Old 02-19-2019, 06:00 AM   #1
2018 30' Classic
Traverse City , Michigan
Frosty Fridge
We have a 2018 30’ Classic with the Dometic refrigerator. The problem is it frosts up quickly and I have to defrost every two weeks. We’ve tried moving the temperature slide per the recommendation of our dealer. Didn’t work. I’ve set the temperature level at 5 and the visible temperature in the outside display ends up at 32. If I put it at 4 it will go to 37-40. Frequently ice cycles are on the coils and melt with water all over the appliance floor. Help. Any suggestions?
Motorhomes were our choice for 40 years and decided to get rid of the stress and experience more flexibility in travel.
2018 30’ Classic
SMKovalchik is offline   Reply With Quote
Old 02-19-2019, 06:21 AM   #2
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Got good door seal?
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 02-19-2019, 07:05 AM   #3
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Unlike home units, Dometic refrigerators are not self-defrosting. Ice/frost build up will be quicker if you are in a humid location and open the door often - or if the door is not closed tightly. In the summer, I usually have to defrost the fridge and freezer every few weeks to keep it operating efficiently.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 02-19-2019, 07:09 AM   #4
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
You can try opening the door less, but that's not really a practical solution in my experience. The Fridge Fix fan, or similar device, will fix the problem entirely. Circulates air across the coils continuously, no frost in the fridge ever. As an added plus, no more warm spots either. I still have to defrost the freezer every six months or so, but never the fridge.
TheGreatleys is offline   Reply With Quote
Making a 2-way Fridge into a 3-way Fridge? Bunkroom Refrigerators 18 06-03-2014 04:37 PM
Fridge Vent and Fridge 12V DC wiring rodsterinfl Electrical - Systems, Generators, Batteries & Solar 1 05-03-2014 09:33 PM
Frosty the Airstream Duck Gator113 Off Topic Forum 51 10-23-2011 09:25 PM
Need Fridge...can Solar keep up with an Electric Only Fridge??? chowman2011 Refrigerators 13 05-17-2011 08:59 PM
Small fridge to large fridge ? 4tumbleweed Refrigerators 3 07-04-2010 06:44 AM
