11-11-2018, 06:29 PM
#41
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
We did a different approach and totally rewired the trailer so all outlets are powered by the inverter that is attached to a 600 amp hour lithium battery and nine 100 watt solar panels on the roof.
11-11-2018, 07:04 PM
#42
2018 25' Flying Cloud
Portland
, Oregon
Now THAT’s a system! One more advantage to having a +30’ trailer...more space for solar and batteries!
11-12-2018, 08:10 AM
#43
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Originally Posted by SilverWind
I believe your system's solar charge controller needs to have the capacity for all of your panels combined.
A&M Solar made a modification to the Victron Charge Controller in my 500 watt system to accommodate a supplemental portable solar panel.
In my case it is a ZAMP 160watt panel connected via the (Airstream factory installed) ZAMP connector on my 2017 25FB battery box.
Hi
With dissimilar panels all running at once, you are very unlikely to get the combined output of all of them .... The Zamp portables have a controller built in so they are even less likely to combine with a rooftop setup.
11-12-2018, 08:14 AM
#44
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Yes, it's a system. It's still incapable of doing air conditioning when it's really hot out. One way or the other you need to come up with the power for that if you camp in the places we do. Two AC running at the same time can barely keep a 30' cool in the hot sun. They run for *many* hours each day.
11-12-2018, 08:37 AM
#45
Anna Maria
Hi
If your batteries are lead acid, they go through a coupe of phases as they get charged up.
Step one is indeed gobble as much current as the charger can deliver. The big question always is - how much does this or that charger actually deliver. There are a lot of models out there that do not deliver "label" amps right up to full charge. (for some really good reasons ... ).
Next step is limited by the battery chemistry. The battery no longer gobbles current like crazy. The battery posts are now up to darn near whatever voltage the converter is putting out. The battery is not fully charged. Is this the 80% point or some other point? That depends on a lot of factors. One is just what we are going to call fully charged. ( = that could be the labeled amp hours or the actual capacity of the batteries at their current temperature).
After the taper charge part of the process is over, your fancy super charger may indeed drop into the "let's rev up the battery" phase. If it's doing something useful, you don't have 100% until that part if finished.
Best guess with most batteries is that you will be in some sort of low(er) current charge phase for several hours coming from a pretty dead battery. How long it would take your converter / charger to go into super charge mode is very model specific.
So my take away is that don't let your batteries run down more than 50% if you don't have an immediate source of power available.
Thank you for the information.
11-12-2018, 01:47 PM
#46
Portland
, Oregon
That's correct for lead acid. With lithium you can go down to 20% should the need arise.
11-12-2018, 03:46 PM
#47
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Well ... errrr ..... this is always going to be a "that depends" sort of thing.
With Battle Born lithiums you can run them down to "zero". What's zero in this case? Well it's the 100AH that the label says is their capacity. The BMS cuts out and stops you once you get too far down the discharge curve. Is that really zero? Certainly not, but it is > 100AH below full charged at normal temperatures.
Trojan wet cell T-105's have some really odd charge parameters for a lead acid. If you charge them per their instructions (which pretty much nobody ever does), they claim you can go pretty far down the discharge curve without major impact. Yes, we're talking about 40% full vs 50%, but that's still a pretty big deal.
Virtually all batteries have more capacity when they are hot than when they are cold. You can indeed get 125% of rated capacity crammed into some batteries if they are a bit on the hot side. Yes, when you cool them down the capacity drops again. Attach them to a load and keep them hot .... you will get the extra 25%.
Yes, it's complicated and you need to dig a bit on whatever batteries you happen to have.
09-06-2019, 09:28 AM
#48
2010 16' Sport
2015 19' International
2020 23' Globetrotter
North Bend
, Ohio
Adding Zamp portable to Airstream with factory solar.
This is from the frequently asked question section of Zamp's website:
3. Can I connect two charge controllers to the same battery bank (e.g. combine a roof mount system and a portable kit)?
Yes, two independent charge controllers can be connected directly to the battery as long as both controllers are set to the same battery type.
The charge controllers will not work properly if wired in series, one to the other.
