Old 06-14-2019, 05:38 PM   #1
2019 30' Classic
LEES SUMMIT , Missouri
Czone not working
Help!! My czone system stopped working and the blue lights on each of the control panels are flashing 7 times over and over. The main Czone screen lights up and lists all of the lights etc. but it will not allow me to turn on anything and won't display the status of water levels etc. Talked to the factory customer service and they have no idea what is wrong.
dechampion is offline   Reply With Quote
Old 06-14-2019, 06:19 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Check the communication cables at the ends. One at the Czone, the other in the lower compartment next to the breaker box. If you don't find anything loose, check the fuses in the Czone fuse box in the same compartment. If everything there is good, turn off the trailer battery switch by the door, wait a minute, then turn it back on.
There is an emergency tank/voltage monitor panel under the kitchen sink, next to the shelf where the sink covers go when they're not in use.
Old 06-14-2019, 06:31 PM   #3
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Turn your battery disconnect switch off. Go into the cabinet to do it under the wardrobe. My disconnect switch by the door does not work. Yours certainly won't either.
Turning everything off will shut off the large switch where all the cables go. It will reset everything. Mine did the flashing thing once and this solved it.
Our Google images and chat: https://photos.app.goo.gl/CMQbpNXQwapMnj8t9
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
turk123 is online now   Reply With Quote
Old 06-14-2019, 10:25 PM   #4
2019 30' Classic
Thanks for the suggestions. I checked all the wiring and everything is tight. Nothing wrong with the fuses. I tried disconnecting the batteries both from the button next to the entry door and the knob in the cabinet below the wardrobe. Still no luck. There are no lights on any of the Czone components in the cabinet below the wardrobe.
Old 06-15-2019, 05:03 AM   #5
turk123's Avatar
2019 30' Classic
Canfield , Ohio
You can call Czone. I’ve talked to them once before. They did not do the programming on the system, but could help on basic operations.
Old 06-15-2019, 05:37 AM   #6
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
When you did a power reset, did you leave the power off for 10ish minutes or just flip it all off then on again?
BigSxyWhtGuy is offline   Reply With Quote
Old 06-15-2019, 10:15 AM   #7
2019 30' Classic
I left the power off about 3 minutes each time.
Old 06-15-2019, 10:18 AM   #8
2019 30' Classic
Did you have a similar problem?
Old 06-15-2019, 10:43 AM   #9
2019 30' Classic
In the interest of trying everything, I disconnected the batteries again (using the knob in the cabinet below the wardrobe) and left it off for 11 minutes before turning it back on. Still nothing. Fortunately, I already have a 2-day appointment scheduled for late August to have the Jackson Center Airstream factory fix everything else wrong with this 4-month-old "Rolls Royce of travel trailers". I've added replacement of the Czone system to the list. Unfortunately, with the Czone not working, I pretty much am stuck with the equivalent of a hard shell tent for the summer (prime camping season). Thanks for the suggestions, everyone.
Old 06-15-2019, 01:25 PM   #10
2018 30' Classic
Long time to wait, you may be able to get into a local dealer quickly for a fix under warranty?
Unfortunately I have firefly but usually that prolonged power reset does the trick. Sorry you’re dealing with this!
Old 06-15-2019, 06:22 PM   #11
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Inside the cabinet under the wardrobe is the Czone switch with all the cables going to it. I assume you said you had no blinking green lights correct?
My trailer is in storage so I can not check, but I believe the Czone box is not fastened down. If not, I would pull it out and see if it is getting power or has been disconnected. If you have power to the panel, the problem lies with this box.
Old 06-15-2019, 09:28 PM   #12
2019 30' Classic
Correct. There are two czone boxes beneath the wardrobe and neither has any lights lit. The cables are connected to the boxes.
Old 06-16-2019, 06:20 AM   #13
2019 30' Classic
Fixed it !! One of the yellow cable connectors behind the circuit breaker panel came loose. Screwed them back together. Click image for larger version
Old 06-16-2019, 06:27 AM   #14
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Great! . . . and good to know!
I got a feeling you are like a lot of us here. It just bugs you that you know it is something simple and staring you right in the face. You persisted and that's what matters. Great news!
Old 06-16-2019, 07:33 AM   #15
2019 30' Classic
Turk123 it was your post that caused me to look deeper and trace all of the cables back to their sources and that is when I found the disconnect. Thanks again.
CZONE replacing fan with MaxxFan The Naker 2016 - Current Classic (all lengths) 18 08-01-2019 07:27 AM
CZone and Multiplex Interfaces In General Re-Pete 2016 - Current Classic (all lengths) 10 05-26-2019 09:11 AM
Regarding Multiplex Interface Systems such as CZone, etc. Re-Pete Electronics & Connectivity 0 04-16-2019 10:53 PM
CZone app skiphoyt Sprinter and B-van Forum 1 03-07-2019 07:42 PM
CZONE Display Reset? PaulR-GA 2016 - Current Classic (all lengths) 5 10-31-2018 02:41 PM
