Old 09-16-2017, 11:57 AM   #1
2018 30' Classic
New York , New York
Fresh Water Tank
I think I saw a post on here, but maybe on Airstream Addicts. Our fresh water tank went from being 50% full from our initial delivery from the dealer to 100% full without being connected to the fresh water intake, but is connected to city water. We were running on city water exclusively for a month and maintained this 50% tank level and then it started filling up on its own. Why would that be?
ajwbarnard is offline   Reply With Quote
Old 09-16-2017, 02:15 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The tank will fill if the reverse flow valve on the pump is defective or simply has a bit of crud in it.
Old 09-16-2017, 02:21 PM   #3
Reads a lot
Titusville , Florida
Check valve properly just stuck. It happens a lot is not considered an issue or defective. Here's the fix. Turn off City Water, I would go so far has to say to disconnect the hose altogether, then turn on your water pump and use the water that is in the tank until gone, then reconnect back to city water.
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 09-17-2017, 03:36 PM   #4
2016 30' Classic
Lorton , Virginia
Also, check the door/port on the fresh water gravity full port. If pressured water is getting into the fresh water tank from city water, it would overflow out of the fresh water tank vent next to the filler port was a certain pressure was reached.
Zybane is offline   Reply With Quote
Old 09-17-2017, 07:42 PM   #5
2018 30' Classic
New York , New York
I think that it may have been leaking near the fresh water intake, but it was raining when this was happening so it was hard to tell. We have been running off the fresh water tank. It has gone down as we have used it and has not gone back up. So using the water pump may have done the trick.
Old 09-18-2017, 05:55 AM   #6
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Since it rained, pop open your outside shower door and see if it's trapping water. I just dumped mine out again last night and cut bigger slots in the foam gasket at the bottom.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 09-18-2017, 06:49 AM   #7
dznf0g's Avatar
Oswego , Illinois
When I got my AS (Used, but hardly), I was unclear about it's history as far as water tank went, so I pulled the bung in the bottom of the tank and flushed it thoroughly. Literally hundreds of shards of plastic came out. Remnants of the hole milling process, I suppose. The debris screen in the filter downstream of the pump would catch most of them, but I would guess that some are small enough to pass through to the pump. I suspect that many check valve fouling instances are the result of this trash.
-Rich-
Old 09-22-2017, 06:41 PM   #8
2018 30' Classic
New York , New York
Thought this had been solved. Used up the fresh water tank this week. Put the city water back and on used it for 2 days. Came back and fresh water tank was filled back up.
Old 09-22-2017, 10:33 PM   #9
1979 23' Safari
Wayland , New York
Consider replacing the pump diaphragm, or opening it up and cleaning it out, there may be dirt in there it cant flush out. You'll need to turn off water for this. You should be able to use a 1/2" nylon plug to plug the line from the pump while working on it.. The only way for water to get in there this way is backwards through the pump. Down the road consider getting a suction strainer for the pump, adding a check valve or shutoff valve on the pump discharge.
Old 09-24-2017, 06:15 AM   #10
Half a Rivet Short
Hi
Since crud is one part of this sort of problem - do a really good flush of the tank and pipes before you swap out parts on the pump. Better to do it before rather than after.
Old 09-11-2018, 08:55 AM   #11
Owljim's Avatar
Golden Valley , Minnesota
Fresh water overflow
I have noticed my fresh water tank is also overflowing. I noticed that the tank will run down when I shut off the fresh water supply and turn on the pump. I will try running the tank down significantly and see if that helps.
Thanks for the tip and I hope it helps.
Owljim is offline   Reply With Quote
Old 09-11-2018, 03:07 PM   #12
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
I have a pump bypass I put on ours, seems to have solved the problem. I put it on to put anti-freeze in the system, but then Alde said not to, after they specifically told me to do so in 2016 on the 2017 we have.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 09-12-2018, 02:12 PM   #13
Reads a lot
With my Classic, the holding tank is now filling immediately every time I hook up to city water so for the moment I am just not going to use the city water connection. I live in Florida and there is lot of lime deposits in the water dis spite using an external filter so I think the check valve is toast. I’m looking into installing a water softener system that would work for the house and the Airstream and have seen a portable system that is compact enough to travel with me. Eventually I’m going to have to replace the Airstream check valve, like soon, and try to find something that will eliminate any hard water left in the tank.
I spent the weekend trying to find and then repair a leak in the Alde system that may have been caused by microscopic hard water build up. Not positive but probably the cause and I don’t want to keep replacing check valves.
Lauri
Old 09-13-2018, 07:17 AM   #14
Half a Rivet Short
Hi
I believe you will find that the check valve is part of the water pump assembly. (yes that's a guess ...).
There are things you can buy at the store to nuke hard water deposits. I'm not real sure that they all are compatible with the metal internals of a plumbing system. Best to read the labels carefully ......
How to keep fresh water tank fresh and tasting good Driftin Di Fresh Water Systems 24 05-19-2017 04:45 PM
Use Black Water Tank as Aux Fresh Water Tank? DaytonaDan Plumbing - Systems & Fixtures 20 10-26-2016 07:53 AM
waste water tank and fresh water tank size 1964 safari jwmonty72 Waste Systems, Tanks & Totes 1 06-28-2016 04:21 PM
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 15 07-21-2015 08:51 PM
Using a fresh water tank as a grey tank? Mike&Ali Waste Systems, Tanks & Totes 14 09-16-2010 10:50 AM