09-07-2019, 12:33 PM
#49
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
You can hook them both up (just as the stock AS parts are both hooked up at the same time). They will not self destruct when you do so. They also will not damage the batteries. So far so good. The gotcha is that they also will not do quite what you expect in terms of charging the batteries.
10-21-2019, 11:17 AM
#50
Everywhere
Forgive my solar ignorance, the learning curve is steep!
With factory solar can additional freestanding solar panels be plugged into the existing solar factory setup to add additional solar charging capacity?
Or is it better to start from scratch, with no factory solar, and build your own system based on your individual needs?
I realize this is likely a loaded question and has innumerable 'what ifs' but need to start somewhere with advice and input from experienced Airstreamers. Thank you.
10-21-2019, 11:23 AM
#51
KW
, Ontario
It depends. How are you plugging them in. Do you have room in the factory controller for the additional cells. What is the voltage of the cells you are adding. Are they similar to the ones you already have. Etc.etc.
Best method is to add an additional controller close to the batteries and feed into it. Leave the factory setup alone, since it has too many limitations anyway.
10-21-2019, 11:34 AM
#52
2018 27' Globetrotter
Apollo Beach
I would suggest building your own if you have some skills in splicing wires together and can keep positive and negative wires in order. Installing solar on newer Airstream's with the Zamp Rooftop Box and factory prewire is a fairly easy task with some electrical knowledge and the support from AirForum members who've done it before. You will likely get a higher quality installation with more wattage and you will have the skills to maintain the system if you install it yourself. A 400W solar installation can be self installed for less than $2,000.
If you choose to purchase the factory solar package, you could still improve that system by replacing the solar controller $300, upgrading the wires between the solar controller and busbars $20, and adding a couple of additional panels $500. This totals around $800 in addition to the cost of the factory solar.
We're here to help if you decide you want to install your own solar. I was intimidated by solar too at first, but found it was easier to install than I first anticipated.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
10-21-2019, 11:54 AM
#53
Everywhere
gator.bigfoot and AirMiles,
Thank you for the replies and advice. We like boondocking more than not. The information you mention about factory solar limitations was a concern of ours. I have read many of the threads about solar and have come away with one significant piece of information; if you want solar independence than a conversation with Lew Farber is needed. We do not necessarily need that much solar, I don't think, but we are learning. I will continue to read and learn and make mistakes and move on. Your advice and input will not be forgotten. Thank you, Jeff and Kathy.
10-21-2019, 12:31 PM
#54
Sierra Vista
Wow! Do you ever contract out? I recently acquired a 1992 B190 van in which I need to replace house battery, but more importantly add as much solar as possible. I know nothing electrical and am not confident with the local RV dealers.
10-21-2019, 08:57 PM
#55
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Factory solar
I might suggest watching some Utube videos by Will Prowse. He seems to be very knowledgeable, enthusiastic and candid about solar, batteries and controllers.
We were all ignorant about solar at one time. I have learned a lot from the knowledgeable people on this forum. Thanks to all of you.
Dan
11-21-2019, 08:55 PM
#56
Zeppelin1597
2018 30' Classic
Ocala
So you have Two 80w panels on the roof, is it best to add two 80w Zamp portable panels so that the roof and portable are «*balanced*» or does it matter? Would there be issues if two 200w portable were added instead? Thanks
11-21-2019, 09:01 PM
#57
Oswego
Size(watts) doesn't matter. However, they all should have very close output voltage spec.
-Rich-
11-25-2019, 10:52 AM
#58
2018 30' Classic
Jacksonville
Hi
As I drive around the country, there are a *lot* of RV parks with great big water slides and multiple other "attractions" right on site. ........., I am at a bit of a loss to see the benefit. We all get to do it our way ....
My daughter and her family with small kids to teen agers and her adult friends with kids like the parks with the water park, activities, haunted houses, ATV trails, fishing, etc. I can see the attraction. But don't stay longer than a day or so to visit. Then it is off to the park with better kayak destinations. We all have our preferences and reasons.
On the solar and the OP post....... on the 2019 at least he has 240watts. I only have 160watt but it seems to handle our needs. The OP should experience the system before worrying about it.
