Old 12-13-2018, 09:31 PM   #1
Anyone Installed Lift Kit On A 2018 Classic 33FB?
Our 2018 Classic 33FB is wonderfully comfortable, low and long. I often worry as I carefully maneuver to avoid dragging or backing that long rear end and low sewer connect. Three more inches of clearance would be great when visiting the rougher and more scenic parks and hilly urban areas. Has anyone installed a Dexter Lift Kit? Is the Dexter #11 a good bolt on fit? I am concerned about fitment with the belly tanks and ability to handle the heavy load of a 33FB. Thanks for your help.
jrkott is offline   Reply With Quote
Old 12-14-2018, 06:12 AM   #2
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
http://www.airforums.com/forums/f437/lift-kit-installed-today-189927.html
Seen this recent thread? Don't remember any 2018's in the sea stories.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 01-02-2019, 11:29 AM   #3
Jhess's Avatar
2017 22' Sport
Johns Creek , Georgia
Did you get the lift? If so how is it working out and did it change your towing any? This is something I’d like to do if we purchase the same 2019 unit.
Jhess is offline   Reply With Quote
Old 01-03-2019, 10:46 AM   #4
2016 30' Classic
Lorton , Virginia
This is definitely on my to-do list.
Zybane is offline   Reply With Quote
Old 01-10-2019, 10:21 PM   #5
I called Dexter and gave them the numbers on my 2018 Classic 33FB axles. I have the 11 axles and they assured me the lift kit could handle the weight of the 33FB and should fit the frame mounting configuration. He said Airstream’s install of the tanks and covers was more custom than uniform, so I might need to get creative to accommodate wrench access to some of the fasteners, but it should fit without any drilling to the frame. When I asked about the effect on towing, he said I should raise my weight distribution tow ball the same three inches the lift kit raises the trailer and I should be good to go. The kit arrived two days later. I will install it when I get the unit back from warranty repairs on the projector and plumbing.
Old 01-11-2019, 06:52 AM   #6
Jhess's Avatar
2017 22' Sport
Great, thanks for the update! Looking forward to hearing again after your install.
Old 01-11-2019, 11:11 PM   #7
2016 28' International
2010 25' FB Flying Cloud
Grand Rapids , Michigan
Thumbs up on the Dexter lift. We installed this on our 30ft INTL to give us more ground clearance (esp. tail-drag). I had suspected there wouldn’t be any noticeable handling difference which ended up being true. Very happy.
ArkFortyCal is offline   Reply With Quote
Old 01-11-2019, 11:12 PM   #8
I meant to add: Of course we had to re-adjust our ProPride hitch setup.
Old 01-12-2019, 02:03 AM   #9
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Great to hear. My kit arrived and I plan to install on my 30’ international.
Did you install yourself? How hard was it to get at the bolts given the water tank covers?
wulfraat is online now   Reply With Quote
Old 01-12-2019, 09:25 PM   #10
2018 28' Flying Cloud
Fairfield , California
I can't speak specifically to the 30ft, but when I installed the kit on my 28ft in October, my tanks blocked bolt access to at least one bolt head on all four blocks. My work around was buying a cheap 15/16 combination wrench, cut it in half, taped each to end of pieces of rebar to make a long extension. This reached through the frame channel between tank and frame to get to the bolt heads to hold them. Some worked better with open end, others with box end.
StuartsDad is offline   Reply With Quote
Old 01-26-2019, 03:03 PM   #11
wulfraat's Avatar
My Dexter lift is being installed on my 30” international on Monday. Timeless Travel trailers in Denver are doing the work for me in their shop - 6 hours labor.
Swapped out the shank on my equalizer to raise the ball 3” to accommodate the lift.
Pictures to follow of the lifted rig - no more dragging the rear end over the smallest undulations in parking lots!
ID:	332393   Click image for larger version
Old 01-26-2019, 05:00 PM   #12
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***
Nice choice ...
2015 25' Eddie Bauer Int Sp Ed
2015 Chev Duramax 2500; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Terminal Aluminitis; 2-people w/ 2-dogs
Old 01-26-2019, 05:09 PM   #13
2019 27' Flying Cloud
Peyton , Colorado
So...are we going to need a lift kit on our (prospective) 27FB? We tend to get off the flat quite a bit...
SnooMc is offline   Reply With Quote
Old 01-27-2019, 08:41 AM   #14
2013 25' International
Boise , Idaho
Lift Installation
Wulfraat - how'd it go, we want to see!
-A
afk314 is offline   Reply With Quote
Lift Kit Installed Today Al and Missy Axles 54 12-12-2018 08:22 PM
2018 Classic 33FB Zip Dee Main Awning For Sale Slipsstream Airstream Classifieds 0 08-11-2018 07:18 PM
Is anyone Airstreaming an Classic 33fb in Europe? Kokopuff Travel Beyond US/Canada 2 04-05-2018 05:25 PM
Dealer installed lift kit? ChrisnPatty General Repair Forum 2 09-28-2017 08:28 AM
Largest tire size w/ Dexter 3" lift kit installed? Airstreamkup Tires 13 04-24-2017 09:25 AM
