Old 11-07-2017, 01:01 PM   #1
Half a Rivet Short
Carlisle , Pennsylvania
Classic Fun with Fuses
Hi
Just incase anybody else runs into this on their newer Classic:
First symptom is a "thunk" from the speakers over the recliners. It sort of a "what was that" kind of thing.
Next you notice that the recliners don't move and the blue lights are out on the USB charge ports.
Rather than dig into what I did next, take a look at the TV. Is the red power LED out? If so it's lost power as well. They both are on the inverter circuit ... hmmm....
Do you still have shore power? I keep a tester in the kitchen socket so that's a quick check. (if no shore power ... go fix that ...)
Next, turn on the inverter for a second (if it's not already on) still no power on the TV and recliners? (if that fixes it, check the number 7 breaker ....)
The common element between the shore power and inverter is a fuse in the front of the inverter. You get to it by pulling the drawer that is under the microwave. It's at the back of the inverter by the wall. It's a cartridge fuse in a screw in holder.
Powering down the 120V when pulling the fuse can be done with the breaker or by unplugging the inverter. That plug is behind the lowest drawer under the sink.
Pull the fuse and if it's like mine you will find a SLC-15 fuse. Check it with an multimeter. It's likely blown. If not, keep digging ...
Good luck finding an fuse from the same guys (Littlefuse). What you are more likely to find is a SC-15 fuse. It's essentially the same thing from a different outfit (Bussman). Home Depot is a likely source. You probably will not find them at a small town hardware store.
Pop in the new fuse and things come back to life. One is left wondering just why the fuse popped in the first place. That's something one may or may not find out at some point in the future ....
Camping is *so* much fun !!!
Old 11-07-2017, 02:31 PM   #2
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
I was told that with the 2017 Classics and at the time only our trailers the Inverter can be bypassed simply by turning it off at the inverter not the Firefly. All other trailers I was told the 110 power goes thru the inverter whether it's on or off.
So, you are sure it's an SLC 15? I just checked Amazon and they only have the SLC 30.
Plus I don't get why a 50amp system would have a 15 amp SLC fuse, but then there is a lot I don't get.
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 11-07-2017, 03:50 PM   #3
Half a Rivet Short
Hi
The magic fuse involved is in the 120V transfer switch circuitry. It is in common with both the inverter output and the 120V pass through from shore power.
Amazon for the fuse in my inverter:
https://www.amazon.com/Littelfuse-SL...eywords=SLC-15
Amazon for the fuse that is easier to find:
https://www.amazon.com/Bussmann-BP-S...rds=SC-15+fuse
Since it's a 120V fuse, your normal inventory of 12v automotive fuses aren't going to do you much good. It is a bit hard to dig down to, so finding out just what it is ... not so easy.
Not surprisingly, none of the buttons on the inverter did anything to bypass the fuse. So far after a few hours, the new one is doing fine ..... let's hope it stays that way.
Old 11-08-2017, 12:33 PM   #4
paiceman's Avatar
Thanks Bob, I too wonder why anything something like this occurs. Often it's "operator error" - me, but almost as often it's not and simply don't know why. Which continually bothers me every time we go out.
Bud
SAFE TRAVELS
Bud
Old 11-09-2017, 05:52 AM   #5
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
120v/15 amps for that one AC circuit that the inverter powers from the battery when not on shore power?
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 11-09-2017, 05:56 AM   #6
Obviously-NOT
Kalispell , Montana
Buttons? I thought it was just a silver box with a few lights and a fan from a jet engine repurposed to cool it and blow away all the surrounding cobwebs.
You boon docking somewhere to use the inverter?
Old 11-09-2017, 09:06 AM   #7
sbowman's Avatar
1972 31' Excella 500
Grapeview , Washington
I may be missing something? You have shore power in use and the inverter on at the same time?
