Old 07-11-2018, 02:40 PM   #1
2018 30' Classic
Bothell , Washington
Bathroom door latch 30í Classic
On our Classic, the bathroom door just barely latches. I donít see any movement in the casing (walls) around the door.
Is there any adjustment on the door latch (handle assembly)?
I tried to take it apart but without damaging anything, I could not figure out how to get the handle coverplates off. Handles have Allen screws but could not figure out the circular covers.
Thanks....
charlesk is offline   Reply With Quote
Old 07-12-2018, 10:00 PM   #2
Reads a lot
Titusville , Florida
Hopefully someone will be along shortly to offer some advice. I’m no help at all.
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 07-12-2018, 10:20 PM   #3
2007 22' International CCD
If you have the handles off the latch, look around the coverplates carefully for a small notch or bent part of the metal. Use a plastic putty knife to gently pry off the notched coverplate to expose the screws.
If there is no notch, pry gently and see which cover plate pops off. Usually itís the inside one.
Old 07-13-2018, 11:13 AM   #4
2018 30' Classic
Rich,
Thanks for the reply. There is a small notch on the bottom of the circular cover plates. Seems to be a small plastic piece in the notch. I tried for 30 minutes, without getting too aggressive, and still could not get them off.
I’ll keep looking.
Thanks.
Chuck
Convert vintage door latch to modern double rotary latch & strike? Mixter Doors & Locks 5 02-19-2017 10:12 AM
Bathroom slider door latch CaCraig 1970 - 1973 Sovereign 0 10-06-2016 12:27 PM
2015 classic bathroom door latch issue gwg 2011 - 2015 Classic (all lengths) 11 07-29-2015 09:42 AM
Bathroom cabinet latch is junk- 2006 Classic kleimanr 2006 - 2010 Classic (all lengths) 7 07-25-2014 03:05 PM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 10:52 AM
