Old 05-09-2019, 04:16 PM   #1
2019 30' Classic
Lakeland , Tennessee
Battery disconnect issue 2019 Classic 30
When we got home from a recent trip I was unable to engage the battery disconnect from the panel by the door. I was able to engage it via the touchscreen, however. When I got back in it a week later the battery disconnect button on the entry panel would not work at all. I had to manually operate the battery disconnect, but I was still able to turn it off via the touch screen or the app. Now I've replaced both the entry panel and the battery disconnect under the wardrobe with no results. If I manually turn the battery disconnect to "Auto On" it turns itself back off after a few seconds. Has anyone else had an issue like this? I am able to manually operate it for now but I would prefer to have it function as intended.
jugdish is offline   Reply With Quote
Old 05-09-2019, 04:52 PM   #2
Fort Davis , Texas
Welcome to computer control. I suspect that if you turn it off using the computer the manual switch cannot turn it back on. Try turning it on with the computer and leave it on. The manual switch may then work. If not, just use the computer to control the system.
Suspect some growing pains with Airstream and the new computer system in the Classic.
Pat
pdavitt is offline   Reply With Quote
Old 05-09-2019, 05:14 PM   #3
2019 30' Classic
Unfortunately the computer is turned off when the battery disconnect is engaged, so it's only possible to turn the power on via the manual switch.
GMC 1500 AT4 2019 & Airstream Classic 30RB 2019 mikebrownvb Towing, Tow Vehicles & Hitches 54 07-15-2019 11:33 AM
Any news on 2019 interstate on new 2019 Sprinter. jagzoo Sprinter and B-van Forum 4 11-18-2018 05:15 AM
Battery Disconnect Switch Issue ATE123 Sprinter and B-van Forum 17 08-28-2017 07:31 AM
To disconnect or not to disconnect urnmor Towing, Tow Vehicles & Hitches 36 02-22-2017 10:24 AM
Battery Disconnect Issue mje Batteries, Univolts, Converters & Inverters 8 02-16-2015 11:24 PM