Scott & Liz
2017 Classic
2016 RAM 3500 6.7
sbowman is offline   Reply With Quote
Old 11-09-2017, 10:50 AM   #8
Half a Rivet Short
Hi
Ok, backing up a bit:
On the Classic, the "inverter" sockets are live when you are on shore power. In most AS trailers, you play a game plugging things into either an "inverter" or a "shore power" outlet. That does not go on with the Classic. Instead, there is a transfer switch built into the inverter.
The transfer switch looks at what is going on and either hooks the downstream outlets to the inverter or to shore power. The switch is rated at 20A, so is the circuit that the inverter is plugged into. To keep odd things from happening they use a protection fuse rated at 15 rather than 20A.
The magic fuse is just there to protect the switch. It really has nothing to do with the inverter side of things. The same fuse is used to protect the switch in inverter or shore power mode. If the fuse blows, both functions go dead. Yes, that's a bit "interesting" but it's the way things are wired.
When you are on shore power with the inverter off, you don't think much about the inverter. Outlets go dead, you are on shore power ... what to check? Inverter is not the obvious first thing to dig into. Indeed, firing up the inverter is a quick way to see if "this fuse" is the one you are looking for. If not move on Other than that, the inverter function is not involved.
The inverter it's self is pretty conventional looking. It has a rear panel that the wires go into . It has a front panel with an LCD display, some LED's, the fuse holder, and buttons. The big red button lets you turn on the inverter independent of the FireFly should you ever need to do that.
So yes, it's all a bit odd until you dig into it. It took me a couple extra loops to figure out what was what. My guess is that others will run into the same problem eventually. If so, having it all spelled out might save some time. The information is in the wiring diagram. Like most diagrams, it's a bit cryptic. Needless to say, I've done a *lot* of diagrams like that over the years Made sense to me on the day I drew it
Old 11-09-2017, 11:54 AM   #9
2000 25' Safari
Denver , North Carolina
I predict in the future there will be a thread starting with " I didn't find an answer to this question about a magic fuse on a newer classic".
mbubbaca is offline   Reply With Quote
Old 11-09-2017, 12:47 PM   #10
paiceman's Avatar
I don't like Amazon, but it is great. I got my two, hopefully, never to be used back-up SLC 15 fuses today. I still don't get what they do or why, but at least know I have one for each hand.
Bud
SAFE TRAVELS
Bud
Old 11-09-2017, 02:36 PM   #11
Half a Rivet Short
Bud
Hi
They protect the sockets that have an "inverter" label on them in the trailer. When you loose power to the inverter sockets, that fuse may be the problem (or it may not be ...)
Old 11-10-2017, 04:02 AM   #12
paiceman's Avatar
Hi
OK, thanks, now I've got it and the fuses.
Bud
SAFE TRAVELS
Bud
Old 11-21-2017, 03:25 PM   #13
Obviously-NOT
Kalispell , Montana
Bud
Me too, thanks uncle bob.
Old 11-21-2017, 05:29 PM   #14
Reads a lot
Titusville , Florida
I don’t. Please keep it super simple for me. What fuses do I need to keep on hand just in case this magical preinverter fuse goes bad? Where do I go to purchase this, what do I ask for, and where does it go, (assuming it goes in front of the inverter ) No, I am not a complete idiot but I am not an electrical engineer nor do I wish to go back to school to become one. However, I do not wish to be caught off guard while on a trip so I will be teaching myself all that I can pertaining to my trailer including crash courses in wiring diagrams. Any and all help is welcome. KISS : )
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Fuses, Fuses, Fuses PSU1981 Electrical - Systems, Generators, Batteries & Solar 9 10-13-2017 11:54 AM
Fuses, what fuses? safariuser Electrical - Systems, Generators, Batteries & Solar 8 04-06-2015 05:52 AM
1980 Airstream Landyacht! Original Condition! Fun Fun eBay Watch Airstreams on eBay 0 04-13-2009 08:10 PM
replacing glass fuses with blades maznblu Electrical - Systems, Generators, Batteries & Solar 4 08-05-2003 11:34 PM
12 volt fuses jim clydesdale Electrical - Systems, Generators, Batteries & Solar 2 03-18-2003 05:47 PM
