Old 01-13-2019, 06:22 PM   #1
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Anyone seen this before?
Looks like water or something got under our molding? Hope it’s still under warranty, thoughts on maybe a quick fix or just let airstream tackle it?
BigSxyWhtGuy is offline   Reply With Quote
Old 01-13-2019, 06:35 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
If your trailer is still under warranty, document it immediately with Airstream.
If the warranty is done, and you want to replace that flexible molding it comes in rolls, peal and stick.
ODM has it in vinyl/chrome, 1/2" wide ~$2 per ft and 1" wide ~$3 per ft
Alan
Old 01-13-2019, 06:39 PM   #3
Overkill Pundit
GMFL's Avatar
2014 23' International
Dadeville , Alabama
No water just the belt line chrome trim peeling. Very common problem. Very easy fix. While you are at it you can seal the hard and upgrade the mild steel hardware behind the lower trim to stainless steel.
Here’s my blog post
http://www.airforums.com/forums/blog...ehind-it-2971/
Dept of “OverKill”
GMFL is online now   Reply With Quote
Old 01-13-2019, 07:02 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Get it replaced under warrantee...but be prepared to replace/repair it again before too long.
I just installed 3m reflective tape on ours. 1" & 1.5" wide. Reflective, 9005 blue.
Worked... well and looked pretty good.
Scroll up-down for more info.
Good Luck
“Side effects from the Network News Broadcast?…ask your Doctor." 🤪
RLC
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 01-13-2019, 07:06 PM   #5
Reads a lot
Titusville , Florida
There was a thread on this for another 2017 or 2018 Classic that had the same problem. If I remember correctly, the molding was put on upside down so water could get in but not drain. I believe the original poster was able to take the handle off, got a new gasket and fixed the problem. I think mine may be upside down as well but I’m not absolutely positive (no water yet) but I’m watching. Right now it’s stored and not getting rained on.
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 01-13-2019, 07:18 PM   #6
2018 30' Classic
Thanks guys. Bob, tape looks great!
I’ll wait for airstream to fix it under warranty. Added it to my list, excited to see the main airstream base in April
Old 01-13-2019, 07:28 PM   #7
I do think the tape looks good. It is a much easier install with 4 hands, wouldn't have turned out so well without the DW's help.
I only found the tape after replacing the "plastic chrome" twice. 🥴
T O..we have Family in Simi
RLC
Amanamus
"Tahawus"
Old 01-13-2019, 07:48 PM   #8
2018 30' Classic
I like Simi. Glad we left Cali! Shooting in Thousand Oaks followed by that big fire. It actually went through our old neighborhood. Happy to be on the road full time in the airstream!
Old 01-14-2019, 10:26 AM   #9
Amsterdamer's Avatar
2015 27' Flying Cloud
Caledonia , Michigan
I also had to have my lower belt molding replaced due to the same issue when the chrome layer pealed off. The new molding will not stick well if the old adhesive is not completely removed, which was not done well by my dealer. Cold and wet also make adhesion difficult.
I ended up adding some 3M VHB tape under the replacement molding to make it stick better.
Amsterdamer is offline   Reply With Quote
Old 01-14-2019, 02:35 PM   #10
PCJ
2018 30' Classic
Eden Prairie , Minnesota
You have a two year warrenty should be covered
PCJ is offline   Reply With Quote
Old 01-14-2019, 04:01 PM   #11
2017 23' Flying Cloud
Port Richey , Florida
Thanks for the idea...I almost want to replace mine and there’s nothing wrong with it.
Jstsal69 is offline   Reply With Quote
Anyone seen this type plug before 1mackenzie Batteries, Univolts, Converters & Inverters 5 09-18-2015 12:36 PM
Anyone seen a Uniden PC22 CB before? Keyair Phone, CB & Ham Radio 4 05-11-2012 03:16 PM
Anybody seen this before? bake315 Off Topic Forum 16 10-09-2004 07:42 PM
