Old 04-23-2019, 09:35 AM   #1
2019 30' Classic
Pleasant Garden , North Carolina
Electric bikes
The wife and I are looking at getting a couple of ebikes. Looking for suggestions on how to transport them. Prefer not to put them inside the AS or in the bed of the truck. Thanks
jlandreth is offline   Reply With Quote
Old 04-23-2019, 10:04 AM   #2
waninae39's Avatar
2017 22' Sport
NCR , Ontario
do not hang them off the rear or the bumper
many AS have flipped and/or turned over with rear bikes
waninae39 is offline   Reply With Quote
Old 04-23-2019, 10:35 AM   #3
Dave-n-Janet's Avatar
Moss Point , Mississippi
You might want to check lunacycle.com and their folding 20" e-bikes. About 45 lbs. I know you don't want to carry in TV bed, but e-bikes are expensive... We have one of these folding e-bikes and like it a lot. I can easily unload/load and it doesn't take up much room in my bed under my tonneau cover. My regular bike goes on top of it. Still can carry generator, gas, weber, propane, chairs, fire circle etc etc... My main criteria was something I could load/unload myself. This is one of the only e-bikes light enough to fit the bill. Has worked out very well. 20+ mile range. Got it for my wife...but will get myself one at some point.
Dave-n-Janet is offline   Reply With Quote
Old 04-23-2019, 10:50 AM   #4
Mollysdad's Avatar
Many? How many? Where? Who's?
Let me understand. Airstream will SELL you a bike rack and mount it on your Airstream, but somewhat that doesn't cause your Airstream to roll over?
Someone posts a photo of an Airstream that flipped over, and everyone has a theory on what caused it, when in fact, no-one knows.
"He should have bought a PP hitch."
"He should have run 80 psi in his tires."
"He put stuff in the back."
"He should have bought a F-350."
[/rant]
I digress.
I'm still trying to decide the best way myself, everything from a front receiver on the truck to a mount on a board inside the door. I have a hard tonneau, so it's not going in the bed.
A cap on the truck bed is probably the best, if you can get past the "grandpa" look and loss of visibility.
Here's the YouTube couple LoLoHo, and their solution.
I admit it's not right for me, either.
Old 04-24-2019, 07:46 AM   #5
2019 30' Classic
[/rant]
I digress.
This is the exact cover I have. Problem is, most bike racks are rated for 35 to 40 lbs. Our ebikes weigh 59 lbs. Don't know whether to chance the extra weight or not.
Old 04-24-2019, 08:19 AM   #6
Mollysdad's Avatar
They have two Arial Riders Plus a Yakima carrier on the crossbars. I believe they remove the batteries so the bikes are in the 50# range.
That cover doesn't work for me because with a Honda 3000is, I need every inch of headroom, thus the hard tonneau.
The secret of the tracks is the ability to use the rails for cargo. Yakama says this system is rated for 300# on road, and 180# off road.
https://www.yakima.com/bedrock-hd
I noticed his cargo carrier is a Thule.
Old 04-24-2019, 09:04 AM   #7
2019 30' Classic
Just got off the phone with customer service at Yakima. They don't have anything that will take the weight of our ebikes. They weigh 58 lbs each and Yakima's top rated bike carrier is 40lbs.
Old 04-24-2019, 09:30 AM   #8
2019 30' Classic
Also forgot to mention. The manufacturer of our bikes stated that they should be transported with the batteries in place because they create a water tight seal for the electronics.
Old 04-24-2019, 09:45 AM   #9
2017 28' International
Baileys Harbor , Wisconsin
My wife and I have Trek ebikes. We have a bit of an advantage in that my son works at Trek and we can get them very reasonably. He works in the ebike development part as an engineer. We do love them. Very solid and great rides. You get what you pay for with ebikes.
We tow them on the front bumper. I put a hitch on the front. It makes them easy to get on and off. They are much heavier due to battery and motor than typical bikes. DO NOT put them the back of the AS. With bikes, hitch, and rack that's quite a bit of weight.
I also have a way of putting them in the trailer if need be (raining) with bike stands and then covering them up with packing blankets so they don't scratch everything up should they move around. They are pretty solid while riding. If you need to see what I use you can personal message me with your email and I can send you pictures of the type of stands I use for the inside.
Putting them on the front isn't maybe ideal for road dirt, etc. but we haven't found it to be a problem. Just spray them down a bit and you have to make sure chains etc are lubed well.
The advantage of using the front bumper is easy on and easy off, and then when we want to go and ride somewhere to travel we can then load the bikes on the back with the rack.
Daquenzer is offline   Reply With Quote
Old 04-24-2019, 09:53 AM   #10
2019 30' Classic
PM sent
Old 04-24-2019, 11:04 AM   #11
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I bought an Evelo folding bike at the end of last year. Love the features, best of the designs, I think. Mine folds and fits nicely in the truck bed under my cap. Would never work with a tonneau, but it is one of the reasons I have a cap.
Larry
lsbrodsky is offline   Reply With Quote
Old 04-24-2019, 11:26 AM   #12
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Simply not true. I don't know who you talked to at Yakima but they don't know their product. This is the specs for the Holdup two by Yakima. I own it and use to to transport our ebikes, a Raliegh for my wife and a Giant for ne, both around 50 lbs, no problem.
Specs:
Application: 2" x 2" trailer hitch receivers
Carrying capacity: 2 bicycles
Weight capacity: 60 lbs per bike
Carrier weight: 49 lbs
Wheel diameter: 20" - 29"
Tire width: up to 2-1/2"
Maximum wheelbase: 47-3/4"
Distance from center of hitch pin hole to:
Closest wheel holder: 12"
Closest wheel holder when folded: 7"
Limited lifetime warranty
The only issue is whether to add a two inch reciever to the trailer, or to put a front receiver on the truck. What to do, what to do...
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
Caffeinated is offline   Reply With Quote
Old 04-24-2019, 11:37 AM   #13
1986 31' Sovereign
Miami , Florida
Electric bikes
If you have decent regular bikes, you can convert them with a kit from electric-bike-kit.com. I have the Hilltopper conversion on my Trek 7500. Works great and in ten years, I've only gone through two batteries.
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 04-24-2019, 01:04 PM   #14
2019 30' Classic
Specs:
Mike
The Yakima rep was referring to their bike racks that fit on the crossbars.
E Bikes X2 Bikes On Top Of Truck Bed mythbuster88 On The Road... 11 03-01-2019 10:46 PM
Kayaks and bikes jordandvm Off Topic Forum 42 02-26-2009 09:12 PM
Foldup Bikes campadk Off Topic Forum 29 11-21-2007 08:28 AM
Bikes and Bambi Trevor Davies 1997 - 2004 Bambi 13 12-22-2004 07:07 PM
How Do U Bring Bikes Along? Steve Heywood On The Road... 30 04-06-2004 10:37 PM
