Old 07-19-2019, 03:07 PM   #43
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Originally Posted by CWSWine View Post
You mention "Pest Block Foam" is this what you were talking about?
https://www.amazon.com/Spray-Foam-Se...gateway&sr=8-5
Yes, thatís the stuff.
Rocinante is our 2014 International Signature 27FB
Old 07-19-2019, 03:32 PM   #44
2019 33' Classic
Oakville , Ontario
I found the 3/4" gap in the underside that I could see from the holes. I used some angle aluminum stock I had with caulking and got it sealed up.
I also checked the entire underside and found a few other spots. Strangely, the metal sheet that covers the entire bottom of the trailer wasn't fastened along several perimeter stretches of 4+ feet at a time. It sagged 1/2" in those places. Other areas have either rivets or self tapping bolts fastening the sheet to the frame.
ID:	347084   Click image for larger version
The Naker is offline   Reply With Quote
Old 07-19-2019, 03:56 PM   #45
Rivet Slave
Rocinante's Avatar
The huge gaps of unfastened material under the belly are not just strange - they sound unacceptable. This merits a long serious chat with Airstream customer service and your dealer.
Keep looking. My instincts tell me that with this unit there's a good chance you'll find other "interesting" issues and it would be helpful to find as many as possible long before the warranty expires. For starters, within the first six months, schedule a visit to your dealer to have them inspect all the seals between all your aluminum sheets to ensure there aren't any leaks, and to repair under warranty any suspect joints they may find.
Old 07-19-2019, 04:44 PM   #46
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
That just seems like something was not right. Would love to see a pic from another Classic 33 owner showing what that area looks like.
Meanwhile, nice fix.
pcskier is offline   Reply With Quote
Old 07-19-2019, 05:52 PM   #47
CWSWine's Avatar
2019 33' Classic
Manhattan , Kansas
I didn't have time to pull the panel in the inside but I will get that done tomorrow. I got on a creeper and check the entire underneath and found zero issues that weren't already sealed with some black foam. What I did find in my city water hook area is the pic below that would allow mice into the underbelly of the AS. I do question the rivet spacing but that because I was aircraft tech inspector for 16 years.
Dennis & Ellie
2019 Ram 2500 Longhorn 6.4 Hemi w/2868 payload on the Yellow Tag.
2019 Airstream Classic 33FB Dry Weight 8595 Tongue 1230
CWSWine is offline   Reply With Quote
Old 07-19-2019, 05:58 PM   #48
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Very good job in sealing that up. What are the other areas that I have arrows on? Where does that upper area go?
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 07-19-2019, 06:14 PM   #49
2011 28' Flying Cloud
Orillia , Ontario
Holes covered up
That reminds me of the holes I found when I removed my dinette bench.
Airstream when I contacted them would not even send me a new sheet of laminate to reapply on wall.
If I was Airstream I would fix problem fast, I would like to believe the work force there cares about there jobs and have pride in there work, but left unchecked can be these type of issues.
All problems start in one location.Click image for larger version
Rust is offline   Reply With Quote
Old 07-19-2019, 06:30 PM   #50
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
All problems start in one location.Attachment 347090
That square hole looks like the cutout used to run the large expandable tubes for the furnace on a 27'-28'. The furnace was further up in your picture toward the front. Duct hose ran to under wardrobe where there was a vent.
Old 07-20-2019, 12:19 AM   #51
Miami Beach , Florida
After reading the dozens of posts here about these issues with holes and gaps on AS it makes me sick to my stomach. I think it is appalling that they can not solve this simple issue after building these things for decades! Absolutely ridiculous. And for the price they want, this issue should NEVER happen. So sad.
rsementi is offline   Reply With Quote
Old 07-20-2019, 06:08 AM   #52
2013 20' Flying Cloud
Westerly , Rhode Island
Wow! Sick to your stomach? And you don't even own an AS? You must be a very sensitive person, or a drama queen.
smithcreek is offline   Reply With Quote
Old 07-20-2019, 06:27 AM   #53
Gainesville , Florida
Plug the holes and go on with your lives. These things are what they are. If you spent your money without doing research, well!
Old 07-20-2019, 08:09 AM   #54
CWSWine's Avatar
2019 33' Classic
Manhattan , Kansas
You need to go over to IRV2 and check out the Provost forum that cost north of 2 million dollars and read all the problems they are having with brand new coaches. I have own Montana, Cougar, Solitude and Fleetwood Class A and so far I had fewer complaints/problems about the AS then any of the others. My entire reason I purchased a AS is less things to go wrong include slides.
Dennis & Ellie
Old 07-20-2019, 09:16 AM   #55
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I think what kind of "shocked" me was seeing the grass through the floor.
Recently we've seen awning controllers that obviously were being diagnosed but left lying on the floor under a cabinet with a screwdriver next to the two controllers. Awning fails. My battery disconnect switch on the door panel with no function at all. Subwoofer and Alde systems with no attempt to set them correctly for the customer or even have them functioning at all. Wires buried in walls and not reaching their destination.
Very obvious things. Easily fixable things.
I'm not going to go into the quality control rant now, as I like the Airstream product. I also know that everything here will be repaired with no questions by the factory guys. I just would like to see my favorite RV company pay attention to the details. Is anyone at Airstream looking or checking their work?
So far we are.
Old 07-20-2019, 01:58 PM   #56
CWSWine's Avatar
2019 33' Classic
Manhattan , Kansas
I got around to pulling off the cover under the TV and found the same thing. You can see light from the outside water outlet from the picture I posted above.
Dennis & Ellie
GMC 1500 AT4 2019 & Airstream Classic 30RB 2019 mikebrownvb Towing, Tow Vehicles & Hitches 54 07-15-2019 11:33 AM
Floor replacement - c-channel bolt holes slipped 1in off frame holes tshannon Repairing/Replacing Floor &/or Frame 2 07-21-2016 04:07 AM
New toilet holes don't match old holes RichHog Sinks, Showers & Toilets 8 03-15-2009 06:36 PM
Extra factory holes in Plywood Floor Cos Repairing/Replacing Floor &/or Frame 4 08-07-2007 02:41 PM
Screw holes in Tradewind floor yochanan Repairing/Replacing Floor &/or Frame 1 01-21-2006 11:50 PM
