05-31-2018, 09:45 PM
Lakeland
, Tennessee
Bike rack
06-01-2018, 04:42 AM
2012 27' Flying Cloud
W
, New England
Have you noticed any change in handling with that setup? Many discussions here about the physics of putting weight on the back of the trailer like this. Definitely not recommend.
06-01-2018, 05:25 AM
2018 30' Classic
Cumberland
, Maryland
Like the pics, now how about some info please?
06-01-2018, 05:32 AM
2016 25' Flying Cloud
Jupiter
At first glance, that doesn't look like a good idea. How is the hitch receiver connected to the trailer/frame?
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
06-01-2018, 09:40 AM
2014 27' Flying Cloud
Viera
If you had any warranty on the Airstream, it’s gone now.
Randy & Pat Godfrey
Florida Airstream Club (027)
ACI# 1212 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
The best part of any trip is when you pull away from home.
06-02-2018, 06:24 AM
Lakeland
, Tennessee
Not at all. 2000 miles so far.
06-02-2018, 06:29 AM
Lakeland
, Tennessee
Warranty! What’s that. I’m not sure how welding on a hitch will effect my pluming, elec...etc thanks tho.
06-02-2018, 06:35 AM
Lakeland
, Tennessee
Welded to the frame. All total right at 100lbs.
06-02-2018, 06:39 AM
Lakeland
, Tennessee
Just welded to frame. Bike rack your chose. This bike rack folds down (see pic) and you can easy access everything. 100lbs weight. 2000 miles on it and no difference in towing.
06-02-2018, 06:58 AM
Lost in America
2015 27' FB International
2004 19' International CCD
Santa Fe
, New Mexico
You may want to consider another point of attachment to help alleviate the frame stress with the bikes bouncing up and down as you go down the road. Perhaps some kind of a strap from the rack/bikes attached to the shell of the trailer at a rib point, maybe over the rear window.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017 Chevy Silverado 2500HD Duramax Diesel
06-02-2018, 07:10 AM
Rich and Kat
Alexandria
Alexandria
, Virginia
Fair enough that you’re not worried about your frame warranty, however, as Steve pointed out, there are significant concerns with adding weight to the rear of the trailer, especially with a bike rack. The extra weight that hangs off the back is ‘amplified’ by the distance from the axles.
http://www.airforums.com/forums/f238...ay-156615.html
http://www.airforums.com/forums/f48/...ec-153984.html
I’m not telling you what to do, but please consider, for your family’s safety, to do some reading about this situation and make a more informed decision. Good luck.
Rich
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 3500 Laramie Crew Cab 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
KB2ZMF Save
06-02-2018, 07:18 AM
Lakeland
, Tennessee
Yes, looked at that hard. So, same bikes and rack on my truck driving off road many times and no problems. Triangle design is what I would like for sure.
06-02-2018, 07:47 AM
Lakeland
, Tennessee
The video is a great visual of what happens when you change the fulcrum point “by extremes”. I weighed in (at the weight scales) 8500 trailer. The total weight I have on the back is 100lbs. .011% of total. With bike rack off, the scale wouldn’t even detect a weight change on the tongue weight. I’m running a pro pride hitch set up and I tow no more than 65mph. I just drove 2000+ miles across the US and at one point 40 mph cross winds and ONE finger on the wheel. I’m not sure what you are reading. So yes I did some homework and testing before I left and put my family in there.
2000 25' Safari
Davidson County
, NC Highlands County, FL
my advice: remove that rack from the trailer.
Those smiling faces in your photo/avatar is what you are betting will not be harmed by the addition your bike rack.
The weight back there does not harm anything, UNTIL IT DOES. Then it's too late.
I installed a bike rack on my trailer too. After seeing and reading so many times about how sway events are caused by extra load on the rear of a trailer and seeing the wreckage, I removed it. I use a rack inside the trailer now.
Alan
06-02-2018, 07:51 AM
Rich and Kat
Alexandria
Alexandria
, Virginia
By the way, another option to consider in lieu of putting the bikes on the rear of your trailer is to add a hitch receiver to the front of your tow vehicle... Again, good luck.
Rich
KB2ZMF Save
06-02-2018, 07:55 AM
Lakeland
, Tennessee
Yea I looked at that. I’m not saying this the best set up but in my opinion it’s safe.
06-02-2018, 07:59 AM
2000 25' Safari
Davidson County
Do another test.
Extend your arms straight out from your sides, parallel to the floor. Rotate your hips so that your arms move in an arch around your body, then stop suddenly. See how your hands want to keep moving, following that circular motion.
Now add a 10 lb weight to one of your hands and do the same motion. See how this weight is amplified. It makes that hand want to move even more as you stop suddenly. That is what your bike and rack will do to your trailer.
100+ lbs swinging behind the axle is amplified several times by the distance (simple leverage) This horizontal left/right motion (sway) is the danger!
Alan
06-03-2018, 10:04 AM
Reads a lot
Titusville
I think what people are trying to do is save your life. Airstream only has one bike rack manufacture they recommend and only one. I am sure you did your due diligence but please reconsider.
Just because you managed to drive 2,000 miles and no one died doesn’t mean it’s safe. A lot of folks driving impaired actually do make it home in one piece.
Lauri
She Believed She Could so She Did.
06-03-2018, 04:48 PM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
Airstream frames not designed to take any additional weight, especially on the rear with bouncing bikes
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
06-03-2018, 05:14 PM
2016 30' Classic
Hinckley
, Ohio
Bike rack
I think OP is fine with what he has done. The frames are much bigger on the new trailers. They are not 3” channels any more. As long as he tied into the frame with the hitch tube he will be fine. Actually I will be doing the same thing, when I get around to it.
Let me ask what is the difference between a fiamma bike rack with bikes on it or a regular bike rack? As long as the weight is carried by the frame, it will be no problem.
My bike rack is a tray model with a no wobble bolt though. So no bouncing or wobble.
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
