customers to frustrating spring when they find out all their plumbing has frozen and busted.
You really need to make JC aware of this issue. Your picture says it all. I'm sending an image to a little birdy I know.
Old 07-17-2019, 01:25 PM   #8
CWSWine's Avatar
2019 33' Classic
Manhattan , Kansas
Good find, how did you seal them up? I will check mine this week and see if mine looks the same as yours.
Dennis & Ellie
2019 Ram 2500 Longhorn 6.4 Hemi w/2868 payload on the Yellow Tag.
2019 Airstream Classic 33FB Dry Weight 8595 Tongue 1230
CWSWine is offline   Reply With Quote
Old 07-17-2019, 06:37 PM   #9
Half a Rivet Short
Carlisle , Pennsylvania
Hi
That's how they do it and have done it for a long time. If you snug the pipes tight to the floor they "work" against each other and break. If you seal it up, do it with something that will flex a lot.
Old 07-17-2019, 07:06 PM   #10
dznf0g's Avatar
Oswego , Illinois
Hi
X2^ I just stuff fiberglass insulation in these areas. However some are there for heated tank air return. Study closely before closing any holes. Also, the areas of flooring over the tank pans are not insulated. Other areas are....at least on mine..albeit only with reflective bubble sheet.
-Rich-
Old 07-17-2019, 07:27 PM   #11
2019 33' Classic
Oakville , Ontario
Hi
Understood. I had used some 3M auto insulation and capped with flexible vinyl cut to fit (and taped with aluminum tape). Maybe I'll remove the vinyl and figure out how to seal up the underside instead.
Old 07-17-2019, 08:00 PM   #12
2020 Classic 33 on order
Box Elder , South Dakota
Just looked at mine on my 2020 Classic 33 and there is insulation (silver backed board type) and no evidence of opening to the outside.
From the outside the daylight that you see in your first photo is the front side of the water service bay. That is also open on my trailer, worth sealing up. I'm guessing that one of the lines is for fresh water connection and the other is for the black flush line. If you take the cover plate off in the upper left under the desk you can see the back flush preventer valve. Also the same cover is used to get to one of the Alde bleeder valves.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 07-17-2019, 11:15 PM   #13
pcskier's Avatar
Park City , Utah
Hi
Expand the picture and have a look again...I think you missed it. He's not talking about the holes in the floor for the plumbing...if you look through the right hole down below you can see daylight and grass! That's what the concern was I believe.
Old 07-18-2019, 03:34 AM   #14
Long Island , New York
^^^^^ x2
Sorry for your troubles.
GMC 1500 AT4 2019 & Airstream Classic 30RB 2019 mikebrownvb Towing, Tow Vehicles & Hitches 54 07-15-2019 11:33 AM
Floor replacement - c-channel bolt holes slipped 1in off frame holes tshannon Repairing/Replacing Floor &/or Frame 2 07-21-2016 04:07 AM
New toilet holes don't match old holes RichHog Sinks, Showers & Toilets 8 03-15-2009 06:36 PM
Extra factory holes in Plywood Floor Cos Repairing/Replacing Floor &/or Frame 4 08-07-2007 02:41 PM
Screw holes in Tradewind floor yochanan Repairing/Replacing Floor &/or Frame 1 01-21-2006 11:50 PM
