Old 11-04-2018, 01:48 PM   #1
2019 30' Classic
Pleasant Garden , North Carolina
Factory solar
So, here's another question about a 30' Classic that we won't get until next month. As you all know, the 2019 Classics come stand with the 240 watt solar system. Question is this, should I have additional panels installed by the dealer before I pick it up? Hopefully the wife and I will be doing some boondocking next spring and I was wondering if the factory solar could benefit from additional panels or would I be wasting money.
jlandreth is offline   Reply With Quote
Old 11-05-2018, 04:15 AM   #2
Reads a lot
Titusville , Florida
it all depends on your style of camping. If you plan to boondock you’ll need to upgrade the entire system, not just add panels. If you plan to use full hookup option then you’ll be fine. You’ll still need to upgrade to better battery and inverter. I use my solar as emergency backup and can go 3 days on solar alone (obviously being ultra conservative with energy usage). If you plan on boondocking might do better by buying a generator instead of trying to make things work on solar. There is a member here named Lewstar (sp) that works magic on installing solar system, might need to ask him.
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 11-05-2018, 06:01 AM   #3
2017 27' Flying Cloud
Fort Worth , Texas
My recommendation would be to wait and see how your 240W performs before having a solar upgrade. I would also add that you can likely do a much better system at an independent shop specializing in solar installations.
There is also some merit to having a portable solar panel. The advantage is that these can almost always be pointed to the sun, unlike panels fastened to your roof. You can get an additional 200W panel from someone like Renogy for a reasonable amount of money. The disadvantage is you will need to set them up each time and there is a risk of theft.
billrector is offline   Reply With Quote
Old 11-05-2018, 06:57 AM   #4
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
It also depends on what gauge of wiring is used at the factory. 10AWG may be OK for 200-watts of solar, but you will need a minimum of 8AWG for 400 watts. In fact, upgrading the wire is mostly a labor cost - I opted to spend an additional $50 and had mone upgraded to 6AWG. Then when I added more solar (now 540 watts), the wiring was sufficient.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 11-05-2018, 07:39 AM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Solar only works when ...errr ... the sun shines The gotcha is that to do well, it needs a *lot* of sunshine. We happen to live in the east and the sort of campsites we wind up in are typically nice and shady (at least the ones we like are). That shade can easily knock your "daily solar" down to 10% or less of the best case total.
In a Classic, running the heat (it is late fall ...) you have the combo of power drain and cloudy / rainy sky. Even out of the shade, there may not be a lot of solar coming in compared to what you are using.
As mentioned above part of the answer is bigger batteries. Your stock battery setup provides about 100AH of usable capacity. That may keep you going for a day, it may be enough for two days with some care. Turn on the inverter and the "maybe one day" is optimistic.
For us, the most rational (as if any of this is rational !!) decision was to bump the batteries up to 400AH of usable capacity. That plus the (2017) stock solar panels has done quite well for us.
Even on a Classic, there is a very limited amount of space. Before you decide to give up some of that precious space for this or that, get out and use the beast. See how it works for you and what sort of places you like to go. See how camping without AC works for you ( = the size of solar to run AC full time is massive). You may camp mostly at places with shore power in the June - September time frame. Who knows ....
Old 11-05-2018, 07:52 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard!! 👍
Use it for a Season and decide...Sol will still be there next year. 😎
You may be surprised and find some other up-grades that you really do NEED. 😂
We got this after 11yrs...😉
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 11-05-2018, 09:08 AM   #7
2019 30' Classic
Thanks for the input. As usual I am getting ahead of myself here. Using it for a while and then determining what will work for us makes since. While reading a thread on the solar forum, it appeared to me that you can't use a portable panel hooked to the zamp connector at the batteries while you have the roof top panels. I would love to get a suitcase panel to use when we are parked in the shade but I think you have to do some modifications to us e both.
Old 11-05-2018, 10:05 AM   #8
I'm not sure how the suitcase would work when plugged into the 'factory' Zamp receptacle on your AS.
I use the 7pin umbilical which goes directly to the batteries, I don't see that the factory Zamp connector would be wired any differently.
Others are going thru the same process and I believe they are not using the controller that is supplied with the portable units. A bit problematic if you ever want to use it as a standalone. Re-wiring the portable controller to be taken in and out of the loop is the most obvious work-around.
ID:	327097   Click image for larger version
Amanamus
"Tahawus"
Old 11-06-2018, 08:17 AM   #9
Half a Rivet Short
Hi
The "factory Zamp connector" is just a pair of (fused) wires going from a dirt cheap connector to the battery posts. That's all it is. A pair of clip leads on the battery posts would do the same thing. Running in through the 7 pin does the same thing.
What you would *like* to have happen with a portable panel is for it's power to add in with the power from the other panels. If the battery is completely dead, yes that works. Once you get past the first bit of charging, the controllers start to fight with each other. Unless they are very unusual controllers ( or they can talk to each other) one will win the fight and supply all the power.
Old 11-06-2018, 09:10 AM   #10
'splain please.."one will win the fight and supply all the power."
How does one win?
If I get a second panel,(may be in the works), and it's connected directly to the battery, how would one controller be rendered useless when charging.
If the purchase does happen I would like to be able to use both separately w/o modifying the wiring for each.
Amanamus
"Tahawus"
Old 11-06-2018, 08:20 PM   #11
2019 30' Classic
So if I am understanding this correctly, I could add a portable panel connected by alligator clips directly to the battery and it will not interfere with the factory system?
Old 11-06-2018, 09:50 PM   #12
Ayr , Ontario
If you do that make sure you have blocking diodes installed. Personally I wouldn't do it. Connect the portable panel in parallel to the factory solar. Most likely the factory solar wires are coming down through the fridge area. You can tap into them there. If not I would make the effort to find out where and run a set of quick connections out of a storage compartment or something similar. If all else fails you can pick up a cheap pwm controller like the Prostar from MorningStar. Then it's truly stand alone.
gator.bigfoot is offline   Reply With Quote
Old 11-06-2018, 10:06 PM   #13
2019 30' Classic
Understood, thanks for the input.
Old 11-06-2018, 10:13 PM   #14
Zamp portable?...our unit has a connection line from the Zamp controller with alligator clamps...that was the reason for my question above. I don't see how separate controllers interfere with each other.
Amanamus
"Tahawus"
Factory Installed Solar Charging System SilverGate Generators & Solar Power 471 11-08-2018 08:22 AM
Can a portable solar panel be added to a factory solar system? larry9000 Generators & Solar Power 7 10-14-2017 05:35 PM
Is this a factory installed solar panel ? I think it's factory installed and ... JacobMerridy Electrical - Systems, Generators, Batteries & Solar 1 01-14-2017 10:23 AM
Supplement Factory Solar with Portable Solar dkottum Generators & Solar Power 10 06-16-2016 04:28 PM
Adding a New Panel to the Factory Solar richschafer Generators & Solar Power 1 04-03-2008 10:32 AM
