Old 11-15-2015, 06:11 AM   #1
beetlebob's Avatar
2015 30' Classic
Green Cove Springs , Florida
Bathroom door handle
Has anyone heard or had done of a new handle upgrade on the door that stays on and tight. Have to tighten mine about 3 times a month and it just doesn't fit snugly. Also we have been stationary so its not from moving around a lot. Thanks
beetlebob is offline   Reply With Quote
Old 11-15-2015, 06:54 AM   #2
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Bathroom Door Handle?
What model, length, year of AS? There are multiple handles....
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 11-15-2015, 07:17 AM   #3
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I am unsure from the OP post if the door is sticking and causes the handle to be placed under unusual stress.
In my experience with out 2014 Classic, Airstream does expend funds for the best quality hardware.
If they used wood screws, then glueing a couple of wooden match sticks in the screw hole and then reattaching might work, If they are machine screws, a drop of blue Loktite will hold them in place but still be removable, Red Loktit is not a good choice as you would end up having to drill the screw out in the future if work was necessary on the handle mechanism.
Old 11-15-2015, 11:49 AM   #4
beetlebob's Avatar
2015 30' Classic
Manitoba we are in the classic trailer page so guess what I have. 2015. How was alumilina?
Old 11-16-2015, 10:35 AM   #5
Msmoto's Avatar
2007 25' Safari
Images: 135
Alumalina was great
Alumalina_2015_10.24.15-8 by Tommie Lauer, on Flickr
https://www.flickr.com/photos/fantin...57659920704220
Old 11-20-2015, 03:50 PM   #6
beetlebob's Avatar
2015 30' Classic
No update on the handle so I will fix it the way it should have been done. Thanks all. Msmoto did dogs only show up. You are a great photographer don't you have more
Old 11-21-2015, 10:32 AM   #7
Msmoto's Avatar
2007 25' Safari
Images: 135
Plans vs, how it turns out...LOL
My plans were to photograph folks and their trailers. Logistics never worked out....so, only a few photos of people.
At the Spring Alumalina....more shot of folks and trailers, sort of walk around surprise.....but, also, more pets....and, at the events...lots of individual shots...always a crowd pleaser...as long as "You don't shoot my photo".....
And, thanks for your comment....and more...how is this?
Untitled by Tommie Lauer, on Flickr
like billions of stars...now that is "more"...LOL
Old 11-22-2015, 08:47 PM   #8
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Bob....I have had the same issue with my bathroom door handle. It has come off 3 times. I finally secured it with Locktite. You probably noticed that A/S did not mortise the lockset into the edge of the door. I did it myself for a better fit into the doorframe. While the handle looks nice, it seems as if the allen screw vibrates loose. We'll see if the Locktite works.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 11-23-2015, 01:18 AM   #9
switz's Avatar
2014 31' Classic
Images: 8
Use blue Loktite if you want to be able to remove the fastener in the future. Red Loktite is more for permanent fasteners.
Old 11-24-2015, 05:32 AM   #10
beetlebob's Avatar
2015 30' Classic
I started by drilling a small hole into the metal shaft so the Allen screw would have something to hold on to and then used some blue lock tight to hold it in. With the small line up hole the handle stays tighter to the assembly.
How I Turned my Plain Bathroom Door into a "Porthole Door"...for $1 Fly at Night Our Community 15 08-28-2015 08:40 PM
Changing out Bathroom Door Handle in CCD Westfalia Airstream Trailer Forums 4 11-20-2013 12:01 AM
Accordion Door For Bathroom and Door Lock - 1963 Jinji 1960 - 1964 Globetrotter 2 11-13-2013 08:17 AM
Door handle for outside of screen door RTurnConn Exterior Storage Compartments & Access Doors 1 08-27-2011 10:16 PM
bathroom exhaust fan handle replacement charlie tuna Roof Vents, Skylights & Fans 8 09-08-2006 07:40 PM
