Old 05-23-2018, 01:36 PM   #1
steverino's Avatar
2018 30' Classic
Ivins , Utah
Classic Bag 'o Parts
Looking through the box of stuff that was delivered with our 2018 Classic, I found a bag of parts which I've found might be used for emergency retraction procedures of the awning and other devices. However there are some pieces I cannot figure out yet.
From the left of the picture below:
1. 1/4 threaded fitting with hex head
2. 5/16 hex to 1/4 hex adapter with a magnet in the 5/16 end
3. 9/32 hex extension
4. 1/4 hex flex extension
5. Plastic antenna-looking thing that is probably not an antenna
6. Jumper cable with SAE connector on one end, alligator clips on the other
Referencing the Zip Dee Relax Awning manual, 1, 2, and 4 appear to be used in the awning emergency manual retraction procedure.
Referencing the Lippert Stabilizer manual, none of these parts appear relevant. The hand crank referenced in the manual was not included. Raising the question of how to retract the stabilizers in a no-power emergency situation.
Included (and not pictured) however is the hand crank for the Atwood tongue jack, so I am good there.
3, 5, and 6 I have no idea. Perhaps 6 is usable to connect a portable solar panel or external battery.Does anyone have knowledge of any of these?
steverino is offline   Reply With Quote
Old 05-23-2018, 03:04 PM   #2
rperrym's Avatar
2017 28' Tommy Bahama
Hot Springs Village , Arkansas
Item number 6 is to run the awning motor from your batteries, assuming the other parts of the awning are operable.
Rick
2017 27 Tommy Bahama
2018 2500 GMC Duramax
rperrym is offline   Reply With Quote
Old 05-23-2018, 03:31 PM   #3
2016 28' International
2015 28' International
2013 28' International
Las Vegas , Nevada
These are all Zip Dee automatic awning tools:
1. Awning spring tensioner tool-you don't want to ever have to use this!
2. Awning arm retractor tool-Ha! it takes over 20 minutes to retract arm!
3. Extension for tool #2-only when the arm is straight up.
4. Extension for tool #2-this is the one to use!
5. Awning limit switch tool-on front of tube under the black cover-don't touch this!
6. Wire jumper harness to run roller motor directly from battery-to get the fabric all rolled up when the control pad will not work.
Great stuff
vintagemotor is offline   Reply With Quote
Old 05-23-2018, 03:44 PM   #4
steverino's Avatar
2018 30' Classic
Ivins , Utah
Awesome, thank you all! What a great resource is the members of this forum!
Air Bag alfalsetto Mechanics Corner - Engines, Transmission & More... 5 09-27-2003 10:16 AM
Argosy rear air bag leveling valves. Mark K Airstream Motorhome Forums 5 09-15-2003 05:34 AM
Air Bag Part # jim8860 Mechanics Corner - Engines, Transmission & More... 0 08-18-2003 02:53 PM
What's this? Radiator bag? TinCanSue Our Community 4 07-30-2003 08:01 PM
air bag compressor zamboni Mechanics Corner - Engines, Transmission & More... 2 11-19-2002 11:38 AM
