Old 05-21-2017, 06:46 PM   #1
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Classic Villa Power sofa
Our new 2016 Classic sofas seemed a little off to us. The legs didn't come up quite as far as we thought they should.
A look at the sides of the extended legs confirmed this. It was not extending to the stop pins. There was a space there.
To fix this look under the extended legs. Pull the keeper and the pin. Simply unscrew the round arm to make it a little longer, so it lines up when you hold the legs lift up. It only will screw one way, because they ship fully compressed.
I hope this help some.
Regards.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 05-22-2017, 08:17 AM   #2
Reads a lot
Titusville , Florida
Very helpful. Thank you for posting. I am new to Airstreaming and still learning a lot because people like yourself took the time to write and offer a fix. Again, thanks.
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 05-27-2017, 03:20 PM   #3
2018 30' Classic
Sioux Falls , South Dakota
Send a message via Yahoo to Kyet
Cushions in arms of sofa
What are these for? I'm hoping nothing and I could use that for storage
Kyet is offline   Reply With Quote
Old 05-27-2017, 03:49 PM   #4
Reads a lot
Kyet- those cushions are used to make the dinette into a bed. The table lowers, you throw the cushions in place and bam! Another bed.
Lauri
Old 05-28-2017, 01:21 PM   #5
2018 30' Classic
Bummer, Thanks though. I think this is going to be some slim living
Old 06-10-2017, 09:48 PM   #6
2016 30' Classic
Santa Barbara , California
Extending the recliner
I've just visited Leggett & Pratt's (the recliner used in our 2016 Classic) website for a description of the adjustment you (Bigventure) mentioned. https://www.leggettmotion-intl.com/f...ts/en/3368.pdf
Where in the diagram is the adjustment part you spoke of?
Also, it seems that our Classic uses the "Supercliner." https://www.leggettmotion-intl.com/f...upercliner.pdf which appears to show the back cushion reclining as well (which ours doesn't).
We've been adding pillows under the legs and behind our lower backs to achieve more reclining.
DavidLawson is offline   Reply With Quote
Old 06-11-2017, 06:16 AM   #7
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Strange how you got a different sofa in your unit. I own a new 2016 Classic. It looks more comfortable than my Villa. The piece I was referencing is not listed as a separate piece in the parts. But it is the only silver part. The motors shown on the left in the middle is the outer tube and to the right is the inner tube that you can adjust. I hope that helps. Don't look to get a whole more motion out of it. It does have limits.
I chose America
Old 06-11-2017, 06:23 AM   #8
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
I'm thinking about the dinette in the 2016 Classic. And I think I can remove the seat backs by cutting a few tacks. This would make the bed at least 8" bigger.
Has anyone done this? I'm concerned about what type of backing is under the backs. I could sew some Velcro to keep them in place afterwards.
Could someone post a photo of a 2017 seat back?
I chose America
Getting new Sofa- Villa International any pointers? rodsterinfl Dollars & Cents 3 03-08-2016 04:25 PM
Power sofa, power bed, etc. Billstream Airstream Trailer Forums 4 03-04-2016 07:07 PM
Recliners by Villa Lift ? swede0030 Cabinets, Counter Tops & Furnishings 2 04-28-2013 06:31 PM
Building L sofa Need Help & Suggestions (Bob Villa) LI Pets Cabinets, Counter Tops & Furnishings 21 11-08-2006 11:22 PM
